Old 01-14-2007, 01:13 AM   #1
HiMileSL2
HiMileSL2 is on a distinguished road
Default SL2 1994 Emissions Failed, hesitates, dies
Failed emissions in Texas 2 weeks ago. Very high mileage. Extremely high NOX and HC. Intermittently hesitated and died at all speeds but quickly restarted. Never happened during warm-up. Intermittently had Service Engine Soon Light on.
I did this for repair:
1. New catalytic converter
2. New EGR Valve and EGR Vacuum Solenoid
3. New O2 sensor
4. New thermostat
5. New spark plugs and spark plug wires
Took car back for re-inspection today - they did not even test it because it ran so badly - rough and probably missing. BUT the service-engine-soon light was not on. After I drove it (after state testing) the service-engine-soon light came back on.
Any ideas on what to do next? Thought about replacing computer (dealer did about 3 years ago w/rebuilt) but not sure that's going to solve it. Baffled.
Add to HiMileSL2's Reputation
Rate the quality of this post and help HiMileSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HiMileSL2 is offline   Reply With Quote
Old 01-14-2007, 02:20 AM   #2
Default Re: SL2 1994 Emissions Failed, hesitates, dies
Have you replaced the engine coolant temperature sensor (ECTS)? Check the How-To section, old plastic one replaced with a new brass one.
Old 01-14-2007, 10:07 AM   #3
DonP
What codes does the SES give?
Are the posts on the coil clean and corrosion free?
Add to DonP's Reputation
Old 01-14-2007, 06:41 PM   #4
HiMileSL2
The codes are
19 ignition system fault-intermittent 7X signal or loss of 58X signal or 6X signal
32 barometric pressure (BARO) sensor circuit failure
** exhaust gas recirculation (ERG) valve diagnostic switch closed during engine startup or open when ERG flow requested by the ECM.
** electronic regulator valve (EVRV) error (EVRV controls EGR vacuum)
One symptom I forgot to mention is above 45 or 50 mph the speedometer wobbles or waivers.
Does this reveal anything new? Thanks for the assist.
Old 01-14-2007, 06:44 PM   #5
HiMileSL2
Will be checking into that soon. Thanks for suggestion.
Also forgot to mention the spark plug coils are clean
Old 01-14-2007, 10:42 PM   #6
DonP
How about the coil pack-to-engine mounting (under the pack)?
Old 01-15-2007, 07:19 AM   #7
BarnOwl
BarnOwl's Avatar
First, clean your EGR valve. There are instructions in the How-To Library. If that doesn't make it run better, disconnect and plug the vacumn hoses to the EGR. If that does make it run better, it's time for an EGR.
Add to BarnOwl's Reputation
1994 SL2 hesitates Keefer S-Series Tech 22 09-26-2007 06:53 PM
1993 SL2 failed emissions MsgtDav(ret) S-Series General 5 03-06-2006 04:57 AM
My 1996 SL2 failed emissions (map sensor problem??) 96saturnguy S-Series General 3 01-25-2006 03:02 PM
My '93 SL2 failed NJ emissions. $1K Special S-Series General 10 07-02-2005 09:34 AM
'00 SL2 Failed NC emissions - p0171 + horn oogy S-Series General 1 06-29-2005 03:38 PM
