Old 04-10-2007, 09:53 PM   #1
Ryan from Ohio
Ryan from Ohio is on a distinguished road
Default Manual Trans disassembly replacement
Long story short, being stupid I split the transmission when it was unnecessary. When putting it back together, I broke an ear off the case. So I tore it down to have it heli-arc'ed back up.
So its all tore apart.
Any preventive maintenance tips or things I should do?
Ive heard about the differential pin. I think I will have that welded up solid also.
Add to Ryan from Ohio's Reputation
Rate the quality of this post and help Ryan from Ohio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ryan from Ohio is offline   Reply With Quote
Old 04-10-2007, 10:01 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Manual Trans disassembly replacement
You answered your own question.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 04-10-2007, 10:24 PM   #3
Ryan from Ohio
Is that different racing site yours? If so a big thumbs up to ya.
Ya I figured that pic was a hard hitter. I wasnt sure if any of the seals should be replaced or dont bother? Anything else I should look for. bearings prone to failure?
I do see it utilizes NSK bearings. So i feel a bit better about it
The trans has 207K on it. The magnet had a layer of steel grit on it. I wiped her off. Honestly for that many miles, seemed clean. But then again, its the only trans Ive had apart
Old 04-10-2007, 11:04 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
while you've got it open, you can check bearings for any play, and replace any that have play in them.
Add to PurdueGuy's Reputation
Old 04-10-2007, 11:18 PM   #5
starhustler
starhustler is on a distinguished road
starhustler's Avatar
1993 SL2
some folks seem to be having problems with the inputshaft seal(quill bearing) i had that problem with my 93 SL2 and requires breaking open the tranny case if it goes bad ----course mine had a few miles on it 215k
Add to starhustler's Reputation
Rate the quality of this post and help starhustler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
starhustler is offline   Reply With Quote
Old 04-11-2007, 12:29 AM   #6
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Mine went bad (146k miles) and i beat it out myself, and installed it myself. You gotta have a small hand-sledge hammer though
My magnet had grease on it... took about 5 minutes to get all of the stuff off.
And if you want to replace all the seals and *****, get the transmission gasket kit p/n 21005868. It has everything.... input/output shaft nuts, bushings, gaskets, filters, shift pads, axle seals, basically everything you need.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 04-11-2007, 10:12 AM   #7
S3aturnR
S3aturnR's Avatar
1999 SL1
i would consider that a "must have" item when you crack open the case...
s3aturnr
Add to S3aturnR's Reputation
Old 04-11-2007, 07:58 PM   #8
Ryan from Ohio
Well the seals Im most concerned about is the input from the motor, then the outputs to the wheels.
The wheels are only $6 each so im gonna get them. now I need the one from the motor...
Old 04-17-2007, 09:49 PM   #9
Ryan from Ohio
One quick question.
The differential. I only have one snap ring for it. Am I missing one? If there is only one which side does it go on?
I cant remember for sure. been a few days since I disassembled it and alot has happened in life since doing it.
Old 04-17-2007, 10:21 PM   #10
rbuffum
rbuffum is on a distinguished road
1996 SC1
How did this go? I am getting ready to do the same thing tomorow... anything i should look out for or things that might make it easier?
Thanx and I hope all goes well for you.
Rob
Add to rbuffum's Reputation
Rate the quality of this post and help rbuffum reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rbuffum is offline   Reply With Quote
Old 04-17-2007, 10:21 PM   #11
andy_95sl2
andy_95sl2's Avatar
there's only one there. It goes.... CASE -> DIFFERENTIAL - SNAP RING IN BORE (its a spacer for the differential) -> CASE -> AXLE SEAL -> AXLE SEAL SNAP RING.
hope this make sense. If not, go to your local dealership and have them print out an expoded view for you.
Old 04-18-2007, 05:51 PM   #12
Ryan from Ohio
Ok,
Which side of the differential?
The one in the bell housing or the side where the case/all the gears are?
Thanks for the help. I figured I was going to have to make my own spacer tomorrow at work! lol
Old 04-18-2007, 10:20 PM   #13
andy_95sl2
andy_95sl2's Avatar
the side of the biggest axle seal. In this case, its the middle case, the one that goes over all the gears.
Old 04-19-2007, 05:48 PM   #14
Ryan from Ohio
Hey, thanks.
I kinda was guessing that side. I put it on the wrong side, and the gears are rubbing... so that explains it then!
Thanks!
S*2 manual trans in S*1 itsnotme1988 S-Series Mods 4 09-03-2008 10:35 AM
Whats trans fluid does everyone use in their manual trans? turbobuick33 S-Series Tech 14 11-07-2007 02:11 PM
DOHC Engine Replacement..thust bearing...Manual Vs. Auto Trans?? Need Help! mile2885 S-Series Tech 5 08-30-2007 11:12 PM
removing engine on 96 sc2 (car has manual trans)... from top w/o removing trans??? DJboozeAlot S-Series Tech 4 02-02-2007 10:18 PM
S-Series Manual Transaxle Disassembly/Reassembly wolfman How-To Library 0 09-02-2003 07:54 PM
