Old 10-26-2018, 04:29 PM   #1
Shive
Shive has a spectacular aura aboutShive has a spectacular aura aboutShive has a spectacular aura about
Shive's Avatar
2002 L-Series 2.2L Wagon
2003 L-Series 2.2L Wagon
Dizzy 2002 LW200 Gasoline Leak
Car has been smelling like gasoline leak. It's raining outside and I made a u-turn in parking lot and I could see gas in the water on the parking surface from under the car - between the tire tracks in the wet. Definitely coming from under my car. I have not checked where it is coming from yet. I will put it on a lift Monday morning.
Has anyone had to replace the fuel line? What about using Dorman Nylon fuel Line? Any more suggestions are appreciated.
Thanks
TJ
Add to Shive's Reputation
Rate the quality of this post and help Shive reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shive is offline   Reply With Quote
Old 10-26-2018, 05:12 PM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: 2002 LW200 Gasoline Leak
Check the fuel filter lines and filter under the car in front of the RR wheel.
If all looks good there, it's likely a leak at the fuel pump. The plastic fittings on the fuel pump crack very easily. Usually the return line for some reason. See if the tank appears to be wet on top.
Let us know what you find
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 10-26-2018, 09:18 PM   #3
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
2002 L-Series 2.2L Sedan
At least the L series cars have plastic fuel lines. The Ions have steel lines and they rust through. Didnít you cut a hole under the back seat and replace your pump a while back? Iíd look there first and see if it is wet with fuel.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 10-27-2018, 01:36 PM   #4
Shive
Shive's Avatar
No. Not on my 2002. I cut the hole & replaced the fuel pump on my 2003. The 2003 LW200 is still doing OK. It's my 2002 that has the fuel leak.
Thanks
TJ
Old 11-13-2018, 11:18 AM   #5
claybear
claybear will become famous soon enough
Probably the fuel pump. That is why I'm doing so much work on our LW200. If the car is sitting on level ground and the engine is running and you see fuel dripping from the area in front of the rear passenger tire then it is the fuel pump and probably one or both of the inlet/outlet tubes has cracked. The fuel finds its way down the path where the fuel line is clipped into the tank and finally drips off either the fuel filter or fuel line. Most likely the fuel lines will be ok. I dropped the tank in my car with only a few broken studs. Exhaust, exhaust shields, rear stabilizer bar, fuel filler neck assembly (could also be a source of fumes- mine was rusted through), electrical connections all must come off. Then, if you are lucky, the brakes lines won't be totally rusted through like mine. Oh, and also, the shield that protects the tank disintegrates in northern climates where salt is used on the road. I found a good one in a TN salvage yard. I have another post going chronicling my saga. Once the car is back together I will feel much better about my daughter driving it.
And, I just thought of this. Could you do me a favor and take a picture of your 2002 ABS pump/valve top and trace the two lines to the firewall connections and to the back of the car? Two of those lines run to the firewall where there are connections to the two lines running underneath the car to the rear. I removed my lines without marking which went where and I can't tell from looking at the ABS module how the lines are paired. I know that the driver's side front and passenger side rear brakes are supposed to be connected and vise versa. Many thanks if you could do this. We have friends with a VUE and I was hoping that the ABS pump in that car was the same as the L-series but I haven't been able to take a look yet.
Add to claybear's Reputation
Rate the quality of this post and help claybear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
claybear is offline   Reply With Quote
2002 Saturn LW200 LegendaryLW200 L-Series Tech 12 03-02-2015 01:26 PM
2002 lw200 vikings General Saturn Discussion 0 06-02-2014 09:55 PM
gasoline smell/leak DonFelts S-Series General 21 05-28-2013 09:41 PM
2002 LW200 AC Condenser sstar L-Series Tech 6 05-15-2013 07:05 PM
2002 LW200. Is anyone using Hydrogen on it??? dbhobby L-Series General 5 08-14-2008 09:29 PM
