Old 04-06-2003, 01:46 AM   #1
Kaylas
Kaylas is on a distinguished road
Default Dome/Rear Interior Lamps. Where is fuse?
My dome light and my rear "reading" lamps are not working. Im pretty sure its a fuse but I cant find it anywhere.
Does anyone know where this fuse (or diode) is located?
*edit*
Its a 2000 L series.
Kaylas is offline
Old 04-06-2003, 02:37 AM   #2
Default
Check the owners manual for sure on the locations of the fuse panels. If memory serves correctly there are two inside the car, on the drivers and passengers outer kick panels. Then the one under the hood. The fuse for the dome lamps would likely be in one of the in car fuse panels. The manual will also say which fuse would be for the dome lamp. If you can't find the fuse then there may not be one. A lot the lighting on the L's can be controlled by the BCM and there may be a problem there. But the first thing to check for is definetely a fuse problem.
ssicarman is offline
Old 04-06-2003, 09:30 PM   #3
Kaylas
Default I looked in ALL the fuse boxes...
...and NOTHING says "dome", or "interior lights" or anything like that. Its the WIERDEST thing I have ever seen.
My Dome, Glove, Map, and reading lights are all out.
I thought maybe someone might have run into this before.
Kaylas is offline
Old 04-06-2003, 10:07 PM   #4
davidtroyer
davidtroyer is on a distinguished road
Default
Try the BCM fuse underhood. If you are standing on the driver's side looking at the fuse box it is the 15 amp in the upper right hand corner. I was having problems with my IP lights, pulled that one and it shut off all the interior lights. If not, there are maybe 5 or 6 fuses underhood that could be it.
davidtroyer is offline
2007 Dome Light (Switched Power Fuse) da_beaver Ion Tech 1 07-24-2009 12:35 AM
Dome Light Fuse HCSaturnGuy2 Ion Mods 1 05-06-2008 12:18 AM
Dome light fuse HCSaturnGuy2 Ion Tech 0 05-04-2008 04:45 PM
Dome Light Fuse shagdrum S-Series Tech 3 10-02-2006 04:25 PM
WTB: interior dome light, center reflector, stock fog lamps 97sc2 Classifieds 0 09-13-2004 01:07 AM
