Old 06-30-2010, 02:40 PM   #21
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: Richpin's How To Videos Sticky
Updated Videos
Saturn s-series Fuel Pump Troubleshooting 2
http://www.youtube.com/watch?v=lqlBWRMwN_o
Door Window Glass Removal
http://www.youtube.com/watch?v=WMA7Obtwe0c
http://www.youtube.com/richpin06a
richpin06 is offline   Reply With Quote
Old 08-09-2010, 11:52 AM   #22
richpin06
richpin06's Avatar
New Videos
Trouble Code P0404 EGR Cleaning
http://www.youtube.com/watch?v=bt5lRTt6BsU
Automotive Ramp Extensions
http://www.youtube.com/watch?v=YFLtoA2Klks
Removing Self Retaining Air Duct Clamps
http://www.youtube.com/watch?v=dJ91oYavwy0
Radiator Replacement
http://www.youtube.com/watch?v=4nUyGjeLpVs
Updated Videos
Serpentine Belt Tensioner Removal
http://www.youtube.com/watch?v=Or0-0oG5Hsc
Old 10-14-2010, 03:01 PM   #23
richpin06
richpin06's Avatar
Updated Videos
Cleaning A/C Drain
http://www.youtube.com/watch?v=W0VdFRDdgvA
Door Lock Cylinder and Door Panel Removal
http://www.youtube.com/watch?v=BoxTGyVCXX8
Old 01-01-2011, 12:33 PM   #24
richpin06
richpin06's Avatar
New Videos
P0340 & P0341 Trouble Codes troubleshooting
http://www.youtube.com/watch?v=i_y-3fhAHZM
Automotive Cylinder Leak Down Tester,How To Build
http://www.youtube.com/watch?v=7UcOn8OEt0Y
Multifunction Switch Replacement
http://www.youtube.com/watch?v=pz3UIzmK7T8
Fuel Pump Troubleshooting (ground)
http://www.youtube.com/watch?v=uo5OeHcvk-0
Wiper Motor & Switch Troubleshooting
http://www.youtube.com/watch?v=0KHUxiXn31s
Old 03-12-2011, 07:36 PM   #25
richpin06
richpin06's Avatar
New Videos
Security Starter Relay System
http://www.youtube.com/watch?v=UfaOOAOXUHE
Exhaust Flex Pipe Replacement
http://www.youtube.com/watch?v=IZYcr50m750
Car Will Not Start
http://www.youtube.com/watch?v=Zjstj9kWos0
Clutch Interlock Switch Troubleshooting
http://www.youtube.com/watch?v=xsfuFcMqvjM
Homemade Air Conditioner Vacuum Pump
http://www.youtube.com/watch?v=DOq0Tr6QTa8
Windshield Washer Troubleshooting
http://www.youtube.com/watch?v=gRsOefRDaqs
Shifter Boot Replacement
http://www.youtube.com/watch?v=RP06_Ax38rE
Old 03-16-2011, 06:15 AM   #26
mjoekingz28
mjoekingz28 is on a distinguished road
Why are you deleting so many of the videos? Does youtube have a capacity?
mjoekingz28 is offline   Reply With Quote
Old 03-16-2011, 10:14 AM   #27
saturnsctwo
you tuibe doesn't even work for me anymore. i get sound & no picture. when i try to log in i get a screen asking me to join google & they will link both accounts. when i try to join google i get that dam code where you have to put it in to avoid spam & i never can read the code & then i can't log in. what a pain...
Old 04-25-2011, 09:06 AM   #28
richpin06
richpin06's Avatar
New Videos
2nt design Engine Mount Sag Measurement
http://youtu.be/U50UGSq_AVo
Windshield Wiper Motor Removal
http://youtu.be/KaKXFcDI2rU
Exhaust Hanger Removal
http://youtu.be/An1MPa2CwzY
Old 08-13-2011, 11:53 AM   #29
richpin06
richpin06's Avatar
New Videos
SW Rear Wiper Arm Removal
http://youtu.be/ssxYwo4Tx0U
Rear Door Glass Removal
http://youtu.be/-6cKbTwdFOg
Intermediate Axle Support Bearing Squeak
http://youtu.be/5wgyiAKv3HU
Three to Two Wire Horn Conversion
http://youtu.be/XZTPU8G5iM8
Old 08-13-2011, 05:35 PM   #30
paxman356
paxman356 is on a distinguished road
paxman356's Avatar
1997 SL1
2001 SW2
The blower motor removal is dead, and has an update:
http://www.youtube.com/watch?v=6mCop...el_video_title
2002 Saturn L200, I4, Auto with ~173,000. Bought 9/24/2013 with 156,107 miles for $2200.
1998 Toyota Camry with ~175,000. Bought 2/1/2015 with 173,523 miles for $1800
paxman356 is offline   Reply With Quote
Old 08-22-2011, 06:39 PM   #31
ehunter
ehunter has a spectacular aura aboutehunter has a spectacular aura about
Location: Pacifica by San Francisco – 5sp – Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
1996 SL2
Clutch: How to install the Throw Out bearing on a SL2 5-sp transmission:
http://www.youtube.com/watch?v=b817j8O12TA
ehunter is offline   Reply With Quote
Old 08-29-2011, 03:04 PM   #32
ehunter
1996 SL2
Engine rebuild videos for 96 DOHC
Starting from engine block bearings to crank caps. Part 1
http://www.youtube.com/watch?v=OmdoiynULhc
Installing crank caps and torquing Part 2
http://www.youtube.com/watch?v=qPOx5evoCAI
Rod to piston work Part 3
http://www.youtube.com/watch?v=wklAB5PKQO0
Installing rings on Pistons Part 4
http://www.youtube.com/watch?v=kYmkZNElrjU
Old 10-09-2011, 12:52 AM   #33
ehunter
1996 SL2
Installing the Rear Seal Carrier for 96SL2
http://www.youtube.com/watch?v=96nBoHWOzO4
Old 10-25-2011, 06:58 PM   #34
richpin06
richpin06's Avatar
New Videos
Fuel Gauge Troubleshooting
http://youtu.be/euIL8M2d2L0
Gas Gauge Reads Too Low
http://youtu.be/De0_O6QOgH4
Trouble Code P0717
http://youtu.be/Y-I7iw8km_c
Automatic Transmission Fluid Filter Change
http://youtu.be/vEimWgEb65c
Front Stabilizer Bar Replacement
http://youtu.be/MPr3QnbqMpY
Fuel Tank Strap Replacement
http://youtu.be/tgTIQL4H05A
Jack Stand Placement
http://youtu.be/82sT4tjXLNI
Bottom Dogbone Motor Mount Replacement
http://youtu.be/sRGBDRGA5t8
Old 03-04-2012, 04:53 PM   #35
richpin06
richpin06's Avatar
New Videos
How To Use A Multimeter
http://youtu.be/zb7WHaL_dz8
Brake Bleeder Removal
http://youtu.be/RMVV51gyoPU
Automotive Computer Radio Memory Saver
http://youtu.be/IXELDLBbmoU
Battery Load Tester
http://youtu.be/tVHlG9qgr8k
Head Gasket,Water Pump Replacement Part 1
http://youtu.be/yH0gHdnM1cE
Head Gasket,Water Pump Replacement Part 2
http://youtu.be/UHj4iHThY2k
Old 04-05-2012, 06:05 PM   #36
richpin06
richpin06's Avatar
New Videos
Locking Extension Bar
http://youtu.be/m0hWyk1hcGI
Copper Antiseize & Saturn Serpentine Belt Tool
http://youtu.be/n5ZgzTAoExM
Saturn Trunk Lock Cylinder Removal
http://youtu.be/unT-PhT6cig
Saturn Stick Shift Shifter Cable Bushing Replacement
http://youtu.be/AI3h7uSTvAI
Old 07-01-2012, 10:09 AM   #37
richpin06
richpin06's Avatar
New Videos
Steering Gear Removal and Replacement
http://youtu.be/1KMaV1kFdzk
Back Up Light Troubleshooting
http://youtu.be/tdRxwhjYjAY
Fuel Door Repair
http://youtu.be/2Y77nsmNxtc
Chime Module Replacement
http://youtu.be/-n4acS2DJkM
Engine Coolant Temperature Sensor Resistance Checking
http://youtu.be/wFHWpgHMAvY
Old 07-12-2012, 11:54 AM   #38
richpin06
richpin06's Avatar
Updated Videos
Ignition Lock Cylinder Replacement
http://youtu.be/Yt8wnj4qHoc
Throttle Position Sensor Replacement
http://youtu.be/Na6Hgu2qwLg
Power Steering Pump Replacement D.O.H.C.
http://youtu.be/OOz4MolBoGI
Old 07-26-2012, 11:05 AM   #39
vabadhog883
vabadhog883 is on a distinguished road
hey rich u are assome!! i have a problem with my instrument panel. last night my son turn the key to whine the windows up and left the key turned on and kill the batt. this morning i jumpped started it and now none of the gauges work,speed,tach,fuel,temp,none of the idot lights come on either. the only light that comes on isthe securety light then goes out like it supposed to. i checked the fuses all are good. so any idea of what i could do with out taking it to the dealer. there is no codes . i am stumped .please help
vabadhog883 is offline   Reply With Quote
Old 09-11-2012, 01:50 PM   #40
richpin06
richpin06's Avatar
New Videos
EVAP Purge Solenoid Testing
http://youtu.be/VmfiI1ribdM
Seat Repair
http://youtu.be/v2k8qPoB8cI
Ignition Lock Cylinder Cleaning
http://youtu.be/8iLPpXVElU0
Water Pump Pulley Bolts Torquing
http://youtu.be/o4EklQb6Bl4
watching Richpin's GPS video dorisSL S-Series Tech 5 01-29-2009 01:55 AM
richpin's video - battery hold down removal bez S-Series Tech 14 10-15-2008 11:51 AM
Videos of Astra!! alfkorda Astra General 5 12-18-2006 04:51 PM
0-60 videos golftango Ion General 31 10-07-2003 08:30 PM
Installation videos sc288203 Mods and Performance 6 05-06-2003 04:04 PM
