Old 02-05-2019, 01:41 AM   #5761
wizerdwolf
wizerdwolf is on a distinguished road
2001 SW2
Pulled a pair of projector fogs from an Audi A6 this weekend, and just finished installing them on my SW2! The top of the housings are nice and flat with the mounting holes level, so it was very easy. Used angle brackets and rov nuts to mount them to the bumper support bar.
Add to wizerdwolf's Reputation
Rate the quality of this post and help wizerdwolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wizerdwolf is offline   Reply With Quote
Old 02-06-2019, 03:55 PM   #5762
Very nice! I never think to check the Euro aisle for parts. . . usually don't have time.
Hit the JY Sunday, muddy/icy as heck, to pull a door for the minivan.
Grabbed an OEM TPS for the Saturn while I was there, installed it last night. I think it is working, had forgotten about it by this morning. Will try to remember to pay attention to my rpms on the way home.
Jumped through the hoops to return the 2-month old dud TPS to Rockauto - have to remember to package and send the part back.
Old 02-06-2019, 05:34 PM   #5763
carangil
carangil has a spectacular aura aboutcarangil has a spectacular aura about
1996 SL1
Replaced EGR valve, as its had that code (intermittently) set for a while, and each time I clean it it buys me 6 months.
Replaced downstream o2 sensor because that code came on a couple weeks ago for a bad heater circuit. New sensor works great.... I bench tested it with a torch and multimeter.
Passed CA smog... well under the limit for most things.
1996 SL1, only 120k miles.
Add to carangil's Reputation
Rate the quality of this post and help carangil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carangil is offline   Reply With Quote
Old 02-07-2019, 10:15 AM   #5764
wizerdwolf
2001 SW2
While the Saturns do seem to always be in one section, our yard has no organization to it, and everything is mixed together. I try to go early enough on a weekend day so I can check everything out and don't feel rushed, if I have an idea of what I'd like to find.
Old 02-07-2019, 07:59 PM   #5765
bumpdraft
bumpdraft is a jewel in the roughbumpdraft is a jewel in the roughbumpdraft is a jewel in the roughbumpdraft is a jewel in the rough
bumpdraft's Avatar
1998 SW2
Replaced the front right brake caliper just because the one on the car was the factory original.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 02-09-2019, 01:30 PM   #5766
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Hit a small pothole today and the dome light popped out. The plastic clips were extremely weak so I had to zip tie it back up. Feels better in place now than it did before!
Looking for a power steering pump and pulley and luckily found one in good condition. Only thing is: its from a 94 SC1 and I have a 99 SL2. Does anyone think it will/won't fit? It looks too similar to not take the chance.
The Daily Driver
1999 Saturn SL2
Mileage: ~126000
The Weekend Warrior
2008 Honda Accord EX-L
Mileage: ~153500
The Special Lady
1993 Chevrolet Camaro
Mileage: ~193500
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 02-09-2019, 03:35 PM   #5767
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Looking up the part number, 21013318, it seems like Saturn used the same ps pump 91-02 so it should go in fine.
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Old 02-11-2019, 06:19 PM   #5768
Pitcher
Pitcher's Avatar
'98 SC2 Red Hot bucked & stalled on the way to Church. All crank, no start.
Had to have her towed.
Crankshaft Position Sensor was bad. Replaced.
Also replaced the Fuel Filter. I had a spare NAPA Gold. Needed it.
Red Hot is all good now!!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-12-2019, 02:26 AM   #5769
cpy911
cpy911 has a spectacular aura aboutcpy911 has a spectacular aura aboutcpy911 has a spectacular aura about
1996 SC2
What steps did you take to diagnose that?
Originally Posted by Pitcher View Post
'98 SC2 Red Hot bucked & stalled on the way to PChurch. All crank, no start.
Add to cpy911's Reputation
Rate the quality of this post and help cpy911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cpy911 is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
