Old 02-18-2005, 07:50 PM   #1
1993
1993 is on a distinguished road
Dizzy changing coolant hoses?
I want to change all the coolant hoses in my 1992 sc, the question, how do you remove that metal/rubber hose combo that runs from the recovery tank up under the torque axis mount, around the corner and into the heater core? only way i see is to remove the TAM mounts mount, wich is about impossible to get to seeing as its bolted to the body and theres no room to get a wrench in there with the motor being right there..the metal hose is not bad but i would like to replace the rubber parts that are made to the metal pipe, so i guess i have to replace the whole assembly..?
Add to 1993's Reputation
Rate the quality of this post and help 1993 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1993 is offline
Old 02-18-2005, 08:23 PM   #2
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
Default Re: changing coolant hoses?
There is room.
Add to TheSaturnKid's Reputation
Rate the quality of this post and help TheSaturnKid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheSaturnKid is offline
Old 02-18-2005, 08:59 PM   #3
Razorbak
Razorbak's Avatar
Why? Does it need to be replaced?
Add to Razorbak's Reputation
Razorbak is offline
Old 02-18-2005, 09:55 PM   #4
saturnhacker
saturnhacker is on a distinguished road
yeah, that hose seems to last forever, imo i would leave it go, unless the rubber is obviously bad. you do have to remove the motor mount bracket, the hardest part of that is getting the four bolts off on the inside frame rail, its a little tight..
Add to saturnhacker's Reputation
Rate the quality of this post and help saturnhacker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnhacker is offline
Old 02-18-2005, 10:09 PM   #5
1993
no, it doesnt seem to be bad, but the car has close to 200,000 miles on it so i thought they might go bad soon, but if their not prone to leaking, i may leave them alone..?
1993 is offline
Questions about coolant hoses termite S-Series General 4 09-05-2009 12:24 PM
Coolant hoses Bill Murray Miscellaneous Tech 4 09-26-2003 09:02 PM
Replacement coolant hoses David 93 SL2m Miscellaneous Tech 5 04-25-2001 07:55 AM
Replacement coolant hoses David 93 SL2m Mods and Performance 0 04-23-2001 07:06 AM
coolant hoses rogerk S-Series Tech 3 09-07-2000 10:20 PM
