Old 08-11-2017, 11:25 PM   #1
senormark
senormark is on a distinguished road
Dizzy Question about strut on my saturn 1998 sc1 Please Help!!!!
Hi everyone I am new to this site I have been searching around for hours trying to figure out what my issue is and I finally decided to become a member and ask. So hear it goes I have been doing some front end work and checking on my 1998 Saturn sc1 and I just put new brakes on today and I checked all the other front end components and everything is very good tight except for one small thing. When I am driving and turn my wheel I can hear just a small noise coming from the left front side so I investigated further when I had the wheels off today for the break job I was turning the wheel and could not hear any noise. When I put everything back together I opened the drivers window and put my hand on the strut while I was turning the wheel so its just one spot when I turn over that spot there s the noise and I can feel the noise its up at the top of my strut it all appears to look fine so my question is does that sound like the top mount making the little noise? If so can I just replace the top mount? Is there anyway to tighten it to stop the noise? Any help would be greatly appreciated!!!! Also I was going to replace the top motor mount and from reading on this forum alot of people say the after market ones are no good can anyone give me a suggestion on what one to get I am trying to avoid putting a lot of money in the car it is really high in km but runs awesome and drives really good as well I like to do preventive maintenance and I am planning on taking it on a trip soon and want to make sure its safe to do so.. Any help is welcomed!!
senormark is offline   Reply With Quote
Old 08-12-2017, 11:15 PM   #2
Ricketts
Ricketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of light
2000 SC1
Default Re: Question about strut on my saturn 1998 sc1 Please Help!!!!
The top of the struts have a bearing plate that should be replaceable. My struts are going and my springs are shot, I'm getting a similar noise but I also feel a bind/pop sensation when turning a broad right corner, which I attribute to my worn spring and bearing plate. I ordered some quick struts and am hoping they take care of the issue.
If you are going to replace the top bearing plate you may as well just replace the whole assembly with a quick strut and get a new bearing plate that way, plus a new spring
OEM engine mounts are recommended, I tried a "frowny" mount and it was quiet but didn't last long. The solid upper mounts are better, but I find the aftermarket solid mount I have is very noisy, even more so in cold temps.
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Old 08-13-2017, 12:39 AM   #3
senormark
Ok thanks very much for reply
clunk, front end, noise, strut, suspension
BTSI question - 1998 Saturn SL2 jonp01 S-Series Tech 8 09-05-2013 11:03 PM
Help! Thermostat question 1998 Saturn SC tsalk221 S-Series Tech 8 08-09-2013 09:59 PM
98 Saturn Sl Quick Strut Question bd692000 S-Series General 5 04-13-2013 12:11 AM
98 Saturn SL1 , Another strut question jacklinane S-Series Tech 3 10-25-2010 07:48 PM
1998 saturn sl1 transmission question magnum2 S-Series Tech 4 03-29-2010 07:51 AM
