Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 04-13-2006, 09:19 PM   #1
phool
phool is on a distinguished road
Default Removing the key from the ignition
I discovered on accident the other day that I can remove my key from the ignition while it is in any position. Does anybody else have this "problem" ?
As a test, I tried turning the key to lock and removing it, and then attempting to start the car with a screwdriver, which didn't work, so for now it seems it's at least still safe.
Add to phool's Reputation
Rate the quality of this post and help phool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phool is offline   Reply With Quote
Old 04-14-2006, 01:16 AM   #2
xxmurrxx
xxmurrxx is on a distinguished road
Default Re: Removing the key from the ignition
Same thing happens with my car, not a redline though, sc2000.
No clue why.
Add to xxmurrxx's Reputation
Rate the quality of this post and help xxmurrxx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xxmurrxx is offline   Reply With Quote
Old 04-28-2006, 11:56 PM   #3
swoker183
swoker183 is on a distinguished road
2006 ION Red Line
it could be either because the "cut" of your key is too smooth or because there is a problem with the tumbler
Add to swoker183's Reputation
Rate the quality of this post and help swoker183 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swoker183 is offline   Reply With Quote
Old 04-29-2006, 03:22 PM   #4
spartsguy29
spartsguy29 is on a distinguished road
spartsguy29's Avatar
2006 ION-3 Sedan
Might be covered under warranty. How many miles? We replace ignition lock cylinders up here all the time in the L car and Ions. I actually stock 5 lock cylinder kits for the Ion.
You get what you pay for. This applies in all aspects of life, like it or not.
Add to spartsguy29's Reputation
Rate the quality of this post and help spartsguy29 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spartsguy29 is offline   Reply With Quote
Old 05-02-2006, 08:46 AM   #5
mytdawg
mytdawg is on a distinguished road
mytdawg's Avatar
2004 ION Red Line
Most of my older cars do the same thing due to being worn. It's never caused any problems. It's actually come in handy a couple times. Don't have to listen to that infernal buzzer/bell while it's running and the door is open.
Add to mytdawg's Reputation
Rate the quality of this post and help mytdawg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mytdawg is offline   Reply With Quote
Old 05-02-2006, 09:09 AM   #6
Eco-Mod
Eco-Mod is on a distinguished road
2006 ION Red Line
2007 SKY
In most cases it is due to a worn key. Try using a spare key, or get one cut at your dealer (maybe $5), and try it again. If it still does it, it's a problem with the lock cylinder.
'06 Ion RedLine
Red Comp. Pkg.
Too Many Mods To List!
260+ whp 240+ wtq
'03 Ion 3 (Retired)
Add to Eco-Mod's Reputation
Rate the quality of this post and help Eco-Mod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eco-Mod is offline   Reply With Quote
How to remove ignition key cylinder with broken key in the cylinder, L-series? dejavu48 L-Series Tech 0 11-15-2008 12:46 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 02:09 AM
Spare key gets stuck in ignition, main key doesn't 94sc293sl1 S-Series Tech 7 07-12-2004 01:03 AM
Key stuck, very hard to remove key from ignition... Actaeon S-Series Tech 7 12-21-2003 01:08 AM
Removing key rings around key hole? cleansl2 Miscellaneous Tech 5 11-25-2003 10:06 PM
