Old 02-16-2017, 08:45 PM   #1
schleprock
schleprock is on a distinguished road
1996 SL1
Default overheating SL1
My car overheats. It is not losing engine coolant.
I had another problem, bad water pump that was leaking coolant, and while I was troubleshooting the overheating due to loss of coolant problem I was told that my heat sensor could be bad. I replaced the heat sensor. Also, I know that fan works.
Would a bad relay work when the engine gets super hot, nearly to the red on the indicator on the dashboard but not work at normal operating temperatures.
My car overheats when I am sitting in traffic and I never hear the fan come on. If I can get my vehicle above about 15mph it cools right down.
How do I know it comes on when it gets really hot? My Saturn always takes 5 or so miles of running to get the engine coolant to get rid of the air in the system. During this process I heard the fan come on, when I could see the indicator inside the cab was on red.
Could the relay only work when it is super hot. Or do they either work or not work. Or what might be happening here. In the summer this is going to become a big problem when I get stuck in traffic.
THanks
Add to schleprock's Reputation
Rate the quality of this post and help schleprock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
schleprock is offline   Reply With Quote
Old 02-17-2017, 07:47 AM   #2
underthehood
underthehood's Avatar
Default Re: overheating SL1
If you constantly get "air in the system" you need to have the cooling system sniff tested. Air pockets around the ECTS can cause the fan to malfunction. That being said I don't think I read what year car it is. If prior to 2001 (IIRC) it has the poorly designed resin tip sensor. The new sensor will be brass tipped. Once you have that in there, see how the engine/fan behaves. If it still does this try turning the AC on which will force the cooling fan to come on. If the engine cools down than it could be the relay. Don't rule out a bad fan motor though
Old 02-17-2017, 09:15 AM   #3
TXSaturn02
TXSaturn02's Avatar
Mid-year 2001. Hence, some 2001 models came with the brass tipped sensor and others did not.
New owner report of 07/25/18: 229,023 Miles
As of 07/25/18: 51,495 Miles
Old 02-17-2017, 10:08 AM   #4
BV22
2002 SC1
OP appears to have a 96 SL1 per profile. On a 96 model, the gauge will approach 3/4 scale before the fan kicks on. It should not go up to the red zone.
As stated above, if the car has functioning a/c, turning it on should result in the cooling fan running constantly. This is an easy way to check if the fan is working. It can also be used to cool the engine when sitting in traffic.
When you say heat sensor, do you mean engine coolant temperature sensor? If that has been replaced with a new one, the replacement was likely a brass tip version.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 02-17-2017, 04:17 PM   #5
schleprock
1996 SL1
It is a 1996 SL1. Sorry I forgot, that was a pretty stupid thing to leave out.
I will try the fan on the A/C and see what happens.
(last time we poked to probes into the wire and the fan turned on)
I only get air in the system when I change the coolant. For instance, when I changed the water pump the coolant came out. When I replaced that coolant it took a few miles to burp out the air bubbles.
The sensor was replaced and I am pretty sure it was the brass tipped one. I replaced it about 3 months ago.
Old 02-17-2017, 04:48 PM   #6
I gotta ask... If it isn't losing coolant, why do you think it is overheating? The dash gauge is far from being a precision instrument. Are you using live-data or an actual thermometer in the coolant? What actual temps (in F or C) are you reading?
Add to billr's Reputation
car overheating bigdoan1 S-Series Tech 5 06-19-2012 07:17 PM
Overheating wheatabix S-Series Tech 15 05-12-2012 02:51 PM
HELP PLEASE!!!! overheating CluelessSouth L-Series General 3 04-12-2012 11:13 PM
Overheating? sfrane S-Series General 15 08-28-2006 09:13 AM
97 SC1 overheating Inphenity S-Series General 28 01-18-2006 04:07 PM
