Old 06-05-2018, 10:59 PM   #221
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Default Re: Saturn Wagon CraigsList Ad's Thread
Has anyone ever wanted to cut off the back half of their Saturn and turn it into a pick up truck? No? Yeah me neither, but apparently this guy wanted to. https://www.facebook.com/marketplace...54396024848032
Saturn sl2 wagon, converted into a pickup. (UTE). 16 Valve twin cam motor and five speed transmission, both strong. Runs and drives, will have a brand new starter installed I'm the next few days. Windows, radio, Ac and heat all work. All headlights and tail lights work. Decent tires. Super fun to rip around in. I still have the back hatch if it is wanted. $500 or best offer. Come get it asap
EDIT: I thought I was putting this in the bonehead finds but must have accidentally opened the wagon finds thread, it still works though since it technically is a SW (I think)
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Old 06-06-2018, 08:33 PM   #222
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
It is nearby. However I wouldnít seriously consider it for anything but a parts car. Iím sure itís probably already sagging since much of itís structure has been cut away and the scraping sound from the middle of itís underbelly on the drive home would drown out the radio.
Donít you dare open one of the rear doors. As if you could.
Itís missing a lug nut in the photo. Thatís a deal breaker.
ē 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
ē 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
ē 1994 SL1 new traded
ē 1992 SL2 new traded for above
Add to dummo's Reputation
Old 06-07-2018, 11:47 PM   #223
Zeebins
Zeebins's Avatar
94 SW2 with only 20,000 miles on it
https://www.facebook.com/marketplace...36423553265167
Checkout this great find. A beautiful 1994 Saturn SW2 wagon. Finished in plum metallic with gray premium cloth interior. Would you believe this little Saturn has only 20K miles. Amazing. The exterior is super clean. Still retains it's original paint. The interior is like new. even smells new. This one is pretty well equipped too. Automatic and front wheel drive. Has the economical four cylinder. These cars are amazing on gas. This car is so cool and unique. Get a gas saver and a head turner with this one. Don't miss this one. Offered at $3995
Old 09-03-2018, 08:05 PM   #224
https://madison.craigslist.org/cto/d...688030101.html
1999 Saturn S Series SW2 Wagon 4D 1.9L - $500 (Madison, WI)
Engine is in good condition. Good torque. Possible u-joint needing replacement. Slow leak on rear tire. Parts car.
odometer: 363180. Has droop roof.
Add to Waiex191's Reputation
Old 09-04-2018, 08:49 AM   #225
onlinebiker
Whatsa droop roof?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 09-04-2018, 08:55 AM   #226
onlinebiker
It could be done. Best way I looked at the idea (an sc2 convertible) would be to stiffen the underbody along the two " boxes" that run from just aft of he subframe to the floor doubling under the back seat.
I think that a piece of .093 flat stock welded alongside the vertical section on both sides would do the trick.
Just good luck scraping off all the damned undercoating to get a good weld.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 09-04-2018, 11:11 AM   #227
Originally Posted by onlinebiker View Post
Whatsa droop roof?
South Carolina term for sagging headliner. At least that is what a South Carolina friend from college called it.
Edit: correction, my friend was from Hickory, NC.
Old 09-04-2018, 05:31 PM   #228
onlinebiker
Ahhhhh...
Yup pretty common - especially when the owner smokes and parks outside in the sun.
Easily fixed. 3M spray adhesive and 6 Buicks worth of material from Walmart.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 09-04-2018, 06:58 PM   #229
My '99 had it. I'm a nonsmoker and the car has always been garaged. We redid that headliner, but it took way less than 6 Buicks worth though!
Old 09-24-2018, 10:10 PM   #230
Zeebins
Zeebins's Avatar
Got a 2 for 1 deal today, a 95 SW1 and a 97SW2. $900 to buy both of them. https://fargo.craigslist.org/cto/d/s...704070672.html
Old 09-25-2018, 09:30 AM   #231
onlinebiker
Lol. Stupid autocorrect.
Bucks, not Buicks.
My dad does Buicks - not me.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-09-2018, 08:11 AM   #232
TvSteve
TvSteve is on a distinguished road
TvSteve's Avatar
1999 SW2
https://nwct.craigslist.org/cto/d/sa...696168523.html
Well-maintained Saturn wagon. Muffler, battery, shoes, rotors and pads all changed within last 10,000 miles. Cooper tires with lots of tread left. A compact wagon that's great on gas. Seats fold down for easy storage.
Listed over a month ago, no pw or door locks. Worth the money?
Add to TvSteve's Reputation
Rate the quality of this post and help TvSteve reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TvSteve is online now   Reply With Quote
Old 10-09-2018, 08:33 AM   #233
trottida
trottida's Avatar
Given the condition I'd be tempted at that price. Looks in pretty good shape with minimal rust for its age.
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-09-2018, 01:02 PM   #234
onlinebiker
The underbody condition is critical to it' s worth.
They can look great, but be so rusted out underneath as to make it un- drivable.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-09-2018, 09:40 PM   #235
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
https://frederick.craigslist.org/cto...719195564.html
I am going to kick myself for posting it.... I really want to buy it but couldnt part with my 95... and cant afford both.
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Old 11-08-2018, 12:18 AM   #236
Gen1 wagon, 90K miles, one owner, $1000
https://madison.craigslist.org/cto/d...742952833.html
Old 11-09-2018, 03:13 PM   #237
TomM96
i put up a thread for a car selling on Ebay:
1999 SW2 36kMi NYC $2500 Ebay
Add to TomM96's Reputation
Old 11-11-2018, 10:36 PM   #238
cgg17
cgg17's Avatar
https://www.facebook.com/marketplace...30752051035893
Old 11-14-2018, 01:13 AM   #239
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1997 SL1
If only this wasn't an automatic... Still kinda want it.
https://bend.craigslist.org/cto/d/19...736414227.html
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
1994 SL2 - Nelly Belle
Current:
1997 SL1 - Cinnamon - 285K
1996 SL2 - Blanca - 36K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Old 12-18-2018, 02:34 AM   #240
Zeebins
Zeebins's Avatar
95, SW2, 5 speed, 131K, $1500
https://maine.craigslist.org/cto/d/p...764706936.html
RHD wagon on craigslist dcc81187 S-Series General 19 12-08-2011 12:36 AM
Nice looking WAGON on craigslist - florida kitkatbahr S-Series General 2 01-18-2010 05:23 PM
'95 wagon on Craigslist cola S-Series General 3 05-29-2009 12:58 PM
Assorted vids/ad's WillyYoungblood Ion General 0 05-05-2006 02:18 PM
New wagon thread cityhawk General Saturn Discussion 148 12-21-2001 05:54 PM
