Old 08-27-2014, 09:24 PM   #1
Starty04ion
Starty04ion is on a distinguished road
2004 ION-3 Sedan
Question Any hints for this bumpy ride mystery?
ISSUE: Unidentified vibration/bumpy ride
// SYMPTOMS
  • Bumpy bouncy feeling in seat, seems like pass. side, changes with speed
  • Possible slight whirring sound, changes with speed, sounds like something that is spinning, could be a normal sound
  • NO other loud noises, clicking, squeaking, etc
  • Wheel does not seem to pull in any direction
// CONDITIONS
  • Experienced while coasting (most noticeable), accelerating and braking
  • Most noticeable/bouncy within 20mph to 30mph
  • Less noticeable at higher speeds, but still present
// PREVIOUS ACTION
  • Brakes done, including rotors (no change, needed to be done anyway)
  • Tires rotated and balanced (no change)
  • "Bounce Test" for shocks/struts (stood in then jumped out of the trunk, seemed ok...was entertaining. Ride is not bouncy in general)
  • Front and back bumper covers recently replaced
// SEEKING Advice!
Does this sound like anything familiar to you?
Anything else I can look for or do that could help me pinpoint this?
Would it have been obvious when balancing the tires if there was something wrong with one of them?
Wouldn't anything wrong in that area have been obvious when the brakes were done?
I was also rear-ended about a month ago, but neither the mechanic nor the collision place said anything looked wrong (apart from the bumper). Anything there?
Suggestions, similar experiences, commiseration, etc. welcome and appreciated.
Please help me help my Ion.
Starty04ion is offline   Reply With Quote
Old 08-28-2014, 12:48 AM   #2
ruley73
ruley73's Avatar
Default Re: Any hints for this bumpy ride mystery?
I still say bad shock & struts are to blame. I've found that the common bounce test as described and preformed by most people is irrelevant. The way I do the bounce test is to suddenly push down on the front radiator support or the rear bumper/trunk area. I feel that if you are able to increase the intensity of the bouncing when you reciprocate the recoil by pushing down again, the struts/shocks are bad and need to be replaced. Shocks/struts that are good go stiff almost right way if the front or rear is suddenly forced down and will not allow you to keep bouncing the car.
This video actually demonstrates what I mean very well. I will say that the bad shocks on the vehicle in the video appear to be a pretty extreme example though.
2007 Chevy Equinox LT 216K miles
2018 Chrysler Pacifica Touring L 100K miles
Old 08-28-2014, 01:35 AM   #3
Belac360
Belac360 is on a distinguished road
2003
Bad suspension will cause this whirring sound you are hearing. I'm getting the same sound on my car and mine need to be replaced. If you let it go long enough your tires will start to wear in a diagonal pattern on the tread.
Belac360 is offline   Reply With Quote
Old 09-02-2014, 12:14 AM   #4
Starty04ion
2004 ION-3 Sedan
Thank you for your responses!
Probably should have mentioned, my Ion has about 93,000 miles on it.
I recently got an inspection at the Dealer while they did my recall work and they listed front struts as a concern (said "worn, noisy"). I thought it was just the dealer doing the dealer upselling thing. I took it to my regular mechanic for the brake job and they didn't say anything about it. I also thought the overall ride would feel worse if it was shocks/struts; like when I go over a bump, it seems fine, not too bouncy.
I am going to bring it back to my mechanic and ask them to take a look. He originally said i had a stuck caliper or something and the brake job would fix the issue (didn't).
Driving it today with no music and the windows up helped me hear the sound better, and it is a bit like a quiet helicopter.
What do bad wheel bearings sound like on an Ion? I don't have any sounds apart from the whir.
The other items listed my the dealer were:
  • Leaking right front axle seal (my guy said it was a "seep" and is ok)
  • Worn front sway bar links
I didn't think those would be related to this though.
My top three contenders are now tires, wheel bearings, and struts.
Old 09-02-2014, 01:05 PM   #5
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
i like how you posted your information. should be a common format when it comes to troubleshooting issues lol
anyways, when you hit a large bump, is your car bouncing for the length of a city block? lol
as for the whirring noise, my thought would be wheel hubs, which have the bearings. they are pretty simple to remove.
swaybar endlinks may not be related to the issue, but still a good idea to change. moog products are pretty good.
03 ion-2 Sedan 5sp {sold at 280k miles}
97 f150 4.6 w/ manual and 4wd
94 Honda civic automatic "VTEC yo"
13 equinox LT 2.4
"A problem clearly stated, is a problem half solved."
kevin.st56 is offline   Reply With Quote
Old 09-02-2014, 03:48 PM   #6
Starty04ion
2004 ION-3 Sedan
I'm a graphic designer, so it comes by habit
The thing is the ride--even over bumps--ISN'T really bouncy, so that's why I wasn't sure about the struts thing. It's just the certain speeds (over flat roads) i get the bounce.
I didn't seem to have ALL the symptoms for any one problem (I thought wheel bearings were usually noisier than a whir).
Old 09-03-2014, 03:10 PM   #7
Starty04ion
2004 ION-3 Sedan
Wrench Re: Any hints for this bumpy ride mystery?
Sorry for the double reply, couldn't find how to edit the last one.
I'm sure I'll be back if the issue isn't resolved by this, but I HOPE it is. Really stupid that the guys at Discount Tire didn't notice anything, balanced them and sent me on my way. Over the phone the mechanic thought it sounded like wheel bearings but i guess they checked out
Belac and ruley are the current winners on this one!
In case anyone skims the thread looking for the solution...
ISSUE UPDATE
// DIAGNOSIS
  • Worn struts causing flat spots on the tires
  • Wheel bearings are OK
// ACTION
  • New struts and four new tires
  • Alignment (obviously)
Old 09-03-2014, 04:05 PM   #8
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
good to hear. i suggested wheel hubs, bec someone else had theirs changed bec there was whirring or humming noises coming from the wheels, and thats what gave me the thought. wheel hubs do usually last a long time on the ions, but you know how it goes. on rare occassions, things do go out prematurly.
13 equinox LT 2.4
alignment, suspension, tires, vibration
Strut recomendations/ touring ride/ -the aura ride Askspot Aura General 16 10-04-2013 09:09 AM
The bumpy road to newastra newastra Astra General 13 07-17-2008 10:06 AM
Too Bumpy OrphenOSX Ion Tech 10 06-06-2007 01:07 AM
Bumpy Road .. Is it just me?? ktravis Vue Red Line 8 03-02-2007 08:24 PM
Ride feels weird/bumpy IONizedinblack Ion General 9 07-08-2004 12:07 AM
