Old 02-12-2019, 07:55 PM   #1
joshjani
joshjani has a spectacular aura aboutjoshjani has a spectacular aura aboutjoshjani has a spectacular aura about
joshjani's Avatar
Default Water Leak in VUE- Likely culprit?
Lots of wintry mix rain in suburban Philadelphia today, and when I got in my 2005 VUE I was distressed to find quite a bit of water dripping from the front of the headliner. The passenger side pillar and roof upholstery was very wet, actually could see dripping water.
My first thought was clogged sunroof drains, but when I opened the sunroof the little moat redirecting the water seems fine. Just to be sure, I took a thin fiberglass wire and pushed it in and out of what I think are the drain holes.
I do notice that my top windshield seal seems brittle- not soft or rubbery as I'd expect, and there are two little notches broken out.
Additionally, I have a roof rack on the black plastic roof rails bolted to the roof. I have seen other SUVs- namely the Ford Escape- that have had issues where water got under the roof rack and rotted a hole.
These are all things I can check when the weather permits, and for right now I'm just trying to dry things out with a fan and heater.
Looking for anyone with experience with a roof/windshield/other leak and what was the culprit, what was the solution. Thanks for any advice!
Add to joshjani's Reputation
Rate the quality of this post and help joshjani reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joshjani is offline   Reply With Quote
Old 02-12-2019, 11:22 PM   #2
atikovi
Default Re: Water Leak in VUE- Likely culprit?
Check the rubber seals in the door opening.
Add to atikovi's Reputation
Old 02-13-2019, 11:47 AM   #3
homerec130
homerec130 is on a distinguished road
2008 VUE 3.6L
My 2006 had problems with leaks. We tracked the first set to the sunroof drains. We saw water in the leading edge of the headliner, the lights over the windshield and of course on the floor. In addition, the speedometer and tach didn't work as water had gotten into the electrics for the dash. That was supposedly fixed with clearing out the drains and replacing the seal around the sunroof. They also replaced the lights over the windshield.
Fast forward to last year, found the front foot wells full of water (shop vac'd about 5-6 gallons out). Water had come in through the sunroof drains again. When they opened up the A-pilars, it was discovered the drain lines did not go all the way to their exit points, so any water being drained went into the car instead of out the drains. This time we went with the draconian fix of disabling the sunroof and sealing it shut. We could count on one hand the number of times we opened it here in southern Arizona.
Windshield and roof rack are also good places to look. If your windshield has never been replaced then that may be the culprit. Mine never had a chance to dry out as my 2006 is on its 5th windshield. Glad we have full glass coverage.
Homer
Paul "Homer" Simpson
15 Ford Fiesta, Gray
06 Vue 3.5L, FWD, Storm Grey (Wife's Ride)
08 Vue 3.6L, FWD, Sunburst Orange - RIP 6T70
Add to homerec130's Reputation
Rate the quality of this post and help homerec130 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
homerec130 is offline   Reply With Quote
Roof Leak!! Roof Rack the culprit? tmckinn Outlook General 77 06-26-2013 01:39 PM
Water leak hydromech S-Series Tech 20 06-23-2011 01:07 PM
Think my cv joint is the culprit? pippo S-Series General 28 11-09-2009 12:01 AM
High idle at startup... most likely culprit?... Hackster S-Series Tech 4 07-21-2007 11:09 PM
water leak sinisa S-Series General 7 11-18-2005 03:42 PM
