Old 10-09-2008, 12:32 PM   #1
bone86daddy
bone86daddy is on a distinguished road
2002 SC1
Default dome light
so i was going to change my dome light and when i went to pop off the cover i popped out the entire thing and now i cant get it back up in there and stay in place. Can anyone help me out short of superglueing it to the header.
bone86daddy is offline   Reply With Quote
Old 10-09-2008, 01:30 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: dome light
did you break the tabs? There should be 2 curled tabs on one end of the dome light. It's a pain to put back in, but that's usually not an issue because the tabs break anyway. Heck, last time I was at the junkyard, I just plain cut the dome light out of the headliner with a knife, cutting a square out of the headliner, so I could get at the whole thing while trying to remove it. Still broke the tabs with full access to both sides of the dome light... it's just a bad design (which, sadly, they used in all the s-series). I'm still deciding how I want to re-hang my wife's dome light (mine was replaced by a console). I've heard of people using velcro and others using zip ties.
SaturnSeries.net owner
Old 10-09-2008, 01:48 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Removal and installation is easier and far less likely to break the tabs if you remove the clear lens first. That way you can see the tabs and know how much to bend then so you dont break them.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-09-2008, 01:52 PM   #4
bone86daddy
2002 SC1
i did break one of the tabs that your talking about when i was trying to get the cover off. and it figures i find your website purde with all your diy guides after i made this post.
Old 10-09-2008, 02:01 PM   #5
Cross piece and a couple of mini zip ties work well. You are right, its a disaster design.
Old 10-09-2008, 03:04 PM   #6
PurdueGuy
PurdueGuy's Avatar
1999 SC1
I'm thinking next time I'm at the junkyard, I'm just gonna hunt down a completely different dome light from a different car to make work. Anyone know how to take one out of an L-series? I glanced at one last time, didn't figure it out (didn't spend at lot of time at it, either).
Old 10-09-2008, 05:21 PM   #7
coupster
coupster is on a distinguished road
I tried velcro with no luck.
I drilled 2 holes in the side of the fixture on the side that had the broken tabs and inserted the ends of a u shaped piece of coathanger. Installation was to slide the coathanger u over the headliner and push the other end of the fixture up, so that the hook tabs grabbed the headliner. Hasn't fallen down yet.
coupster is offline   Reply With Quote
Old 10-10-2008, 07:31 AM   #8
bone86daddy
2002 SC1
while i had it off i took out the wiring and popped the lens cover off then took a wire tie, looped in up around where one of the tabs broke and its holding up fine
Old 10-10-2008, 11:16 PM   #9
DIYguy
DIYguy's Avatar
Happy Re: dome light
Mine self-destructed when I replaced the headliner. I tried velcro too. Doesn't stick in Summer heat. Then I tried a tie wrap. It just cracked the plastic of the light base and it rattled like mad.
I ended up drilling holes through the base of the housing and then marked the metal piece above it (part of the sunroof) through the new holes.
I drilled the metal piece at the marks using a scrap piece of 1/4" steel plate behind it so I wouldn't accidentally drill through the roof.
Once suitably drilled, I used a pair of short pan head screws inserted from the top side of the metal panel downward and some nuts. Now the body of the light fastens to the metal piece using some more nuts.
Hasn't rattled or dropped out of place yet.
One of these years I'll put a panel of white LEDs in it so it doesn't get hot when it's on. Probably be brighter anyway.
DIYguy
Quando Omni Flunkus Moritati
97SC2 Saturn (gone but never forgotten), Gen6 Camaro, Cruze Eco, Chevy SS P/U, Honda VT1100C, Honda CBX
Old 10-11-2008, 01:13 AM   #10
xtremeranger
xtremeranger is on a distinguished road
xtremeranger's Avatar
2005 VUE Red Line
2006 ION Red Line
I think a new one is like $35 from saturn...I broke mine and just bought a new one....
2005 VUE Red Line AWD - Tint, Audio, K&N
2006 ION Red Line Competition Package - Stage 2, strut bar, Hurst, Antenna delete, tinted corners, painted headlights
1998 SL2 - SOLD 87K-113K
xtremeranger is offline   Reply With Quote
Old 10-11-2008, 01:36 AM   #11
eBay is something like $8.00 or so for new old stock.
Old 10-12-2008, 05:32 PM   #12
t-daddy
t-daddy is on a distinguished road
Like they say.....Ebay. That's where I bought mine (2nd hand)
t-daddy is offline   Reply With Quote
Old 10-12-2008, 09:35 PM   #13
ajs_saturn
ajs_saturn will become famous soon enoughajs_saturn will become famous soon enough
ajs_saturn's Avatar
2001 SC1
supergluing to the header would melt the plastic in minutes
ebay man, the best thing ever
2001 SL1 5spd - DOHC swap and MS in the works
Bought 02/27/14
2000 SL 5spd
Bought 04/05/05
Sold 06/14/10
ajs_saturn is offline   Reply With Quote
Dome Light karinhesed86 S-Series General 9 04-24-2007 07:57 AM
Dome Light spachek Miscellaneous Tech 1 06-07-2004 08:15 AM
Dome Light Adman Classifieds 1 04-21-2002 08:51 PM
Help cant see...need dome light Sabrina General Saturn Discussion 8 01-21-2002 04:52 PM
Dome light dbaker Miscellaneous Tech 3 04-25-2000 07:27 PM
