Old 12-31-2018, 02:12 PM   #41
SLfun
2006 ION Red Line
Default Re: Engine Swap Advice (2002-2001 SC2-1)
Congratulations on a nearly complete drive train swap!
I did my swap 3 years ago, and you reminded me of all the little (and big) challenges along the way.
Happy trails!
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-31-2018, 03:02 PM   #42
SSarge
SSarge is on a distinguished road
Congratulations on getting your Saturn running.
The BCM contains the stored odometer mileage.
Add to SSarge's Reputation
Rate the quality of this post and help SSarge reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SSarge is offline   Reply With Quote
Old 12-31-2018, 03:13 PM   #43
Passlock is in the lock housing, not the lock proper. All you need to do is run the security reset AFTER you have replaced BOTH the PCM and BCM. That should get them synced. As it now runs you did what needed to be done.
Old 12-31-2018, 03:27 PM   #44
Very nice job! Kudos and welcome to the forums.
Add to Waiex191's Reputation
Old 12-31-2018, 10:17 PM   #45
Saturn Night
Originally Posted by SaturnGirl02 View Post
Progress Update!
The car starts and runs!! : So, after reading a bunch of random information on the internet, much of it on this forum, I decided to try some things before looking into getting the pcm reprogrammed. What worked in the end was, with the SC1's pcm and bcm, I turned the key to the run position, left it for 10 minutes while the security light blinked, and when the light shut off (which was almost exactly at the ten minute mark), I turned the key off, and did it again. I did it three times, and after shutting it off on the third time, I tried to start the car. The security light did not blink at all and the car immediately started, stayed running without a problem and has started multiple times.
Other random notes: The car shows the low miles from the SC1 engine, I assume because both the pcm and the bcm are in the new body. The SC1 that all of this came from had no features at all (crank windows, no running lights, no electric locks, nothing.) All of those things now work on the SC2 body even though I am using the pcm and bcm from the other car, as does the sunroof. I am assuming the cruise control will not but haven't tried it since I cannot yet attempt to drive the car, but we'll see. Every single wire and connector matches up on both cars, the colors of the wires match and everything, with a few exceptions that had to be modified and the one to the power steering left off (just in case anyone reads this thread with the intention of doing a swap themselves and wants to know!).
Thank you all again for your help and input. I still have to change the throttle cable (they are two different lengths), the shifter cable, bleed the brakes, and fix the exhaust or have a new one made (mine was destroyed in the accident and the SC2 does not match what comes off the cradle of the SC1). I will post again when everything is complete and the car is driving!
Happy New Year too all!
The difference between the SOHC exhaust and DOHC exhaust are the manifold head pipe. After the converter, the DOHC has a resonator(which can remain in the system with the SOHC without ill-effects to performance or economy). Once you are past the resonator, the pipes, hangers, and even the muffler are identical.
http://www.walkerexhaust.com/catalog...catalog-lookup
You can use this website for seeing the exhaust system diagram.
Old 01-03-2019, 01:43 PM   #46
Nice work and congratulations!
Kudos to you for tackling this job and saving a car
Originally Posted by fetchitfido View Post
3rd gens don't care about the cluster like 1st and 2nd gens do. Put whatever cluster in you feel like...even if it's a L-Series or Vue or Torrent (full swap list).
Good to know, thanks! I'm a big fan of the Pontiac Torrent gauge set.
http://saturnfans3.saturnfans.com/~s...postcount=5201
I do a fair amount of night time driving and the red lit needles / numbers is easy on the eyes. I just have to mask off the traction control light and remember to run a code scanner on it occasionally
Old 02-04-2019, 12:50 AM   #47
hendryjullius
hendryjullius is on a distinguished road
good day
Add to hendryjullius's Reputation
Rate the quality of this post and help hendryjullius reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hendryjullius is offline   Reply With Quote
Old 02-04-2019, 10:23 AM   #48
Spammer in our midst folks - please report him. He did a bunch of good day posts so he could start posting links.
2001 SC2 Engine Rebuild Advice mrvann202 S-Series Tech 6 06-13-2010 01:36 AM
Engine swap advice Cathode_Ray S-Series Tech 13 03-27-2008 09:40 PM
Need Engine Swap Advice...ASAP.... 93BLKTWINCAM S-Series Tech 8 04-30-2005 12:40 PM
Need advice on DOHC engine swap old51 S-Series General 5 03-20-2005 11:59 PM
Possible Engine Swap, Advice Needed Quick Kentai S-Series Tech 5 07-16-2004 03:32 AM
