Old 02-26-2010, 09:52 PM   #1
yogi1200
yogi1200 is on a distinguished road
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
Dizzy elec. short
My 93 SC1 has started to short out when any electrical device is turned on. It started with the radio cutting out then coming back on when I stepped on the brakes or turned on the hi beams. Now it's shutting down the engine and it won't even crank for about 45 seconds if any electrical impulse is applied. Then it starts up and runs fine. It will act like this about every other day. Any Idea's? Thanks for the help.
Add to yogi1200's Reputation
Rate the quality of this post and help yogi1200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yogi1200 is offline   Reply With Quote
Old 02-26-2010, 10:51 PM   #2
Default Re: elec. short
What kind of radio do you have in there and what do you have plugged into the cigarette lighter socket?
Old 02-28-2010, 04:55 PM   #3
yogi1200
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
Dizzy Re: elec. short
No it's a sony wired into the factory harness. It has worked fine for the last 3 years. The problem is that the engine now dies once in a while when I step on the brake, turn on the wipers, turn signal, heater fan,.. Anything that causes an electrical circut to be used.
Old 02-28-2010, 05:22 PM   #4
Most likely the alternator is bad and only partially charging (bad diodes).
Add to ssicarman's Reputation
Old 02-28-2010, 05:54 PM   #5
+1^^^Test alternator and battery. A bad diode may not show up on an alternator out put test but the battery should show as being low on charge. To check for bad diodes you have to bench test it.
Old 03-01-2010, 02:28 PM   #6
yogi1200
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
The alt. was replaced about 8 mos ago. I guess I should have it tested anyway.
Old 03-01-2010, 04:23 PM   #7
Yes, a bad diode will cause the problem you are having and rebuilt alternators are well known for high infant mortality. This all gets down to a process of elimination working from cheap/easy to high cost/labor intensive.
Elec Rear Lights ragpicker S-Series General 6 09-27-2009 07:15 PM
Elec Rear lights ragpicker L-Series General 1 09-24-2009 08:12 AM
Elec Window probs now PlainSC1 S-Series Tech 8 12-28-2008 01:04 PM
Replaced VB, can elec. cause no reverse at all? tacinc1 S-Series Tech 0 03-28-2008 02:50 PM
1994 SL1 Elec. Problems Alicia051703 S-Series Tech 5 11-10-2006 11:51 AM
