Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay Tech
Old 02-27-2008, 02:27 PM   #1
wholesmith
wholesmith is on a distinguished road
Default Relay overhead console removal
The five buttons that are mounted in the overhead console on my 2005 Relay just pushed through into the console. I can't seem to figure out how to get the console off the rails so I can push the switches back into the hole it sits in or if there is another way to pull the switches back down into the hole.
thanks.
wholesmith is offline   Reply With Quote
Old 02-18-2011, 06:54 PM   #2
wizrules
wizrules is on a distinguished road
Wrench Re: Relay overhead console removal
I know it has been a long time since the original post but I needed to remove mine as well when we had the same thing happen to our 2005 Saturn Relay. I found that the clear plastic cover over the overhead map light/doorlight can be snapped off (from the center, bottom and top) and you will see a screw centered above the middle light(toward rear of vehicle). Remove that and the rear of the console will drop. The front of the console is snapped into place using two clips. Pulling straight down these will release and they can be re-snapped back when finished to put back up. I was able to push the button array back into place and tighten the single pressure clip in the front to prevent it from sliding out later. Snap the console back into place at the front, replace the single screw, and snap the plastic light cover back on. Hope this helps.
wizrules is offline   Reply With Quote
Overhead console in 1st gen SL. Any ideas? itsnotme1988 S-Series Mods 10 02-24-2009 10:20 AM
console lock removal? 96sc2pwr S-Series General 4 08-17-2008 08:36 PM
overhead handle removal saturnsctwo S-Series Tech 14 12-01-2007 12:02 AM
2005 L300 overhead console? Partymmudasti L-Series General 1 10-02-2007 10:27 PM
Overhead console mkapp S-Series Mods 2 05-24-2006 05:12 PM
