![]() Join Date: Feb 2023
I want to get lowering springs for my car and also I was wondering if it is possible to add negative camber to my 2003 Saturn L-200 and how would I achieve that?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2015
2002 L-Series 3.0L Wagon
Lowering springs will not drop the car very much. The front is on the snubbers on hard bumps. The rear will come down quite a lot but the alignment is tricky. As the car comes down the wheels go negative camber a lot. The trick is to get the toe to come back in so you can drive it. Is there a reason you want negative camber other than looking like a Honda? I lowered the back of my car one coil and half the bump stops. I had to purchase adjustable lower arms and educate the alignment shop on how to align the car. I installed v-6 springs on the front to get the car to stop hitting the stops on rough roads. My car handles really well with the 16” Saab wheels. I am thinking about trying a set of Ion struts and springs to get the front lower. The Ion struts are a couple inches shorter than the L series struts and might use the same hub.
2002 LW 300 loaded, just rolled 100,000 miles, new timing belt and goodies 2002 L200/5 Loaded, 280k grandson’s car 2000 LS1, TMU love those bcm failures., grand daughter’s car |
Tags |
camber, camber adjust, lower, suspension |
Camber | tipiman | S-Series Mods | 4 | 09-28-2011 03:53 PM |
Need more camber! | MeSpdRacer | S-Series Mods | 6 | 08-25-2011 01:21 AM |
Camber | MikeNW | S-Series Tech | 5 | 10-01-2009 06:30 PM |
RL Camber??? | steviep831 | Vue Red Line | 11 | 02-05-2005 03:59 PM |
Camber Kit | sc288203 | Mods and Performance | 4 | 02-23-2003 08:37 AM |
