#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2011
I just bought the harbor freight compression tester and need to know the right way to check compression. I have never done it before and have the dreaded cyl 3 misfire. Thanks!
#2 |
To prevent washing the cylinders down with fuel remove the PCM B fuse to shut off the fuel pump, injectors, and ignition before starting the test. Remove all spark plugs and block the throttle open. Use a low charge rate battery charger to fully charge the battery before conducting the test.
Crank the engine until the gauge quits increasing and compare both the final pressure and number of compression strokes to reach the max pressure, cylinder to cylinder. You can do this test either cold or hot or warm just mention it when stating results. For example if you find all cylinders produce a final reading of 200psi but the compression cycles are as follows: 1-8, 2-6, 3-8, 4-14 then it should be obvious that cylinder #4 has a serious problem with leakage past either the valves or compression rings. FSM states the MINIMUM number of compression cycles is 10 and a Fully charged battery is required to obtain the full 250RPM cranking speed. Nominal compression for a high mileage good condition DOHC is 190-220psi and SOHC is 175-205psi. Do not screw it into the head past the point the sealing o-ring just contacts the head. Do not overtighten as it will leak. |
#3 |
Perfect! Thank you!
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2015
Facing west whilst slaughtering a goat is always helpful too....
Ya just can't be too thorough... ![]()
Currently owned 93 SC2 M(anual) 96 SC2 M 98 SL2 A(uto) 99 SC2 A 01 SC2 A 01 SC2 M 02 SC2 M 02 SL2 A 02 SL2 M parts 2 94 SC2 parted out 2 96 SC2 98 SC2 - rusty frame minus engine. 98 SL2 |
#5 |
![]() Join Date: Feb 2018
2001 SW2
thats only if your west of St Louis. Otherwise for proper compression test its facing North while slaughtering goats
#6 | |
![]() ![]() ![]() Join Date: Jan 2019
![]() Quote:
1/28/2019 2002 SL2 w 62k miles |
#7 | |
![]() Quote:
Pulled the PCM-B lots of times, never caused a code. Pulling the PCM-B will actually clear any stored codes.
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#8 |
Sorry, the question I actually meant to ask was: Will it set all readiness to "Incomplete"
#9 |
I believe it will - loses all memory of completing the readiness tests, so will set it back to "Incomplete", default fuel maps, default shift points for the auto trans, etc.
Don't have emissions testing here, so not something I ever thought about. Plus my normal commute cycle completes the tests pretty quickly, the times I checked with a reader
#10 |
YES IT WILL. You can attempt to disable fuel and spark independently of just pulling the PCM B fuse or you could try just pulling the PCM I as it should accomplish the same thing. Or you can move on down the tree of increasing potential mechanical damage and start pulling relays and random fuses.
Bookmarks |
Proper engine compression after lost oil? | luvme2tymes | S-Series Tech | 14 | 08-21-2009 08:42 PM |
What is the proper way to do a fuel pressure test? | groingo | S-Series General | 3 | 07-09-2009 12:20 PM |
compression test | sluketic | S-Series Tech | 3 | 07-07-2008 08:22 PM |
Compression test | junker | S-Series Tech | 3 | 02-21-2008 08:03 AM |
Detecting proper seating of new rings by compression check? | roswell998 | S-Series Tech | 4 | 10-29-2004 01:27 AM |
