Old 03-22-2020, 08:02 PM   #221
Waiex191
Waiex191's Avatar
Default Re: 98 SC2 project. Drive for now, maybe rebuild later.
We started swapping out the window motor. Adam took off the inner panel.
I got the outer.
Adam took the old motor apart in the name of science.
We drilled the rivets out and used AN4 aircraft bolts to put it back on. I cleaned the regulator with WD-40 and then greased it.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 03-25-2020, 11:45 PM   #222
Waiex191
Waiex191's Avatar
Originally Posted by ErikTande View Post
I love this thread, keep it up!
Let me know if you figure out a good way to fix the door panel clip, I broke one of mine too. Stupid plastic gets SUPER brittle after 20 years.
First I sanded the busted tab so there were no irregular lines.
Then I roughed up the inside of the doorskin with some 60 grit.
The form is a flat piece of metal with plastic tape on it for release.
I cut out small rectangles to build up to the thickness of the skin. The larger ones overlap to the bottom of the doorskin. Acetone was used to clean before bonding.
Resin mixed up.
Here is the layup. Curing now.
To be continued...
Bryan Cotton
Old 03-26-2020, 12:03 PM   #223
Waiex191
Waiex191's Avatar
I popped off the mold. I made a pattern from a neighboring tab.
I'm not sure I need the anti-rotation things on my new tab. The fiberglass is probably tougher than the plastic.
Bryan Cotton
Old 03-26-2020, 10:43 PM   #224
Waiex191
Waiex191's Avatar
I made a better tool for locating the hole.
The tab is slightly oversize. I put a notch in the end.
Bryan Cotton
Old 03-27-2020, 12:32 PM   #225
Waiex191
Waiex191's Avatar
One busted and one cracked tab on the front mounts.
Here was the layup. Note I just put two plies of glass behind the cracked one.
Form pulled off.
All the tabs are either cracked or will crack, in my opinion. So I am putting two plies of fiberglass behind all of them.
Bryan Cotton
Old 03-27-2020, 01:13 PM   #226
Waiex191
Waiex191's Avatar
Finished front mounts.
Need to reinforce the four rear mounts and I'm done.
Bryan Cotton
Old 03-27-2020, 04:17 PM   #227
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
Nice fix.
Mark_b is offline   Reply With Quote
Old 03-28-2020, 12:34 AM   #228
Waiex191
Waiex191's Avatar
Thanks Mark!
So my wife had me cover the inside of the garage door in reflectix last year. I had some left over. Also our dishwasher died and I saved the sound blanket.
After I cut these things to size and glued them together, I taped them onto the car.
Bryan Cotton
Old 03-28-2020, 08:01 PM   #229
Waiex191
Waiex191's Avatar
Somebody here mentioned the Home Depot 3/4" grommet as a door lock seal.
Bryan Cotton
Old 03-30-2020, 11:56 PM   #230
Waiex191
Waiex191's Avatar
I took the passenger side skin off also. The remains of the factory door seal were held on with grey duct tape.
The sound blanket looked really thin and powdery.
Most of it was white dust inside the door.
The tab fix also works on the passenger side.
Only one broken tab and a couple cracked ones. I glassed them all.
Bryan Cotton
Old 03-31-2020, 10:07 PM   #231
Waiex191
Waiex191's Avatar
This is disappointing - two of my tab reinforcements didn't bond well.
Bryan Cotton
Old 03-31-2020, 10:26 PM   #232
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
I have total trust that you will figure out a solution - even if you have to use your leather sewing machine to do so.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Singer Serger 1985 - 14U64A & 14U34B
Old 03-31-2020, 11:12 PM   #233
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
I have this post from cgg17 saved in case I need it when I finally go to remove my door panels. Maybe it will work for you as well.
http://www.saturnfans.com/forums/sho...d.php?t=234708
97 SL2, auto, 122K miles
Old 04-01-2020, 12:04 AM   #234
Waiex191
Waiex191's Avatar
Thanks Zeebins! I remember cgg17's post. In my case I think it was bad prep on those two tabs. Otherwise it has been awesome. I'm doing over the two tabs.
Tonight I cleaned out the inside of the door, cleaned and lubed the window tracks with dry silicone, cleaned the regulator sliders with WD-40 and greased them. I have another piece of reflectix cut out. Should be a lot quieter when I'm done. Also the passenger speaker had two loose screws, which explains the buzzing.
Bryan Cotton
Old 04-02-2020, 11:23 PM   #235
Waiex191
Waiex191's Avatar
One of my door panel hangers cracked.
Bryan Cotton
Old 04-04-2020, 04:43 PM   #236
Waiex191
Waiex191's Avatar
The inner door panel cracked on the rear edge where the plastic rivet goes. I made this 7075-T6 replacement.
In the background is the carbs from my kid's 1984 Honda V30 Magna. He replaced the o-rings for the carb bowls and now they don't leak anymore.
Bryan Cotton
Old 04-04-2020, 06:59 PM   #237
Waiex191
Waiex191's Avatar
I busted the dome light clips, as according to prophesy. Here I am repeating the fix that I did on the '99. A couple holes drilled through the two pieces.
Here it is screwed together and I'm pointing to the broken clip.
I took it for a spin, for the first time in a couple weeks. It sort of seems quieter with the redone doors, but I am also missing the headliner. Joann fabrics is closed so that project is on hold. I can definitely hear the front bearings now.
Bryan Cotton
Old 04-14-2020, 09:15 AM   #238
Waiex191
Waiex191's Avatar
I've now owned this $500 car for two years. Would like to start driving it again.
Bryan Cotton
Old 04-30-2020, 10:42 PM   #239
Waiex191
Waiex191's Avatar
I started redoing my headliner with a layer of felt.
Bryan Cotton
Old 05-01-2020, 12:44 AM   #240
Waiex191
Waiex191's Avatar
I'm on rattle patrol. I popped off the dash. Prior owner had busted the two clips behind the instruments. I'm thinking the easiest fix is to get a dash from LKQ. Will any Gen 2 fit? What about Gen 3?
This thing was torn and hanging down on the passenger side. Any advice?
Bryan Cotton
Summer Project:1.9 Engine Rebuild 1bignordic S-Series General 5 03-17-2014 02:29 PM
Rebuild VS Drive it as is VS sell it off OldSkewlSW1 S-Series General 11 03-09-2009 05:27 PM
Updated rebuild project hAnNibAl_H S-Series Mods 8 06-18-2007 12:17 AM
Current Project Towing New Project popp Vue Red Line 6 04-11-2006 12:55 AM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
