Old 03-11-2012, 10:11 PM   #1
kevster0522
kevster0522 has a spectacular aura aboutkevster0522 has a spectacular aura about
kevster0522's Avatar
Default HVac Lights not working!
So I just installed a new car radio in my 95 sl1 and noticed that all the lights where the temperature and fan controls are are all burnt out. I checked the fuses that I thought related to those lights and they all were fine! I even put in the old radio to see if that would fix it but it didn't. Can someone please help me?
Add to kevster0522's Reputation
Rate the quality of this post and help kevster0522 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevster0522 is offline   Reply With Quote
Old 03-11-2012, 10:53 PM   #2
off-track
off-track's Avatar
Default Re: HVac Lights not working!
Did they work before? Pull the HVAC panel and check/replace the bulb.
I can only reference a Gen-II+ but, I'd expect it should be similar?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-11-2012, 11:08 PM   #3
kevster0522
Thanks for the quick reply
They defiantly worked before I installed the radio. I can't remember if they worked right after I installed it or if they stopped working today (I installed the radio yesturday).
Unfortunately I don't have any bulbs to test it with but I did put a volt tester (just two prongs with an led on the end) to the lights leads and I didn't get anything so I think they aren't getting power from somewhere or my volt tester isn't working. I also looked at the bulb and the filament doesn't look broken. I would also assume the 2nd gen would be close to the same.
Old 03-11-2012, 11:22 PM   #4
off-track
off-track's Avatar
Did you muck with the OEM wiring harness or just get the correct GM adapter for the aftermarket radio?
Added OEM CC
Old 03-11-2012, 11:42 PM   #5
kevster0522
I just got an adapter.
The kit I got was one on ebay. it came with the wiring harness, antenna adapter, and body kit.
Old 03-12-2012, 12:19 AM   #6
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Did you completely insulate the ends of the unused wires? It's very common to have a short that blows the fuse (10a under the hood), which will generally leave hvac, cluster, and rear driving lights out.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Rate the quality of this post and help PurdueGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 04:33 PM
A/C (HVAC) not working after BCM/PCM swap x-angel S-Series Tech 2 04-13-2008 09:46 PM
HVAC fan quit working wifes03ion Ion General 0 01-13-2007 02:06 PM
SC1 HVAC lights help!! ExcitedMoose S-Series Tech 0 06-12-2006 06:39 PM
IP, HVAC lights out David 93 SL2m S-Series Tech 21 06-09-2003 06:11 PM
