Old 03-04-2019, 03:17 PM   #1
bikeone43
bikeone43 is on a distinguished road
2009 VUE 2.4L
Dizzy door locks
i have a 2009 saturn vue 4 cly automatic transmission xel door locks work on drivers door not other doors when it get hot they all stop working they make a noise and the locks look like they are trying to move but only a little movement be seen ,sometimes they work ok other time not at all help thank you
Add to bikeone43's Reputation
Rate the quality of this post and help bikeone43 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bikeone43 is offline   Reply With Quote
Old 03-04-2019, 11:22 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: door locks
It sounds like a minor power deficiency - perhaps weak battery or electrical system.
Do locks operate same with: (1) engine off, (2) engine on. or (3) engine at 1300 RPM or higher?
I've also attached a door lock/unlock description and a few diagrams.
Repost or send PM if you have more questions.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 03-05-2019, 07:49 PM   #3
far2grumpy
far2grumpy's Avatar
I received OP private message indicating locks were flaky with engine on/off and at higher RPM.
I would normally suggest swapping lock/unlock relays but it appears they're hardwired to a circuit board.
Best I can do at this point is attach FSM extract with steps a dealer tech would use to isolate possible causes.
Old 03-06-2019, 02:30 PM   #4
bikeone43
2009 VUE 2.4L
thank you will try when i get over this crap i came down with thanks again
Old 03-09-2019, 02:04 AM   #5
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
some times it just needs several latches, I see this often.
Add to bern's Reputation
Door Locks gspille Aura General 2 05-01-2015 08:16 PM
What's up with my door locks? Blue Eyed Devil S-Series Tech 5 11-28-2009 12:37 AM
Door locks by itself! cam Ion General 6 04-13-2009 05:07 PM
door locks squirel022003 S-Series Tech 1 03-08-2006 10:47 AM
Door Locks??? sc24life Miscellaneous Tech 5 06-12-2002 10:06 AM
