Old 10-14-2006, 06:26 PM   #1
dmc
dmc is on a distinguished road
2000 SL2
Default 3rd gen SL2 exterior door panel removal
I'm going to be replacing the driver side exterior door panel on my 3rd gen SL2. Will these instructions for a 97 SW2 work?
http://www.saturnfans.com/forums/showthread.php?t=73445
dmc is offline   Reply With Quote
Old 10-14-2006, 08:11 PM   #2
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: 3rd gen SL2 exterior door panel removal
Yes, its the same throughout the s-series. There may be some alterations, but nothing really major.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
andy_95sl2 is offline   Reply With Quote
Old 10-28-2006, 02:24 PM   #3
dmc
2000 SL2
Done.
It was pretty straightforward. I *carefully* removed the T-30 bolts from the inside of the door with a drill, then pulled the push-pin out from the bottom of the exterior door handle (there was only one pin). I slid the handle to the left, and it came right out.
I tried removing the panel right then, but it was still locked in to the weather strip. There was one T-15 bolt at the rear of the door that had to be removed, and then the weather strip easily pulled out. I also had to remove the mirror. This was done by yanking out the plastic shroud around the manual adjustment knob, and removing three 10mm nuts. The mirror comes right off after that.
I lifted the exterior door panel to unlock it from two tabs on the top edge, and it easily came off. Installation was done in reverse. I took the oppurtunity to put graphite on the T-30 bolts so they won't rust out.
2nd to 3rd gen panel interchangeability spencerforhire S-Series Tech 4 01-11-2009 08:50 AM
2nd gen SL2 seats in a 3rd gen SL1 or SL2? delturcious S-Series Tech 2 03-28-2008 05:39 PM
1997 SL2 Door Panel Removal Help CKyAlliance07 S-Series Tech 9 11-12-2005 12:44 AM
Removing exterior door panel?!? jefferson70 Miscellaneous Tech 3 09-14-2003 07:22 PM
2001 SL2 front door panel removal? klasvoss S-Series Tech 3 10-24-2000 12:39 AM
