Old 11-15-2015, 11:39 PM   #1
jdbell2004
jdbell2004 has a spectacular aura aboutjdbell2004 has a spectacular aura about
Default Vue Green Line 4t45e Trans Shot????
My wife's vue seems to have lost all power to the wheels.
2008 Vue Green Line
140,000 miles
Last week, driving on the interstate with cruise, the RPMs surged and the vechicle began to decelerate. We had it towed home and the next day drove it around town. I noticed it would not shift out of gear under load, releasing the throttle it would shift into the next gear. Occasionally it would slip out of gear and the RPMs would surge until I released the throttle then slowly come down to under 3000rpm and slowly re-engage.
Took it to my company shop and poked around for a couple of hours, googling everything I could. Took her out for a run again. This time it refused to shift out of first gear. I could accelerate very very slowly until about 2-3000 rpm then it would gradually slip and the RMPs would surge freely.
I no longer have reverse, the "manual mode" does not work. Drive provides nearly zero forward acceleration, the engine seems to spin almost freely.
I have DTC code P1808 and the message "Service Hill Start Assist".
I have not yet checked the trans fluid level but with the mileage and lack of any service for almost 50k miles, I won't be surprised to find 4 gears sitting in a pile on the bottom of the pan.
Thoughts?
Add to jdbell2004's Reputation
Rate the quality of this post and help jdbell2004 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdbell2004 is offline   Reply With Quote
Old 11-16-2015, 12:19 AM   #2
Default Re: Vue Green Line 4t45e Trans Shot????
Check xmission fluid level first before condemning a ruined xmission.
Old 11-16-2015, 08:34 AM   #3
jdbell2004
Will do. Praying for the best.
Thanks!
Old 11-19-2015, 06:55 PM   #4
jdbell2004
Ok, pulled the pan. Fluid is burnt and full of the glittery guts of my transmission. I tried ordering a trans from RockAuto but they said the 4t45e they have on their site is not compatible with the hybrid. What transmission do I need?
Old 11-23-2015, 01:12 AM   #5
vasy
vasy is on a distinguished road
2007 VUE Green Line
PM PortugalFocus, he will help you out searching for a used one.
Add to vasy's Reputation
Rate the quality of this post and help vasy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vasy is offline   Reply With Quote
Old 11-25-2015, 02:04 PM   #6
jdbell2004
Thank you sir!
Old 11-25-2015, 02:31 PM   #7
PortugalFocus
PortugalFocus is just really nicePortugalFocus is just really nicePortugalFocus is just really nicePortugalFocus is just really nice
PortugalFocus's Avatar
Clearly sounds you've got FDBU in the transmission. (Fairy Dust Build Up) Usually cause by fairies partying hard inside your transmission, getting drunk and leaving a mess to clean up.
The 4T45E is the regular 5speed auto mated to the 2.4L motor, it's similar but it will with your vehicle. Technically it will bolt to your engine, but that's all about it will do, none of the connections are the same, axles, hybrid motor doesn't mount to it, etc.
I've already DM'ed you back.
Michelin LTX M/S2's // MOMO // Razzi Spoiler // Westin // Hella // K&N // Clear Corners
V6 Air Bag and Steering Wheel Swap
http://www.saturnfans.com/forums/showthread.php?t=155754
Add to PortugalFocus's Reputation
Rate the quality of this post and help PortugalFocus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PortugalFocus is offline   Reply With Quote
Old 11-26-2015, 09:35 PM   #8
jdbell2004
LOL FDBU love it!
What about rebuilding the trans? I suppose it depends on what needs replaced. I'm hoping to pull it out this weekend and having my mechanic dig into it a bit.
Old 12-02-2015, 04:49 PM   #9
jdbell2004
We're going to try a rebuild. Will the parts for a standard 4t45e work?
2008 VUE Red Line and Green Line Info and Photos Charlie 2008 Vue 26 12-15-2018 09:59 PM
Lower trans line removal, luckly the metal line didn't twist Jeeprz! S-Series Tech 4 01-23-2015 12:58 PM
trans swap VTI to 4T45E... do-able ? TylerLee Vue Tech 9 09-01-2011 11:24 PM
Can't decide between a Green Line and Red Line? tackepj Vue Green Line 0 03-15-2010 08:16 AM
Is the trans shot? 1995sl1sohc S-Series Tech 11 02-26-2009 04:24 PM
