Old 05-25-2019, 12:26 PM   #1
Wessmith33
Wessmith33 is on a distinguished road
Default No radio or turn signals clicks after starter swap
Changed struts, shocks and starter on 07 aura and now the radio will not power on and the turn signals or hazards do not click when they flash. Did I forget a ground or unhook something by mistake. Fuses look good. There is a component in the the trunk on the left side quarter panel that I hit a few times trying to squeeze my 6í1 ass into the trunk to swap shocks, could that be the issue. Thanks all
Wessmith33 is offline   Reply With Quote
Old 05-25-2019, 02:21 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: No radio or turn signals clicks after starter swap
I didn't need to do anything in the trunk to change rear shocks. I changed mine, didn't even take the back tires off. Just jacked it up a bit so I could reach in above the tire to get the 2 nuts off the studs. I backed it up on ramps to get the bottom bolt out. Put the shocks in place, installed the bottom bolts, drove it off the ramps. Jacked it up a bit to install the top nuts on the studs.
Hard to see how changing struts and shock could affect the radio and signal lights.
On the starter, there are 2 wires on the connection stud. I almost missed the second one when I was putting mine back together. Don't know what kind of weird stuff could happen if one was not connected.
I've had ground wires break off that caused all kinds of wacky stuff to happen.
Without removing the trunk liner, the only component I see on the left rear quarter panel on my Aura is the rear fuse box. There is a fuse for an amplifier in it. Nothing for signal lights.
Are you checking the fuses in the box on the passenger side of the center console too?
Old 05-25-2019, 03:43 PM   #3
Wessmith33
Yes I checked all the fuses. Also noticed there is now no chimes for anything....key in, headlamps on, door ajar...nothing. Canít find a chime fuse or chime module so not sure what issue is.
Old 05-25-2019, 03:51 PM   #4
imaddicted2u
2008 AURA XE
Chimes function is built in the radio and fed out of the front driver door speaker.
Have you disconnected the battery and reconnected it?
Old 05-25-2019, 06:24 PM   #5
Wessmith33
Yes several times. No change. Canít imagine any wire down by the starter that would be radio connected. Iíve double checked all fuses too. Maybe the radio unit just took a **** but I figured at least the clock would work. Nada
Old 05-25-2019, 06:51 PM   #6
imaddicted2u
2008 AURA XE
Just came across this, you might find it helpful.
https://www.2carpros.com/questions/2...do-not-working
Old 05-26-2019, 07:14 AM   #7
imaddicted2u
2008 AURA XE
There is a known issue with the BCM connections getting corroded. There was a recall for when the increased resistance affected brakes. Not your issue but since the BCM turns the radio on, you might get lucky if you clean the BCM connector and apply dielectric grease. Plug it in and out a few time before finally seating the plug.
The BCM and connector are integral to the instrument panel fuse box in the passenger compartment. (I'm not responsible for any damages caused by trying ths... )
https://www.consumeraffairs.com/news...ms-051614.html
Old 05-26-2019, 07:21 AM   #8
imaddicted2u
2008 AURA XE
Pic of BCM
Old 01-18-2021, 02:49 PM   #9
eusjma
eusjma is on a distinguished road
Hello All
Resurrecting this thread versus creating a new one.
I have a 2007 Saturn Aura XR - have owned since new
Had battery issue recently, tried to jump start it (didn't help), took battery out and to NTB, they tested and said it was no good (unchargeable).
Got a new battery and installed it.
Car starts but now the radio doesn't work (as with the original poster).
Fuses are good.
I didn't check the BCM connector yet (as someone above suggested).
In the past 13.5 years we have either jump started this car or replaced the battery and have never run into this problem.
eusjma is offline   Reply With Quote
Old 01-19-2021, 05:22 AM   #10
imaddicted2u
2008 AURA XE
If the fuses are good it would seem that you are down to the BCM itself, BCM connections or the radio has failed.
Old 01-20-2021, 07:49 PM   #11
eusjma
So to check that BCM does it mean simply disconnect that multiconductor connector and visually inspect? Or is there more to it?
And if I disconnect that, do I need to disconnect the battery first?
Old 01-20-2021, 08:27 PM   #12
imaddicted2u
2008 AURA XE
Best practice would be to disconnect the battery. Inspect the connector and pins for corrosion. The service bulletin says to put dielectric grease on the connector to prevent corrosion.
04 Radio power on/off with turn signals and brake application. talonsaab Vue Tech 8 10-27-2016 04:14 PM
Starter just clicks awilson506 S-Series Tech 13 07-12-2012 09:24 PM
Changed Clutch, Starter won't spin/engage (starter clicks) VolvoDude S-Series Tech 10 10-08-2010 02:47 PM
Turn Signals Wont Blink After Cable Swap surprisinguy S-Series Tech 2 06-30-2010 11:30 AM
turn signals, radio & dash lights out felix18 Ion Tech 4 09-02-2008 09:38 AM
