#1 |
![]() ![]() ![]() ![]() Join Date: Feb 2015
2000 SL2
When I drive slowly I hear a slight grinding coming from my left front wheel. At faster speeds it turns into more of a "wirrrr." When I turn it will sometimes go away. Even sometimes when I drive straight the sound will not occur. However once I turn either way it will begin again.
I am unclear if it is the wheel bearing or the CV joint. As turning affects the sound I would lean towards CV but do not know. I have jacked it up and shaken the wheel and there does not appear to be any lateral play. Again leading me to the CV joint. But from the things I have read I am just unsure. Is there any more diagnoses I can do to narrow it down? Last edited by dylank; 04-01-2016 at 07:55 PM. Reason: spelling |
#2 |
In general, car cv joints use either several large steel balls in a ball/socket configuration or 'Y' type setup using three regular ball bearings allowed to slide in a sleeve to transfer engine torque to each tire. Google for images and how cvj's work. Normally long lasting and encased in a heavy duty rubber boot holding synthetic grease for lifetime reliability, a blown boot and spinning drive shaft throws grease everywhere. This leaves the bearings exposed to weather and eventually dry out causing corrosion and damage. Typical worn cvj's will make clicking sounds from each worn ball/socket or worn bearing/sleeve assembly as a car rolls forward or turned in a circle at low speed. Wheel bearings whirr quietly or loudly and are dual ball bearing arrangements for each wheel hub. Google for images. While one of the two ball bearings may wear out, the other bearing supports the weak one and doesn't let anyone know the bearing is worn out from side play. Others may add their comments.
#3 |
2000 SL2
Here is a video showing the sound
here is the link |
#4 |
I'm not an expert on noise but that sound from your video doesn't sound like cv joints.
#5 |
2000 SL2
Yeah I agree. From everything I've read and deduced it seems bearing. I've had CV joints go out in other cars and it was very different. I've turned the wheel all the way and made very slow circles in both directions and there is no signals of a CV joint going out. I am gonna buy a hub/bearing combo so I don't have to mess with pressing it. I'm gonna do it tomorrow so we'll see
#6 |
2000 SL2
Doing a bit more detective work I went to a parking lot. When I turn the wheel all the way to one side and move slowly there is no sound at all. This happens regardless which way I turn the wheel. My reasoning says that the further the wheel is turned the more the CV joint is used. So if it was indeed the CV joint this extreme turn test would seem to make it worse, right? If not, why does turning the wheel all the way eliminate the sound?
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
![]() Quote:
https://youtu.be/BQT6UunKTxw
1999 SL2 MT (311,300 km @ 01/2023) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: |
#8 |
2000 SL2
So I was successful!
I rented a 30mm socket from Advanced Auto parts as well as a set of tie rod pullers which came in very handy. I also had to use a C-clamp to hold the steering arm to the knuckle as the ball joint was just spinning as I attempted to tighten it. All and all it went pretty smooth. I was grateful for having an 19" breaker bar. Everything came apart easy. I then took the knuckle with the hub and bearing still pressed in over to Brakes Plus. They charged me $55 bucks to pull the old hub and bearing and press the new ones in. I was happy to pay it, not worth the trouble. As always thanks for all your help everyone |
Bookmarks |
Tags |
cv joint, cv joints, suspension, wheel bearing |
Wheel Bearing vs. CV Joint vs. ???? | nivlem7 | S-Series Tech | 25 | 08-02-2016 12:23 PM |
ball joint vs wheel bearing | fetchitfido | S-Series General | 6 | 11-21-2012 02:59 PM |
Wheel bearing, CV joint, or brakes | Ron2002SaturnSL | S-Series Tech | 10 | 11-03-2007 12:45 PM |
CV Joint and Wheel Bearing questions | batmobile | S-Series Tech | 3 | 12-08-2006 02:02 PM |
CV Joint or wheel bearing? | BahnBurnr | S-Series General | 5 | 11-09-2004 02:47 PM |
