Old 08-16-2008, 09:33 AM   #1
1994Saturn
1994Saturn will become famous soon enough
1994Saturn's Avatar
1994 SL2
1994 SL1
Attention Richpin's How To Videos Sticky
THIS THREAD IS FOR REFERENCE ONLY! PLEASE DO NOT POST REPLIES OR COMMENTS WITHIN THIS TOPIC. THANKS!
Engine:
Engine Coolant Temperature Sensor Connector Replacement
http://www.youtube.com/watch?v=yQx84-93WkE
Removing Throttle Cable from Throttle Body
http://www.youtube.com/watch?v=LZ5cAVjjnWg
Water Pump Pulley Removal Without Impact Tools
http://www.youtube.com/watch?v=pRpG1BIVRcc
91-02 saturn alternator removal
http://www.youtube.com/watch?v=iogtiYraHCg
Saturn S-series starter replacement (updated)
http://www.youtube.com/watch?v=U6awyslXkeI
Good O2 Sensor Data (Real Time)
http://www.youtube.com/watch?v=ALrqogzVqR8
Saturn EVAP Solenoid Location
http://www.youtube.com/watch?v=jIKaPF2Yw3I
Front Oxygen Sensor Removal
http://www.youtube.com/watch?v=KDaKRRmASWA
Calibrated ignition spark
http://www.youtube.com/watch?v=9V2j6ArPcp4
96-up saturn DOHC coolent temp sensor location
http://www.youtube.com/watch?v=pUwCTJRqnAk
Saturn drivebelt tensioner removal
http://www.youtube.com/watch?v=REanRbFco4k
Saturn Tensioner Removal 2
http://www.youtube.com/watch?v=cU5lDkHsacM
Saturn S-series Thermostat R&R
http://www.youtube.com/watch?v=DrCSJpbDCiI
Saturn S-series Thermostat Replacement Walkthrough
http://www.youtube.com/watch?v=JEoLFrg8IUI
Engine Removal Saturn S-series (part 1)of 2
http://www.youtube.com/watch?v=GwoOXEX1jrE
Engine Removal Saturn S-series (part 2)of 2
http://www.youtube.com/watch?v=ta3e1c_KZL0
Checking Top Motor Mount(Second-design)
http://www.youtube.com/watch?v=WGIAt3nzs9Y
Saturn Top Motor Mount R&R
http://www.youtube.com/watch?v=zaugUfILmGE
Saturn Crankshaft Position Sensor(car not starting)
http://www.youtube.com/watch?v=pUMGFnK29B8
Saturn Crankshaft Position Sensor(car not starting)2
http://www.youtube.com/watch?v=Pv6wqQAmXvc
installing cruise control in 96-99 saturn s-series
http://www.youtube.com/watch?v=EEUgba5xxnA
Saturn Engine Cooling Fan Motor Removal
http://www.youtube.com/watch?v=J-FQjlPrqrc
Checking Saturn Coolent Fan 2
http://www.youtube.com/watch?v=X4pSWFE4kdQ
Saturn Idler Pulley Removal
http://www.youtube.com/watch?v=_n76-CqvJ2k
Bearing Race Removal
http://www.youtube.com/watch?v=eKNUMvT16lk
Saturn ignition coil and module removal
http://www.youtube.com/watch?v=8XgHM1i5jK8
Bench testing saturn coolant fan
http://www.youtube.com/watch?v=VnFFEFrlXlo
Saturn water pump access
http://www.youtube.com/watch?v=nRbUjGLviMY
Removing Saturn TPS (throttle position sensor)
http://www.youtube.com/watch?v=feJvmXY-je8
Replacing Saturn (CPS) Crankshaft Position Sensor
http://www.youtube.com/watch?v=PVTFFOwqNZM
Saturn S-series Power Steering Pump Removal
http://www.youtube.com/watch?v=ACKfwBBIM08
Saturn S-series Power Steering Pump Removal DOHC
http://www.youtube.com/watch?v=8pxK8fRsNMM
Throttle Body Cleaning (part 1)of 3
http://www.youtube.com/watch?v=ApNTQs6GzcY
Throttle Body Cleaning (part 2)of 3
http://www.youtube.com/watch?v=qT7yA2TL4lk
Throttle Body Cleaning (part 3)of 3
http://www.youtube.com/watch?v=u3dC0ZLvpt8
Engine Coolant Temperature Sensor R&R Saturn S-series
http://www.youtube.com/watch?v=JC0U53w_Htk
EVAP Purge Solenoid Removal Saturn S-series
http://www.youtube.com/watch?v=Xj605HENFno
Compression Check
http://www.youtube.com/watch?v=UdZHPa6fxjE
Saturn Crankshaft Position Sensor Location
http://www.youtube.com/watch?v=QKb_TTQo0J4
saturn pcv valve and grommet replacment 96-02 DOHC
http://www.youtube.com/watch?v=a-xIpNSADGM
Saturn EVO Solenoid Location
http://www.youtube.com/watch?v=eVNkBejm_Go
Saturn Serpentine Drivebelt R&R (3)
http://www.youtube.com/watch?v=BdhCzA0NcDQ
Knock Sensor Replacment
http://www.youtube.com/watch?v=dbYkkH7Dn-g
Computer Connector as Replacment ECTS Connector
http://www.youtube.com/watch?v=9ageV7g6eyw
DOHC Spark Plug R&R
http://www.youtube.com/watch?v=UqB2nq0V07c
EGR Passageway Length
http://www.youtube.com/watch?v=dJ_TkgjIW8U
Fuel Rail Removal 98-02 Saturn SOHC
http://www.youtube.com/watch?v=bwCxTs4riM8
In Car Alternator Testing
http://www.youtube.com/watch?v=g5B54xX_QVg
Saturn S-series Fuel Pump Troubleshooting 2
http://www.youtube.com/watch?v=HfHcU_JQzVs
Saturn S-series Oil Change Tip
http://www.youtube.com/watch?v=9dREDQKuV1Q
Saturn Fuel Pump Troubleshooting 1
http://www.youtube.com/watch?v=ODs5GMRI2Q0
Poor Man's Load Test (testing battery)
http://www.youtube.com/watch?v=viltQBg2jOQ
Checking Data Link 96-Up (OBD-2)
http://www.youtube.com/watch?v=26Nhf4K8ZOo
Panel Removal:
Rear Outer Door Panel Removal Saturn S-series
http://www.youtube.com/watch?v=whOOsv_EA8s
Saturn S-series (96-99)Front Fender Removal
http://www.youtube.com/watch?v=eZT_S4XtS9k
Saturn 96-99 Front Bumper Removal
http://www.youtube.com/watch?v=dcXOZFKPudY
Saturn 96-99 Quarter Panel Removal
http://www.youtube.com/watch?v=z_8wAvt7Bh8
Opening Saturn 96-99 Hood with Broken Cable
http://www.youtube.com/watch?v=KDPyIV9BwRU
HVAC:
Saturn S-series A/C Troubleshooting(part 1)of 2
http://www.youtube.com/watch?v=PMM80xlon3U
Saturn S-series A/C Troubleshooting(part 2)of 2
http://www.youtube.com/watch?v=T3o1l4r_ERE
A/C Checkup
http://www.youtube.com/watch?v=l5FibxcQTU4
saturn blower motor resister removal
http://www.youtube.com/watch?v=yLDnlQ6cAw0
Saturn S-series Air Conditioning Expansion Valve
http://www.youtube.com/watch?v=pfXKQ7gLKBQ
Saturn Recirculation Inlet
http://www.youtube.com/watch?v=T-iqiXw2klQ
Blower Motor Removal Saturn S-series
http://www.youtube.com/watch?v=5tTPJo7kl2s
Replacing temperature slider bulb and AC/REC button bulbs
http://www.youtube.com/watch?v=77kpne_BnRs
Checking For Debris At Evaporator Core
http://www.youtube.com/watch?v=dbGUmeVVL4A
Checking Blower Motor Amperage Draw
http://www.youtube.com/watch?v=lq2y5mWvEmg
Saturn Recirculation Damper Motor Removal
http://www.youtube.com/watch?v=tJZDy5Xr7dU
Checking A/C Pressures Saturn S-series
http://www.youtube.com/watch?v=Q__Jkv9BWu8
Cleaning A/C Drain
http://www.youtube.com/watch?v=hMxX16Q2edc
Interior:
Saturn S-series Cigarette Lighter R&R
http://www.youtube.com/watch?v=khTqYKWeLVY
Glove Box Removal 95-up Saturn S-series
http://www.youtube.com/watch?v=xWN3tplXr8U
Saturn S-series Inside Door Handle R&R
http://www.youtube.com/watch?v=q9AtNqxpK_E
Window Crank Handle Removal
http://www.youtube.com/watch?v=7YyktubQKwc
Saturn Center Mount Brake Light Cover Removal
http://www.youtube.com/watch?v=FS6HVSXzl6M
95-99 Saturn Center Vent Grill R&R
http://www.youtube.com/watch?v=6YV6q7xrUZY
Saturn 00-02 Instrument Cluster Removal
http://www.youtube.com/watch?v=5araI3Lu6OE
Saturn 95-99 Instrument Cluster Removal
http://www.youtube.com/watch?v=6jXiwgm3bPg
Saturn S-series Inner Door Panel Removal
http://www.youtube.com/watch?v=tF5vCjhcyd8
Saturn S-series Trunk Light Troubleshooting
http://www.youtube.com/watch?v=3ZXqkh9IZMM
Saturn S-series SL Front Seat Removal
http://www.youtube.com/watch?v=tkLs20SujyE
saturn RKE (remote keyless entry) receiver location
http://www.youtube.com/watch?v=eLf1cTmL1Wc
Assist Strap R&R
http://www.youtube.com/watch?v=0w1zaePzrHc
Door Check Link Replacment Saturn S-series
http://www.youtube.com/watch?v=XudcrrOFPbM
Access Rear Strut Nuts Saturn S-series
http://www.youtube.com/watch?v=M6eTTMyR4NU
Saturn Door Switch R&R
http://www.youtube.com/watch?v=22PvvjzsmQo
Seat Back R&R Saturn SL
http://www.youtube.com/watch?v=Rla0xitaOfk
Exterior:
Windshield Wiper Arm Repair
http://www.youtube.com/watch?v=b5mh-OrFdnc
Lubing Wiper Linkage Saturn S-series
http://www.youtube.com/watch?v=sNQC_24-Qvc
Adjusting Headlight Saturn S-series Gen 2
http://www.youtube.com/watch?v=j_08ZF89X2M
Disabling Saturn DRLs(for testing purposes)
http://www.youtube.com/watch?v=zVTyzmqQwBM
Saturn 96-02 Horn Removal
http://www.youtube.com/watch?v=ltiNuHdKeIg
Troubleshooting Saturn Gen 2 Horn
http://www.youtube.com/watch?v=WEMO0qARRec
jacking up saturn front end
http://www.youtube.com/watch?v=D1fTJ02Slos
SIDE-MARKER LAMPS SIGNALLING
http://www.youtube.com/watch?v=Iq_B5Uldzho
Door Window Glass Removal
http://www.youtube.com/watch?v=h1kaUA3U7u4
saturn 96-up door lock cylinder removal
http://www.youtube.com/watch?v=7G3PN6TYaJ4
Current:
1998 SL2 Auto issues 112K
1995 Eagle Vision 3.5L TSI 117K
Past:
98 SL1 254k miles Valves Burnt.
94 SL2 125K miles Diff Pin Blew!
94 SL1 Sold @134K.
1994Saturn is offline   Reply With Quote
Old 08-16-2008, 09:36 AM   #2
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Happy Re: Richpin's How To Videos Sticky
Transmission
Saturn clutch slave
http://www.youtube.com/watch?v=AtrTcX8wym
Saturn clutch fork travel
http://www.youtube.com/watch?v=099IRHql-qc
Saturn shifter sequence
http://www.youtube.com/watch?v=-GbBDRjVs7I
Saturn Transaxle Fluid Check and Fill
http://www.youtube.com/watch?v=lrbzSnUAgyk
Saturn differential pin inspection
http://www.youtube.com/watch?v=-gqhGC5vKDY
Saturn Vehicle Speed Sensor Location From Bottom
http://www.youtube.com/watch?v=h_bf_QitHGs
Saturn Transaxle Mount R&R
http://www.youtube.com/watch?v=5x1VMuWG5yw
Saturn S-series Automatic Transaxle Filter R&R
http://www.youtube.com/watch?v=Dfh9HGU3NXM
WHAT NOT TO DO.
Saturn Launching Diff Pin
http://www.youtube.com/watch?v=ITiUWTBuo9E
Brakes
Saturn rear brake job
http://www.youtube.com/watch?v=FpxQN2esZnU
Saturn front brake job
http://www.youtube.com/watch?v=xp36qmlGmGo
Parking Brake Lever C-clip Removal
http://www.youtube.com/watch?v=dTDBcmRkbhM
Checking Disc Brake Pad Thickness
http://www.youtube.com/watch?v=CFFd3TCxC80
Thanks Richpin for all the great videos. I can update as needed hopefully.
http://www.youtube.com/user/richpin06a
Current:
Past:
94 SL1 Sold @134K.
Old 08-19-2008, 02:25 AM   #3
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Suspension:
Inner Tie Rod End Removal Walkthrough
http://www.youtube.com/watch?v=Mk-toz8jsdI
Current:
Past:
94 SL1 Sold @134K.
Old 08-26-2008, 08:44 PM   #4
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Audio:
Saturn S-series Rear Speaker Connector Removal
http://www.youtube.com/watch?v=UzjygSKVyiY
Engine:
Saturn S-series Radiator Removal Walkthrough
http://www.youtube.com/watch?v=eSji7N5ommg
Current:
Past:
94 SL1 Sold @134K.
Old 08-26-2008, 09:59 PM   #5
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: Richpin's How To Videos Sticky
Brakes:
Has been deleted and replaced with this updated video.
http://www.youtube.com/watch?v=CsUn9m4Y4_0
http://www.youtube.com/richpin06a
richpin06 is offline   Reply With Quote
Old 09-03-2008, 03:09 PM   #6
richpin06
richpin06's Avatar
Body:
Saturn S-series Rear Bumper Fascia Removal
http://www.youtube.com/watch?v=c48vMhTK0_c
Ignition Lock Cylinder Removal Saturn S-series
http://www.youtube.com/watch?v=TJ6EJhuaT5s
Saturn S-series 00-02(Gen 3) Air Bag Removal
http://www.youtube.com/watch?v=7vMNiM_m-Ls
Old 09-16-2008, 10:45 AM   #7
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Interior.
Saturn S-series Dome Light Assembly Removal
http://www.youtube.com/watch?v=wv2CU9VAHFg
Engine:
Troubleshooting:Engine Rotates But Will Not Start
http://www.youtube.com/watch?v=fv3z6Jjbs1w
Hvac:
Testing Blower Motor Amperage and Voltage
http://www.youtube.com/watch?v=pK3dmfBjRI8
Brake:
Parking Brake Adjustment Saturn S-series 95-02
http://www.youtube.com/watch?v=NatVQFa5zdM
Electrical:
Remote Starter Switch
http://www.youtube.com/watch?v=xJz_EppuntA
Current:
Past:
94 SL1 Sold @134K.
Old 09-30-2008, 11:32 PM   #8
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Engine:
Tune-Up Saturn S-series Spark Plug Wire Removal
http://www.youtube.com/watch?v=Gq5hRTjll3E
Hvac:
Checking Heater Controls Saturn S-series
http://www.youtube.com/watch?v=MBucwjIcc3s
Current:
Past:
94 SL1 Sold @134K.
Old 10-08-2008, 10:41 AM   #9
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Brakes:
Bleeding Brakes With One-Person Brake Bleeder
http://www.youtube.com/watch?v=UvyztDFHhaY
Engine:
PO410 Secondary Air injection System Troubleshooting
http://www.youtube.com/watch?v=dIrmkxj6wJE
Engine:
Battery Hold Down Removal Saturn S-series
http://www.youtube.com/watch?v=8MUUY2EE38c
Audio:
Rear Speaker Removal Saturn SL
http://www.youtube.com/watch?v=x4mchytppo8
Current:
Past:
94 SL1 Sold @134K.
Old 10-26-2008, 08:29 PM   #10
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Suspension:
Replacing Lower Control Arm/Ball Joint Saturn S-series
http://www.youtube.com/watch?v=5PjkfDp8mLE
Engine:
Accelerator Cable Removal Saturn S-series
http://www.youtube.com/watch?v=yNccP9wou7U
Interior:
Saturn 91-94 Instrument Cluster Removal
http://www.youtube.com/watch?v=Nf65ON1CpEk
Interior:
Ignition Lock Cylinder Removal 00-02 Saturn S-series
http://www.youtube.com/watch?v=cown4CO2FJ0
Current:
Past:
94 SL1 Sold @134K.
Old 11-20-2008, 06:53 PM   #11
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Normal OBD 2 Data Saturn S-series
http://www.youtube.com/watch?v=XI4ZiOWX4C4
Current:
Past:
94 SL1 Sold @134K.
Old 01-03-2009, 01:41 PM   #12
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Interior
Installing GPS In Saturn S-series
http://www.youtube.com/watch?v=M_bgG...e=channel_page
Electrical
Programming Saturn RKE Module
http://www.youtube.com/watch?v=ac_lS...e=channel_page
Electrical.
Checking Production Date Automotive Battery
http://www.youtube.com/watch?v=j9lN_...e=channel_page
Engine
Saturn S-series Tensioner Removal 3
http://www.youtube.com/watch?v=6a3cm...e=channel_page
Manunal Transmission
Clutch Fluid Replacement Saturn S-series
http://www.youtube.com/watch?v=a-XhF...e=channel_page
Current:
Past:
94 SL1 Sold @134K.
Old 03-11-2009, 06:03 PM   #13
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Body
Fender Applique Removal Saturn S-series
http://www.youtube.com/watch?v=Vefd2...e=channel_page
Cooling system
Antifreeze/Coolant Checking With A Multimeter
Checking Saturn Coolant Level
http://www.youtube.com/watch?v=9i6Zz...e=channel_page
Interior
Gen 2
Console Removal Saturn S-series
http://www.youtube.com/watch?v=J4wby...e=channel_page
Steering Wheel Removal
http://www.youtube.com/watch?v=WcOI0...e=channel_page
Radio Removal 95-99 Saturn
http://www.youtube.com/watch?v=Xy2jY...e=channel_page
GM Service Wrench Light
http://www.youtube.com/watch?v=S8pvl...e=channel_page
Engine
Vacuum Leak Checking With Brake Or Choke Cleaner
http://www.youtube.com/watch?v=mYa8r...e=channel_page
Exhaust Gas Recirculation Valve (EGR) Checking
http://www.youtube.com/watch?v=8YRq2...e=channel_page
Must Have Tool For DOHC Engines Spark Plug Removal
http://www.youtube.com/watch?v=fuYkB...e=channel_page
1997 Saturn S- series No Start Problem
http://www.youtube.com/watch?v=Oriwt...e=channel_page
Transmission
Saturn Clutch Setup Walk Through
http://www.youtube.com/watch?v=js4gl...e=channel_page
Current:
Past:
94 SL1 Sold @134K.
Old 07-22-2009, 01:58 PM   #14
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Thumbs Up Re: Richpin's How To Videos Sticky
Engine/Electrical
Map Sensor Testing
http://www.youtube.com/watch?v=B8EVh...e=channel_page
Body/Electrical
Saturn S series Trailer Wire Hookup
http://www.youtube.com/watch?v=uU6fg...e=channel_page
Electrical
Trunk Overide Light Switch Saturn S series
http://www.youtube.com/watch?v=_drY0...e=channel_page
Cooling System
Coolant System Checking Saturn S-series
http://www.youtube.com/watch?v=YS8zG...e=channel_page
Suspension
Removing Rusted Control Arm Bolts Saturn S series
http://www.youtube.com/watch?v=RyId2...e=channel_page
Protection
Rustproofing Subframe Saturn S series
http://www.youtube.com/watch?v=CHJDS...e=channel_page
Current:
Past:
94 SL1 Sold @134K.
Old 08-27-2009, 09:50 AM   #15
richpin06
richpin06's Avatar
Body
Rear Inside Door Panel Removal
http://www.youtube.com/watch?v=7QbkO2LHW3k
Dash Pad Cover Repair
http://www.youtube.com/watch?v=5_RYhNW9R4o
Trunk Lid Applique Panel Removal
http://www.youtube.com/watch?v=zuqlfpFgObo
Door Check Link Troubleshooting
http://www.youtube.com/watch?v=-liOJa-nqbE
Windshield Washer Nozzle Replacement
http://www.youtube.com/watch?v=EQvuAXZZl_U
Parking Brake Handle Repair
http://www.youtube.com/watch?v=cCbsYlUoZE4
Chassis Electrical
Radio Bulb Replacement
http://www.youtube.com/watch?v=tWVja8RMbEA
Cooling System
Coolant Level Sensor Repair
http://www.youtube.com/watch?v=-5814yr2p_Y
Old 10-24-2009, 04:06 PM   #16
1994Saturn
1994Saturn's Avatar
1994 SL2
1994 SL1
Manual Trans
Clutch Fork Pedel Travel Saturn S series
http://www.youtube.com/user/richpin0.../1/ZL-FZ7bT4_A
Interior
Cruise Control Pedal Attachment Removal Saturn S series Gen 2 and 3
http://www.youtube.com/user/richpin0.../2/S-mpGDjmMLk
Gearshifter Knob Removal Saturn S series All years
http://www.youtube.com/user/richpin0.../3/xkCKZXG3-Us
Saturn Radio Bulb Replacement
http://www.youtube.com/user/richpin0.../9/tWVja8RMbEA
Suspension
Outer Tie Rod End Replacement
http://www.youtube.com/user/richpin0.../4/ZpI6J_97VCc
Current:
Past:
94 SL1 Sold @134K.
Old 12-11-2009, 07:42 PM   #17
richpin06
richpin06's Avatar
Updated Videos
http://www.youtube.com/watch?v=arv0hutlz0Y
Inner Wheel Bearing Race Removal
http://www.youtube.com/watch?v=iM7Eie6aRk4
Inner Tie Rod End Removal Walk-through
http://www.youtube.com/watch?v=jJpuz-gf9pA
http://www.youtube.com/watch?v=Pc5qCuQLmFE
Engine Coolant Temperature Sensor Remove and Replace
http://www.youtube.com/watch?v=cucm7QGlsYs
http://www.youtube.com/watch?v=ju7Znf3Z01A
New Videos
Heater Blower Motor Troubleshooting
http://www.youtube.com/watch?v=UJ-MfAo8AUQ
Headliner Removal
http://www.youtube.com/watch?v=RKN13KVfWaI
Old 03-15-2010, 06:40 PM   #18
saturnsctwo
Originally Posted by richpin06 View Post
Updated Videos
New Videos
Headliner Removal
i have a 2001 sc2. i need to get at those sunroof hoses that keep comming off & clamp them on. i think the rear hose come off & now i got a leak over my rear 3rd door. i understand how to remove the items i seen in this video, but on my headliner, i also got the controls that open the sunroof & those lights up front. how do they come off? is there any easy way to get at those rear hoses without totally removing the complete headliner?
Old 06-12-2010, 02:13 PM   #19
mjoekingz28
mjoekingz28 is on a distinguished road
Thanks RichPin!
At first I was worried because you had deleted the Alternator testing, but continued scrolling and it was revised further down
mjoekingz28 is offline   Reply With Quote
Old 06-25-2010, 02:32 PM   #20
richpin06
richpin06's Avatar
Updated Videos
Antifreeze Coolant Checking with a Multimeter
http://www.youtube.com/watch?v=mBXZtfzHhig
http://www.youtube.com/watch?v=S8sYR0r8PDQ
http://www.youtube.com/watch?v=mNZq6PuOi5c
http://www.youtube.com/watch?v=6mCopVB6Qt0
Adjusting Headlights
http://www.youtube.com/watch?v=0GdQ5YCCUaY
Checking Automotive A/C Pressures
http://www.youtube.com/watch?v=i9yv0euT7xA
watching Richpin's GPS video dorisSL S-Series Tech 5 01-29-2009 01:55 AM
richpin's video - battery hold down removal bez S-Series Tech 14 10-15-2008 11:51 AM
Videos of Astra!! alfkorda Astra General 5 12-18-2006 04:51 PM
0-60 videos golftango Ion General 31 10-07-2003 08:30 PM
Installation videos sc288203 Mods and Performance 6 05-06-2003 04:04 PM
