Old 06-12-2004, 10:16 PM   #1
AJR
AJR is a jewel in the roughAJR is a jewel in the roughAJR is a jewel in the roughAJR is a jewel in the rough
2002 L-Series 2.2L Sedan
Default Cheap, Cheap, Cheap (cabin filter)
I assume I will be able to change this filter twice before the door for this thing breaks off. That whole plastic cowl section is the worst I've ever seen. Do you guys even bother putting this filter in any more?
Andy
Add to AJR's Reputation
Rate the quality of this post and help AJR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AJR is offline
Old 06-12-2004, 10:37 PM   #2
silverblueL200
silverblueL200 is on a distinguished road
silverblueL200's Avatar
Default
Yea the that whole cowl is pretty poorly made, I always have to bend the metal back into place everytime I open it. I still keep changing the filter though cause it does seem to work pretty well.
- 2003 Saab 9-3 Arc
Hello, mother. I come bearing a gift. I'll give you a hint. It's in my diaper and it's not a toaster. -Stewie Griffin
Add to silverblueL200's Reputation
Rate the quality of this post and help silverblueL200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverblueL200 is offline
Old 06-12-2004, 11:37 PM   #3
Euphony010
Euphony010 is on a distinguished road
Euphony010's Avatar
Default
I broke mine the first time :-(
I need to check that...
Thomas
So Long L Series... Hello Mazda 3.
I still miss the polymer.
Add to Euphony010's Reputation
Rate the quality of this post and help Euphony010 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Euphony010 is offline
Old 06-13-2004, 12:14 AM   #4
hugh
hugh will become famous soon enough
Default
I must be missing something here as I had no trouble getting to the filter on my 2000 LS2 and now on the 2004 L300.3.
Make sure you lift the cowl seal completely off the metal flange and put the screwdriver in from the front,not the side as shown in Handbook.
I live in a dusty area and wife has alergies so I changed filter more often than called for in LS2......must have replaced it at least a dozen times and the cover showed no signs of wear. If you try to pry it up from sides,I can see why the hinge might mot last too long.
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline
Old 06-13-2004, 10:11 AM   #5
BobL
BobL is on a distinguished road
Default
My LS had the same self-hinged piece of crap.
Contrast to my Corolla. Open glove compartment and squeeze sides.
Reach in and remove a door with 2 press snaps.
Pull out old filter. Push in new filter.
All of 2 minutes - no tools.
GM engineers are tremendously lacking in intelligence.
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Old 06-13-2004, 03:49 PM   #6
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
I had no trouble changing mine, but I removed the hood seal first. Made it much easier to open the cover.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline
Old 06-13-2004, 04:31 PM   #7
Silversaturn
Silversaturn is on a distinguished road
Silversaturn's Avatar
Default
How often should this be replaced?
Add to Silversaturn's Reputation
Rate the quality of this post and help Silversaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Silversaturn is offline
Old 06-13-2004, 05:47 PM   #8
BobL
Default
Possibly every 8K. Depends on where you drive.
When airflow on "fresh" is much less than on "recirc", it's time.
BobL is offline
Old 06-13-2004, 10:06 PM   #9
Silversaturn
Default
:o: :o: :o: , well i guess at 17k i'd better get one and replace the old one...DOH!!
Old 06-13-2004, 10:14 PM   #10
Hans Gilbranson
Hans Gilbranson is on a distinguished road
Default
[/B]
Is that what they mean in the owner's manual when they say to "peel" the seal back?
My filter was changed a few weeks ago. Both center dash A/C vents worked fine prior to changing it. A few days later when we turned the air on the left center vent had no air flow at all, while all of the others worked fine and all other functions of the HVAC system functioned properly.
Anyway, I lifted up the lip from left to right and was popping up the cover as I went. It came up and there were same leaves and things next to the holes where the ductwork opened and closed.
I ran the system for awhile and low and behold the duct getting no air worked fine.
The hard part was closing the cover and trying to get the lip of the gasket over the edge of the cover. I'm guessing from what you said that I could have simply lifted the gasket off and merely pushed it back into place when I was done.
Add to Hans Gilbranson's Reputation
Rate the quality of this post and help Hans Gilbranson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hans Gilbranson is offline
Old 06-13-2004, 11:21 PM   #11
silverblueL200
Default
I have to change mine every couple a months, its gets nasty pretty quick, I left the last one in a little too long and it got all moldy and crap.
- 2003 Saab 9-3 Arc
Old 06-14-2004, 12:08 AM   #12
AJR
Default
OOPS. My bad. I really thought that hood seal was glued on. I'll try pulling that seal off and prying up in the middle next time. Maybe I could make it last longer that way. That assembly is still awfully cheap though.
Andy
AJR is offline
Old 06-14-2004, 01:19 AM   #13
hugh
Default
Hans;
Yes,that is what they mean. The seal is a friction-fit thing with no fasteners and is very easy to remove and replace.....just pull straight up. Again,make sure you take seal completely off before trying to pry up the cover.
hugh is offline
Old 06-14-2004, 01:23 AM   #14
Hans Gilbranson
Default
Originally posted by hugh
Hans;
Thanks! I don't know what happened when I had it off to make the center left A/C outlet get air again but it did.
Old 06-14-2004, 07:43 AM   #15
mcgyver
mcgyver is on a distinguished road
Default Tried It
This thread motivated me to go out and check my Cabin Filter at 3 months and 7k/mi.
The filter was loaded with crap. And although I did follow 'lost wages' advice and pull the hood seal first, that filter housing does NOT inspire confidence. The whole thing tried to come up instead of just the middle section. It was a hassle.
My experience is from a Volvo dealership a few years back. Our Cabin filters were under a selaed cover held with a couple of T-25 screws as I recall.
Well, I had no replacement on hand so I vacuumed it and tapped it against a wall. For fun, I checked the Engine Air filter too fore the first time. It was hardly stained at all. ??!
Could, perhaps the Cabin Air Filter have been under-designed? Or is there just so much particulate matter suspended in the soCal air?
Add to mcgyver's Reputation
Rate the quality of this post and help mcgyver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mcgyver is offline
Old 06-14-2004, 08:08 AM   #16
BobL
Default
I vote underdesigned since large matter should be kept entirely out by a screen.
Entire system is a Rube Goldberg piece of crap compared to the Corolla. No tools and a two minute change.
Guess GM should stop by the Toyota line at the plant they share in Fremont, CA and learn how a proper cabin filter assembly should be engineered.
BobL is offline
Old 06-14-2004, 10:30 AM   #17
lostwages_ls2
Default
Don't forget. The L is basically an Opel Vectra. The filter design is probably from Opel. I have an Olds Silhouette. The cabin filters are changed thru the glove box.
Obey the Min Pin
Old 06-14-2004, 11:19 AM   #18
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default
The L is very easy after doing it the 1st time. The VUE is a much better design with 2 plastic pull pins. Saturns are the 1st cars I have had these filters and they are expensive.. especially the VUE. I believe some Hondas it is a real task to get to the filter.
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 06-14-2004, 11:28 AM   #19
AJR
Default
Rick, they are a bit high for what they are. Believe it or not, Saturn was a dolllar cheaper than Pep Boys. I was surprised by that.
Andy
AJR is offline
Old 06-14-2004, 11:55 AM   #20
ricksLS1
ricksLS1's Avatar
Default
Andy
I get the ones for the L for $8.07 from one dealer the other dealer charges $11.25. The one for the VUE costs $21.75 at one dealer and $27.95 at the other
ricksLS1 is offline
Cheap $25 1998-2002 Fuel Filter & aftermarket guide ruley73 S-Series General 74 06-04-2013 11:08 AM
Cheap DDin Touchscreen DVD unit... like 199 cheap Counterfit Vue General 18 12-17-2007 02:18 PM
Fram AirHog Filter, dirt cheap, should I bite? The Critic S-Series Tech 2 09-23-2006 07:45 PM
cheap oil filter tool? liubhs02 Ion General 3 09-13-2006 08:13 PM
