Old 04-29-2002, 11:21 AM   #1
dohc 97
dohc 97 is on a distinguished road
Default spark plug wire boots
Sometimes it is impossible to click the ignition wire boot onto a spark plug, even with the engine cold.
Any suggestions?
Add to dohc 97's Reputation
Rate the quality of this post and help dohc 97 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dohc 97 is offline
Old 04-29-2002, 12:29 PM   #2
bigbird
bigbird is on a distinguished road
bigbird's Avatar
Default
If the boot won't snap on to the spark plug with an audible click, then try squeezing the metal clip inside the boot tighter with a needle nose pliers. If this doesn't help, then it's time for new boots.
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline
Old 04-29-2002, 03:17 PM   #3
Qlara
Qlara's Avatar
Idea
Look inside the boot and check the metal socket, as long as it's not corroded (badly sometimes) the plug head should have good contact to the wire....with audible click or not.
Make sure the boot is fully plugged in to the plug head, of course.
Add to Qlara's Reputation
Qlara is offline
Old 04-29-2002, 09:41 PM   #4
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Idea
Try putting a dab of di-electric grease onto the end of a Q-tip, then apply the di-electric grease to the metal "band" inside the spark cable boot that snaps onto the spark plug.
The di-electric grease is used to make better electrical connections, to help seal out moisture (and prevent rust), and to help dissipate heat. Maybe it will also help the boot snap onto the end of the spark plug.
David 93 SL2m is offline
Old 04-30-2002, 08:48 AM   #5
dohc 97
Default
Dielectric grease is non-conductive -- not conductive. That's why it is used on ignition wire boots -- to deter arcing between boot and spark plug, and boot and coil. It also provides a waterproof seal.
dohc 97 is offline
Old 04-30-2002, 10:24 AM   #6
Qlara
Qlara's Avatar
Idea
Di-electric grease won't help to conduct the spark stronger, but help to maintain a 'seal' environment between metals so the high voltage won't oxidize the conductive element overtime and eat out the metal band....
Did you see white ashes always accumulate on the coil head or inside the boots? That's oxidation from the metal cuz by contant high voltage conduction.
Qlara is offline
Spark Plug Wire Help awhat? S-Series Tech 6 04-24-2007 10:20 PM
Spark Plug Boots Maritime Storm Ion Tech 1 04-07-2007 10:58 AM
Spark Plug Wire #1... PitchBlackSC2 S-Series Tech 1 11-08-2005 10:48 AM
ignition wire/spark plug wire - resistance/ohms Heartbeat - '95 SL2 S-Series Tech 3 10-17-2005 02:09 PM
Spark Plug Wire Help... Rob1998SL2 Mods and Performance 8 10-16-2003 03:09 PM
