Old 08-02-2018, 09:24 PM   #1
josefvs
josefvs is on a distinguished road
Default Low Beams not working, DRL and high beams do
First time posting. I have a 2000 Saturn L300. The headlights donít come on/are not discernible from the DRLs. I can only get high beams and daytime running lights. What are some of the reasons that could be causing it?
josefvs is offline   Reply With Quote
Old 08-02-2018, 11:24 PM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: Low Beams not working, DRL and high beams do
The daytime running lights and the high beams use the inside bulbs. The outer bulbs are the low beams on your car. When did this start, have they ever been right?
2002 L200/5 Loaded, over 1/4 million miles!
Old 08-03-2018, 04:00 PM   #3
If I'm not mistaken, '00 L300's use high beams for DRLs. Either both low beams are blown or there's a wiring issue.
Manually turn on headlights to force low beams on. What do you see?
Tags
drl, headlight, high beams, l300, low beams
2006 Saturn Ion 2 - High Beams Work, Low Beams Do Not. spacer7767 Ion General 4 10-31-2018 07:44 AM
High Beams indicator flickering, cutting DRLs, but no high beams andymcconnell L-Series Tech 6 10-04-2012 10:14 PM
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 12:06 PM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 05:10 PM
High Beams not working 94sl2guy S-Series Tech 3 02-02-2008 06:44 PM
