Old 09-26-2003, 11:39 AM   #1
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
Default Coolant hoses
My 97 SC has 107k miles and the original coolant hoses.
They look to be in surprisingly good shape but I'm sending the car off to college in January with my kid so it will be an hour away and I'm doing some preventive maintenance.
Any tips on good brands / sources?
THANKS!
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill Murray is offline
Old 09-26-2003, 12:01 PM   #2
WHITE98SL2
WHITE98SL2 is on a distinguished road
Default
coolant hoses I have found are just coolant hoses. I have used aftermarket hoses with no problems but I change them every three years so I couldn't comment on longevity between one type or another. Change the upper and lower for sure. Remember when the hoses feel soft and pliable its time for them to go.
Add to WHITE98SL2's Reputation
Rate the quality of this post and help WHITE98SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WHITE98SL2 is offline
Old 09-26-2003, 08:15 PM   #3
TedL
TedL is on a distinguished road
Default
I didn't like the quality of the Kelly Springfield hoses at Autozone, so went with NAPA, which I found to be of better quality. But I later noticed that Saturn list was about the same as NAPA. Start there, and check prices. I've been surprised how some OE parts come in cheaper than aftermarket (like OE valve cover gasket for $15.)
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 09-26-2003, 08:41 PM   #4
Dach
Dach is a jewel in the roughDach is a jewel in the roughDach is a jewel in the rough
Default
Don't forget the hose from the coolant tank to the t-stat. And if your t-stat is original it might be worth changing it out while your in there.
Add to Dach's Reputation
Rate the quality of this post and help Dach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dach is offline
Old 09-26-2003, 09:02 PM   #5
TedL
Default
That's not the only one overlooked. There are seven coolant hoses on an SL of that vintage - -I assume the SC has the same count. All seven bear full cooling system pressure. I replaced 'em all on the car I sent off to college in August.
TedL is offline
Questions about coolant hoses termite S-Series General 4 09-05-2009 12:24 PM
Coolant sweating from hoses? Elementkng20 S-Series Tech 4 03-28-2007 04:58 PM
Replacement coolant hoses David 93 SL2m Miscellaneous Tech 5 04-25-2001 07:55 AM
Replacement coolant hoses David 93 SL2m Mods and Performance 0 04-23-2001 07:06 AM
coolant hoses rogerk S-Series Tech 3 09-07-2000 10:20 PM
