Old 10-22-2005, 12:16 AM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Shell Rotella T 5W40 good oil for the saturn 1.9?
I have a oil consumption problem on my 92 Saturn SL 1.9 DOHC and I remember reading a post that one guy is using Shell Rotella T 5W40 and his oil consumption has dropped. Is Shell Rotella T 5W40 good oil to use everyday? Does anyone here use this type of oil?
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 10-22-2005, 12:50 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Shell Rotella T 5W40 good oil for the saturn 1.9?
I can't remember who it is, but there is someone that posts in the tech forum that is trying all kinds of different oils. He's on rotella now. Looks good so far.
Add to BarnOwl's Reputation
Old 10-22-2005, 10:20 AM   #3
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
How could you forget the King of Caddyshack?
(hard to believe that was 25 years ago, most of you younger guys weren't even born or were little kids)
http://www.saturnfans.com/forums/showthread.php?t=55258
If you want to go cheaper, try some Mobil Delvac 1300 15W40 which is about 6.50 a gallon at Wallys.
Although if you're in a cold climate, it might not be the best for winter starts.
These diesel oils have a stout detergent package which should help clean out the rings.
If you can find the German Castrol, that would be my best recommendation.
Try an Autozone in a bad part of town and look for 0W30 weight, MADE IN GERMANY only, not USA version they are totally different. The guys on BITOG paid to have it analyzed and the GC uses a special ester base that makes is a good cleaner. Good luck.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-22-2005, 10:59 AM   #4
eRic 02sc2
eRic 02sc2's Avatar
is the 1.9L a diesel? I don't think we need advanced soot-handling... I use 5w30 Valvoline or whatever Saturn retailers fill it with. Saturn had some assocation with Valovoline or Quaker State if my memory is correct. or that was the ICY racing team when they raced Saturns. your 92 consumption problems can probably be resolved with valve guides and/or piston rings. or you could have a leak somewhere. my 92 SC had oil consumption so the the valve guides and piston rings were replaced. also I replaced the cam cover gasket.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 10-22-2005, 11:13 AM   #5
cazzylee
cazzylee is on a distinguished road
cazzylee's Avatar
I use Castrol 10-40 weight which has reduced my oil consumption (along with some tricks) to 1 qt in 1500 miles. Next oil change I'm gonna try the mobil 7500 (changing every 3000 miles regardless of mobil's claims...), I've been hearing on other forums about it reducing even further oil consumption problems.
Madness takes it's toll: Please have exact change.
SES light + unplugged sensor = testicle ownage.
Add to cazzylee's Reputation
Rate the quality of this post and help cazzylee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cazzylee is offline   Reply With Quote
Old 10-22-2005, 11:37 AM   #6
patcal
patcal is on a distinguished road
patcal's Avatar
I have been using Conoco 5-30 synth. I am burning 1 qt in 1000 miles. I did the MMO soak last night. Sure was smokey this morning. I may change to Mobil since I am now out of the Conoco.
Pat Callaghan
Portland, Or.
Add to patcal's Reputation
Rate the quality of this post and help patcal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
patcal is offline   Reply With Quote
Old 10-22-2005, 12:10 PM   #7
FrozenPilot
FrozenPilot's Avatar
I use Shell Rotella T Syn 5w40 in my SL1. Its one of a few oils that have less oil consumption than others. Things to note, its officially an HDEO (Heavy Duty Engine Oil) and is designed for use in gas and diesel motors (fleet oil). HDEOs tend to help with oil consumption in our Saturns because they are designed for severe service, though it works out to something like $3.50/qt. The ONLY other oil I've tried that had low consumption was Chevron Supreme 5w30, which is also similar to Texaco Havoline. Different weights of Mobil1 (5w30, 10w30, 5w40) had no effect on consumption.
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline   Reply With Quote
Old 10-22-2005, 12:26 PM   #8
twosaturns
twosaturns's Avatar
I'm running 10W30 in my DOHC, and did an MMO soak. seems to be doing well. never seen heavier oils have an effect on consumption. if you are not leaking, do an MMOS and you should be good to go.
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline   Reply With Quote
Old 10-22-2005, 01:36 PM   #9
turbobuick33
1992 SL2
Where can I buy shell rotella 5w40? Ive been to a few auto parts stores and they don't have it
Old 10-22-2005, 02:55 PM   #10
Bill Murray
1997 SC1
1997 SC1
Most Wal-Marts have Rotella 5W40 syn usually right next to the Rotella dino gallons
blue quart bottles
3.62 / quart at mine in Indy
Old 10-22-2005, 03:03 PM   #11
Bill Murray
1997 SC1
1997 SC1
the consensus seems to be that "stuck" oil rings is a contributor to oil consumption on the 1.9
these diesel oils have a lot of detergent but also meet the SL/SM gas specs although too thick to get the starburst energy conserving rating
anybody that has an oil burner can experiment
I was able to greatly improve consumption without any internal work
Old 10-22-2005, 03:31 PM   #12
turbobuick33
1992 SL2
I think 15W40 is to thick of a oil for everyday driving use especially since the cold weather is already here. Do you know the brand name of the 0W30 oil? Would this 0W30 oil be ok to use during the cold weather?
Old 10-23-2005, 08:04 AM   #13
BarnOwl
BarnOwl's Avatar
Ummm you can't be taking about me. I was born in '56.
Old 10-23-2005, 01:42 PM   #14
JLWhid
JLWhid is on a distinguished road
Guys on Bobistheoilguy use Mobil Truck and SUV 5w-40 with success. I'm at 62K miles with my 1.9 and it only uses about 1/4 of a quart in 5000 miles so Im still using havoline 10w-30.
Add to JLWhid's Reputation
Rate the quality of this post and help JLWhid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JLWhid is offline   Reply With Quote
Old 10-23-2005, 02:36 PM   #15
Bill Murray
1997 SC1
1997 SC1
Castrol Syntec
but only made in Germany 0W30 grade
none of their other varieties sold in the USA have the PAO/ester base oil
yes it's a great cold weather oil
the pour point is -63C
Old 10-25-2005, 07:33 PM   #16
turbobuick33
1992 SL2
Would it be ok to switch to the shell rotella 5w40 in my car with 197,000 miles? I didn't know that it was synthetic until yesterday when I looked at the bottle. The previous owner used conventional oil and sometimes synthetic blend through out all of those miles. Will it be ok to switch?
Old 10-25-2005, 08:42 PM   #17
obd
obd is on a distinguished road
1995 SC1
I use 20w50 valvoline in my 95 saturn with 120K most people think that is to thick but with more miles engines develop wear which leads to more gaps for the oil to sqeeze through. Car companies suggest very thin oil for two reasons one is that new engines have tighter tolerances the second is that car companies don't want your car to last forever. why would they? I still get 29mpg and have no problem in sub zero weather but that is also propaganda, because thinner oil doesn't cling to parts as well which can cause damage to higher milage engines and lower oil pressure that can become hazardous at higher rpms.
Add to obd's Reputation
Rate the quality of this post and help obd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
obd is offline   Reply With Quote
Old 10-25-2005, 09:12 PM   #18
FrozenPilot
obd, 20w50 is probably overkill on a 120k mile Saturn. Thicker oil is not always better, read through Bobistheoilguy to find out more. If you had a nearly worn out Saturn, the 20w50 may do you some good to cushion the gaps between parts, and subsequently reduce consumption, but in this case I doubt it. Some proof that 30wt is fine in Saturns is when members here have torn down their motors to find the factory hone marks at well over 100k. Oil flow is just as important as oil pressure, and flow is something you may not have compared to a 30wt on those oh so cold mornings.
Old 11-02-2005, 11:06 PM   #19
HomeBase
HomeBase is on a distinguished road
I posted this at Bob's site at the 122,756 mile mark. The high insolubles and reduced flash point are due to the t-stat running too cold (it's been replaced since then...)
Rotella 5w-40 is a top-notch product!
Add to HomeBase's Reputation
Rate the quality of this post and help HomeBase reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HomeBase is offline   Reply With Quote
Old 11-03-2005, 01:35 AM   #20
turbobuick33
1992 SL2
I going to try 5w40 rotella. My car burns oil alot. My saturn has 197,800 miles on it. Every single week I have to add 1/4 of oil to the crankcase. I put about 360 miles a week on my car. My saturn has no leaks and no blue smoke from the tailpipe. The cars runs excellent but just eats oil every week. I hope this rotella 5w40 will slow down my oil consumption
Rotella T Engine Oil.... gm7 S-Series Tech 37 08-28-2019 11:01 AM
Rotella Synthetic 5w40 Leafy S-Series Tech 22 12-05-2009 12:41 PM
Anyone using Rotella T or any other HDEO oil in their engine? Spartus S-Series Tech 19 10-13-2008 09:04 PM
Shell Rotella Recommendation, inquiry Luke S-Series Tech 24 01-19-2007 03:52 PM
96 SL2, Used Oil Analysis, Shell Rotella-T 5w-40 Synth HomeBase S-Series General 15 02-11-2005 11:16 AM
