Old 05-03-2013, 07:24 PM   #1
ROCCERO4
ROCCERO4 is on a distinguished road
Idea Power Steering Pump Pressure Hose Removal
Today I decided to take on the replacement of my leaking power steering pressure hose, but when I came to loosening the bolts on the rack I did not have the correct tool. I read something where Old Nuc suggested using a 6 point open end wrench, well I may have something else that my Saturn mechanic ( when Saturn was in operation) gave me, a crowfoot wrench 18 mm. It fits perfectly over the replacement hose nut,so tomorrow I will try it out to see if this application works. In the meantime he also told me that when I loosen the return hose to pour p/s fluid down from the top and when it starts coming out clean you wouls have removed all the gunk on the bottom of the pump.Any input on this topic would be appreciated, and I will let u know how I make out.
Add to ROCCERO4's Reputation
Rate the quality of this post and help ROCCERO4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ROCCERO4 is offline   Reply With Quote
Old 05-03-2013, 07:41 PM   #2
Default Re: Power Steering Pump Pressure Hose Removal
18mm crow foot/ brake line wrench is what you need. Pretty much this thing here.
Don't forget the PB Blaster or whatever penetrating fluid you like the best that isn't WD40
Not sure about the cleaning out the gunk part, doesn't sound like a bad idea...just never thought to try it.
Need help with power steering pump removal rawphd S-Series Tech 13 12-24-2012 01:49 AM
SL-1 power steering hose- which one? osp001 S-Series Tech 3 03-10-2011 03:08 PM
Power steering pump removal Mac Guy S-Series Tech 9 10-10-2008 11:51 PM
Power Steering Pump Removal AJT_Leo S-Series Tech 7 09-15-2008 05:16 PM
Power Steering Pump Removal javaboy S-Series Tech 3 07-13-2005 10:31 AM
