Old 07-27-2018, 07:35 PM   #1
Mysaturnbeater
Mysaturnbeater has a spectacular aura aboutMysaturnbeater has a spectacular aura aboutMysaturnbeater has a spectacular aura about
Default Recharge my ac
I have a 1998 Saturn SC 1.
I'm looking to recharge my AC. Its not quite cold enough.
Does anyone know the high and low pressure and how many pounds does it use?
R134a Freon.
Thank you
Add to Mysaturnbeater's Reputation
Rate the quality of this post and help Mysaturnbeater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mysaturnbeater is offline   Reply With Quote
Old 07-27-2018, 08:50 PM   #2
Default Re: Recharge my ac
1.5 lbs or 24 ozs. Before throwing away money to refill..............a leaking system, buy and use an inexpensive uv blacklight (good for any vehicle already having dye in it) to find the source of the leak. All Saturns (and most likely every GM vehicle with r134a systems) have dye already installed at factory assembly to make it easier to find 98% of all vehicle ac problems, the leak no one wants to find and fix but will reach for the refill kits. Sealer will guarantee a more expensive repair.
To prove how stubborn diyers are; http://www.saturnfans.com/forums/sho...10#post2278610
Old 07-28-2018, 12:29 AM   #3
Mysaturnbeater
I had it recharged about 2 yrs ago. And I do have a set of UV lights.
Thanks
What about the high and low pressure?
Old 07-28-2018, 05:24 AM   #4
Run the engine up to 2k rpm when measuring pressures.
Old 07-28-2018, 05:44 AM   #5
Mysaturnbeater
I plan on buying some dye so that way I can find where the potential leak is coming from first before deciding to recharge the AC system again.
I'll report back
Old 07-28-2018, 06:22 AM   #6
Read my first reply again. Dye is in your system and doesn't have a freshness date. There's no need to add dye.
Old 07-28-2018, 06:27 AM   #7
Mysaturnbeater
Sorry. I should of been more clear.
I had my AC recharged about 2 to 3 yrs ago from a shop. When I had it recharged, does the shop that recharged my AC system already have dye added from their machine?
Just wanted to be clear.
I'll go ahead and check it with a UV light. Thanks
Old 07-28-2018, 10:44 AM   #8
I'm not a business owner and do not know what repair shops do or not do but my guess is if you didn't ask for dye, they didn't add any. Dye is inexpensive but can be messy for anyone to add into a system. Again, dye is already in your system and does not degrade. It's mixed in with oil and circulates permanently. When refrigerant, oil and dye are released, refrigerant is invisible but oil and dye are not, leaving markers for almost anyone to find. A uv light makes it easier to find leaks.
Old 08-09-2018, 03:42 PM   #9
boatmoter
boatmoter is on a distinguished road
boatmoter's Avatar
1993 SL2
remove all freon, evacuate the system and install the amount of freon stated on the radiator support, each can of freon is 12 oz,I forgot how much mine held,it was like 2.5 cans
Add to boatmoter's Reputation
Rate the quality of this post and help boatmoter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
boatmoter is offline   Reply With Quote
Old 08-09-2018, 05:46 PM   #10
I don't know if your r12 converted system to r134a uses the same amount but all S-series ac systems havingr134a from the factory have 1.5 lbs or 24 ozs as the amount. Two 12 oz cans.
Old 08-12-2018, 01:29 PM   #11
Mysaturnbeater
Thanks
AC recharge relaymom Relay Tech 5 11-09-2011 07:43 AM
AC/Recharge Zvolen S-Series Tech 6 07-25-2007 12:59 PM
AC Recharge?? andyr13 Vue General 23 07-06-2007 03:41 PM
98 SL2 AC recharge Muktar6 S-Series General 2 07-18-2006 11:57 AM
AC Recharge Kit LoveMySL1s S-Series Tech 0 06-15-2001 12:06 PM
