Old 10-29-2004, 12:05 AM   #1
roswell998
Guest
Posts: n/a
Question Detecting proper seating of new rings by compression check?
So far so good on 96 SL2 engine rebuild.............
I used the Haynes manual method of ring seating breakin and now have about 40 miles on engine.
Compression check on warm engine is 200 psi +/- 2psi on all cylinders.
DOES THAT IMPLY THAT RINGS ARE PROPERLY SEATED?
Old 10-29-2004, 12:21 AM   #2
Hiddenlites
Hiddenlites is on a distinguished road
Hiddenlites's Avatar
1993 SC2
Default
It sounds better than the 175 5psi that I measured on my warm engine a couple of weeks ago.
1993 Saturn SC2 75k
2004 Chevy Silverado Z71
2008 Saturn VUE Redline 175k sold 7/8/16
2013 Honda Accord Coupe
2016 GMC Acadia
Hiddenlites is offline
Old 10-29-2004, 12:30 AM   #3
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
Perhaps but I wouldn't count on it. It's best to break-in the motor for about 500 miles or so. Some feel better going a full 1000. The rings SHOULD seat without issue if everything was done correctly.
It is a good sign that your compression numbers are linear.
SLeepr is offline
Old 10-29-2004, 12:47 AM   #4
sierrap615
sierrap615's Avatar
Default
yeah, the numbers are good but don't go racing it quite yet
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 10-29-2004, 01:27 AM   #5
wolfman
wolfman's Avatar
Default
What he ^ said.
wolfman is offline
Proper engine compression after lost oil? luvme2tymes S-Series Tech 14 08-21-2009 08:42 PM
proper strut mount check? blue92 S-Series Tech 3 11-16-2008 09:59 PM
Compression Check Ackpacket S-Series Tech 10 10-10-2008 03:26 AM
Compression Check Jenn07 S-Series Tech 1 05-05-2008 08:46 PM
Proper way to check oil? Blue Goose Vue General 3 12-06-2004 12:57 PM
