Old 05-01-2011, 05:37 PM   #21
mattachuz
mattachuz is on a distinguished road
mattachuz's Avatar
Default Re: Tail lights not working
Originally Posted by stoke21 View Post
Completely understand now. I appreciate the breakdown. Sorry if I was being a little 'slow' on that one. I'm competent (I promise). Thanks again. I'll give the new bulbs a try. If that doesn't work I'll check out the other 'brake' switch that was referenced. If that doesn't work, hopefully it's because of the BCM switchout about 12 months ago. Thanks again!
no problem lol, i was just thinking "really we went over this a few times already!" lol
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Anahiem (disneyland): xxx
Tulare: o,(x-atleast 15)
Visalia: x
Add to mattachuz's Reputation
Rate the quality of this post and help mattachuz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattachuz is offline   Reply With Quote
Old 05-02-2011, 12:23 AM   #22
stoke21
stoke21 will become famous soon enoughstoke21 will become famous soon enough
2004 L-Series 3.0L Sedan
So I almost feel stupid for making a thread for this. Ended up being the bulbs! I never would have thought that the two sides would go out at the same time, but I'm relieved to have the issue fixed for $6.42.
Had a rough week last week - here's to a better week this upcoming!
Thanks again for all of your help guys.
Add to stoke21's Reputation
Rate the quality of this post and help stoke21 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stoke21 is offline   Reply With Quote
Old 05-02-2011, 04:04 AM   #23
mattachuz
mattachuz's Avatar
heh had a feeling it was. glad that was it, lets focus on that dome light lol, bulbs by chance up there?
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Visalia: x
Old 05-03-2011, 01:26 PM   #24
stoke21
If my dome light, map (mirror) lights and trunk lights all were not working because of all bad bulbs.....I'd drive to California to deliver you a case of beer.
Truth be said, I pry won't even check it out. Our Saturn is still pretty reliable (knock on wood). It's a 100 mile/day round trip commuter from the city to the burbs and if it stays reliable for another 12 months, we'll probably retire it then. Not TOOO concerned about the courtesy lights.
Thanks again for the help. The easy/quick fix made my weekend.
Old 05-03-2011, 09:27 PM   #25
mattachuz
mattachuz's Avatar
no problem lol
please do knock on wood, i called mine reliable yesterday and the serpentine belt broke.
yea the map lights are nice but not as needed as brake lights. glad it all worked out for so cheap.
Matt
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Visalia: x
Old 11-02-2017, 11:44 PM   #26
fdorbinjr
fdorbinjr is on a distinguished road
I FOUND OUT WHY MINE STOPPED WORKING. sATURN L100 (2002).HOPE THIS HELPS SOMEONE BEFORE THEY GO NUTS BUYING FUSES AND BULBS..SATURN USES A CRAPPY THIN SHEET (REFLECTOR) AS A CONDUCTOR..IF YOU HOLD THE BRAKES TO LONG THE PLASTIC WELD THAT HOLD THAT SHEET (INSIDE THE LENSE)..THEY MELT..OVER TIME /BULB REMOVAL ETC..THAT SHEET GETS DEFORMED...WAT I DID WAS TAKE A HEATED NAIL AND POKED HOLES IN THE BULB HOUSING NEAR THE METAL CONNECTORS/CONTACTS THAT TOUCH THE BULB..STICK A WIRE TO THAT AND HARDWIRED TO THE MAIN ELECTRICAL FEED AND CUT THE FEED FROM GOING TO THAT THIN SHEET...BYPASS IT...IT TOOK ME ABOUT 2 HRS...SOLDER IF YOU CAN AND TAPE IT UP GOOD AND YOU SHOULD BE FINE...MIGHT WANT TO BUY SOME FUSES JUST IN CASE BEFORE YOU TRY IT. HA.
Add to fdorbinjr's Reputation
Rate the quality of this post and help fdorbinjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fdorbinjr is offline   Reply With Quote
Old 11-03-2017, 12:03 AM   #27
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
Saturn actually recalled these cars for taillight problems. I have the improved parts in both of my 2002 L200s. Any GM dealer should be able to supply you with the upgraded kits.
Add to 02 LW300's Reputation
02 LW300 is online now   Reply With Quote
Old 11-04-2017, 12:35 AM   #28
^That's exactly right. My tail light lens assemblies were replaced under the recall referred to above and I've had no problems with bulbs burning out prematurely. What I did discover early on was that the factory installed bulbs were themselves of a poor quality. After replacing all of the rear tail light bulbs and the center high mount bulbs - over the course of a few years - I found that the replacement bulbs were not burning out so rapidly. It was quite the opposite, the bulbs were lasting several years before needing replacement.
I get the impression, fdorbinjr, that the vehicle you're dealing with may not have been in your possession when the recall repairs were taking place at the Saturn dealerships. Is this correct?
BTW, it might be worth your while to contact GM.com and find out if there are any outstanding recalls on your car. You can do this quickly online via a chat session (check for hours of operation). Have the VIN with you when you do this as the agent will ask for it.
298,000 miles-it keeps on rolling!
Add to pierrot's Reputation
pierrot is online now   Reply With Quote
04 Vue, Dash Lights and Tail Lights Not Working 03zq8 Vue Tech 10 03-16-2018 01:57 PM
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 04:33 PM
HELP HELP HELP!!!! NO TAIL LIGHTS OR DASH LIGHTS..... PROBATION IN three HOURS!!! RBrown20 S-Series Tech 15 02-04-2009 05:04 PM
clear tail lights and black tail lights on ebay cheap ericblkredline Vue Mods 5 08-28-2008 03:08 PM
tail/stop/brake lights stop working? (QUICK FIX INSIDE) BLUEION2 Ion General 17 06-21-2004 08:04 PM
