Old 03-15-2019, 02:37 PM   #1
ElysRealm
ElysRealm is on a distinguished road
Default SL1 99 - Installing AC on a Saturn that never had one.
So ya I'm in FL and I have a 99 SL1. It is from Maine and has no AC. It blows air and has heat. How much would it cost me to add in a remanufactured AC system?
Something like this or is it missing key parts?
https://www.ebay.com/itm/RYC-Remanuf...frcectupt=true
ElysRealm is offline   Reply With Quote
Old 03-15-2019, 03:18 PM   #2
Default Re: SL1 99 - Installing AC on a Saturn that never had one.
The compressor kit is only one part of the ac system. Did you consider all the wiring needed, including the hvac replacement control panel, wiring from it to the blower and pcm that controls when to power the compressor, compressor wiring to the pcm, wiring for the combination low/high pressure switch to the pcm? In addition to this, did you overlook tearing apart the interior to remove and replace or add the evaporator coil and the condenser coil with all hoses for the ac system? This wouldn't be considered an average diy project.
Perhaps examining a junk yard SL with ac may help you visualize how large this project is. The cabin hvac box holds a heater core and evaporator coil. The fittings thru the hvac box on the firewall holds the thermal expansion valve where the two ac hoses connect - one returning to the compressor (suction line/larger diameter hose), the smaller diameter hose goes to the filter/drier hung off the side of the condenser coil. One hose between compressor discharge port to the condenser coil.
Old 03-15-2019, 03:56 PM   #3
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Even if you did manage to install the parts in the A/C system, you wouldn't be able to use it. It would be like adding cruise control to a Saturn that didn't have it. You could install all the parts needed, but you'd still need a dealer or a GM tech 2 to enable the A/C option in the PCM.
97 SL2, auto, 123K miles
Old 03-15-2019, 04:08 PM   #4
^ Interesting point. If everything was installed correctly and a temporary setup were performed to bypass the hvac controls to power up the compressor with a full charge of refrigerant to ensure the ac system actually runs and cools, this allows a complete system test regardless of pcm interaction. The next step would be trying the hvac controls to turn on ac - the power on signal is passed to the pcm that sends a signal to the ac relay to power up the compressor. Presuming all hvac wiring is installed correctly, either the pcm turns on compressor operation or not. Again, presuming all associated wiring is in place, if the pcm must be enabled by GM, either pay GM to enable the pcm to control ac operation or find a used pcm from a car with ac.
There are many what ifs to consider when attempting to retrofit a non ac vehicle with ac............
Old 03-15-2019, 04:15 PM   #5
Well, that is an interesting question.
No idea how it actually works, but it is possible the signal through the PCM will be sent regardless of whether the PCM is coded for AC or not. Possibly the difference is that a PCM coded for AC would "notice" the signal pass-through and turn the fan on (if over ~40F) plus bump the idle speed a touch
I agree with what fdryer said, best bet is look for a complete SC1 with AC and pull what you need (and hope the parts work) . . . which might include PCM
The diagram in this thread is not for a Saturn but the layout of the AC parts is purty darn close - does not include the inerior parts you will need
http://www.saturnfans.com/forums/sho...d.php?t=207909
INstalling AC on a '99 Saturn SL xXPhasemanXx S-Series Mods 6 06-27-2015 11:40 PM
Installing a different Engine in my 2007 Saturn Vue Christian1242 Vue General 13 01-14-2015 11:46 PM
Installing Saturn Ion/Vue MP3 Radio How to ruley73 S-Series General 29 08-28-2013 03:07 PM
Need help in installing Remote starter kit in my Saturn SL-2 prabhakarglv S-Series Tech 29 12-07-2008 08:11 AM
Installing Saturn Logo Pedals thatjerryguy General Saturn Discussion 5 06-20-2003 07:41 PM
