Old 04-27-2017, 11:25 AM   #1
TDA
TDA is on a distinguished road
2008 Astra XE
Default P0013 - Cam Position Sensor?
I have 2 codes on my car.
P0446 which is said to be Evap Control Solenoid related
P0013 - Camshaft sensor Bank 2. Which the parts store says is most likely the exhaust cam position sensor.
P0446 I'm not worried about. I had it cleared it and it hasn't came back. Sounds like the P0440 I got on my Saturn SL2 a couple times every spring and fall but never actually caused a problem. But, I will most likely try to fix it eventually.
P0013 sounds like something I should definitely fix. Looking up on AC-Delco.com it lists two different cam sensors. One it says there is two of on the car. The other says there is one. But, it doesn't give any indication which is the exhaust cam.
I found forums/showpost.php?p=2021551&postcount=26 (won't let me post the actual link) but I'm not understanding it. Could just be that it is still somewhat early and I didn't get enough sleep.
Have any of you had experience with this code?
Do you know which sensor is the right one?
I still need to find a manual for this thing so I'll be going in somewhat blind when it is time to replace it...
TDA is offline   Reply With Quote
Old 04-27-2017, 10:33 PM   #2
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
Default Re: P0013 - Cam Position Sensor?
I believe you are correct with bank 2 being the exhaust side. They are the easiest part to replace on our engines. Both sensors are located on the driver side of the engine and held in with one screw. I would replace the exhaust one first and if that doesn't fix the code just switch them around.
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Old 04-28-2017, 12:46 AM   #3
TDA
2008 Astra XE
Being VVT, I expected there to be two. But they are actually identical?
But yeah, ACDelco says the engine has 2 "25192205" "Engine Camshaft Position Sensor"
1 "55352609" "Camshaft Position Sensor"
and
1 "55555806" "Engine Crankshaft Position Sensor"
So... not sure exactly which one I'd be replacing. Guessing it would be the "25192205"
Old 04-29-2017, 04:27 PM   #4
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
25192205 is the one I replaced last summer, and cured my sluggish throttle response.
Old 05-31-2017, 08:26 PM   #5
TDA
2008 Astra XE
I've had the part for weeks but finally installed it last night.
Just to attempt to completely perform the process of elemination, I installed the new sensor in the intake position and the (no codes thrown so should be good) intake sensor in the exhaust sensor position.
Cleared the codes and the car felt more peppy.
Then... it threw the same exact code again. OpCom gives 2 more digits and a quick explanation.
P0013-04 Exhaust Camshaft Phasing Powerstage Circuit Open
Old 09-21-2020, 04:46 PM   #6
ProOpel
ProOpel is on a distinguished road
Do you know if part 2240050 is the same as part 55352609? Searching on ebay I get the same part, ie., they look exactly the same to me.
08' Astra XE 5dr
5 spd manual
team2fast 200 sportcat
Autolite XP5224 spark plugs
GM valve cover/PCV (55564395)
OPC body work (wip)
ProOpel is offline   Reply With Quote
Throttle Position Sensor rickb240 L-Series Tech 2 04-20-2016 09:36 AM
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
cam position sensor briansc1 S-Series Tech 5 09-09-2008 11:54 PM
Cam Position Sensor??? WEGoat Miscellaneous Tech 5 12-18-2004 10:13 PM
Cam Position Sensor??? WEGoat General Saturn Discussion 1 12-18-2004 02:35 PM
