Old 02-12-2019, 03:05 PM   #1
kylesn
kylesn is on a distinguished road
Dizzy 2007 saturn ion 2 speedometer/odometer issue
i just recently bought a 2007 saturn ion 2 with a 5 peed manual tranny
two days after i bought it i go to start it and the needle is tapping it taps for 4 or 5 seconds when started and when turned off but after that it works fine
also it had 64209 miles when i bought it the same day i had issues with the speedometer i noticed the odometer wasn't tracking the miles any more the trip is not working either
any ideas?? here is the video
youtube.com/watch?v=dWHKJjsuKcI[/url]
Add to kylesn's Reputation
Rate the quality of this post and help kylesn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kylesn is offline   Reply With Quote
Old 02-12-2019, 08:10 PM   #2
Default Re: 2007 saturn ion 2 speedometer/odometer issue
Under the fuel gauge is a symbol of the engine, the check engine indicator. Is it on after starting the engine? If on, an error code is stored. Autozone is one store offering free reading of error codes.
Old 02-12-2019, 09:26 PM   #3
kylesn
the check engine light goes off after its started
Old 02-12-2019, 11:58 PM   #4
If the car was bought from a dealer or used car lot, bring it back for repairs immediately. You should have some kind of warranty to insist that you didn't buy the car with a new problem. If bought privately, you can try appealing to the seller that a problem occurred soon after buying it and see if it can be repaired without cost.
The instrument panel may have been repaired, replaced, modified. The body control module drives the instrument panel.
Old 02-13-2019, 12:54 PM   #5
kylesn
the car was bout as is from a private seller i don't mind putting work into it cause i only paid 1900$ for it i just need to know if its something i can fix or if i need to take it to someone and have it fixed
Old 02-13-2019, 03:27 PM   #6
If you can remove the instrument panel, you can check for evidence of repairs; screws with paint removed as signs of someone removing hardware, wiring harnesses bent a certain way and seemingly out of place, modifications to wiring that appears out of place, etc. Disconnecting the i/p may reveal bent pins or pins pushed out and not level with others to indicate partial connection. That's about all a diyer can do unless you have advanced electronics knowledge and can read wiring schematics from service manuals. A subscription too alldata or Mitchell will give you online access to service manual info equal to factory manuals.
Speedometer/Cruise Control Issue, 2007 Vue 5spd chops Vue Tech 5 12-20-2013 07:18 PM
2002 Saturn Vue Speedometer issue x2006nzl Vue Tech 35 07-27-2013 05:30 PM
odometer/ speedometer issue pampas56 S-Series Tech 5 05-28-2012 06:16 PM
2000 Saturn Lw2 wagon speedometer/odometer issues JediMasterMatt L-Series Tech 14 11-27-2011 02:22 AM
help!! no speedometer or odometer !! samiam7156 L-Series Tech 4 05-22-2009 07:29 PM
