Old 11-25-2011, 08:46 PM   #1
JakeJD
JakeJD is on a distinguished road
Default Crazy Throttle Body Noise?
Hi everyone! Its my first time
I have a question. I have a high pitch noise coming from the Throttle body when I have the key in the on position with out the car running... cant start it. Also some random clicking in there.
The code I am getting right now is P0123. The book says Throttle Position?
Also P0222, cant find the code for that.
Anyway, anyone know if this could be causing my car not to start? Lease it happened in my garage.... LOL!
Add to JakeJD's Reputation
Rate the quality of this post and help JakeJD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JakeJD is offline   Reply With Quote
Old 11-25-2011, 10:30 PM   #2
Default Re: Crazy Throttle Body Noise?
Year might help as well as mileage and any other maintenance done recently.
Old 11-26-2011, 02:20 AM   #3
JakeJD
sorry... 2000 lw 80,000+ miles, v6 The more I read, the more I think I need to replace the throttle body.
Old 11-26-2011, 04:19 AM   #4
P0123 Throttle position sensor 1 circuit high voltage
P0222 Throttle position sensor 2 circuit low voltage
Yes, this may be a throttle actuator issue. There may be a loose connection worth checking - exercise the connection by disconnecting and reconnecting several times and try the ignition again. The electronic drive-by-wire system are the throttle actuator control (TAC), accelerator position pedal (APP) sensor, and the ecm. Normally these tacs are reliable and built for longevity as you may the the first to post these two error codes for a tac fault. Hopefully its just a loose connection.
Old 11-26-2011, 06:43 AM   #5
JakeJD
Thanks for your time!
I have unplugged and plugged a few times and still the car wont start. Is there a fuse that I should be checking?
Does having a bad throttle body cause the car not to start?
Old 11-26-2011, 05:11 PM   #6
JakeJD
Well I installed another throttle body and I no longer get those errors. Car still wont start and the new error I get is P1510. LOL, I'm lost!! I dont even know if it was the throttle body after all. Sucks!
Any ideas??
Old 11-26-2011, 05:14 PM   #7
Well, its presumed you checked all fuses everywhere before, during, and maybe after troubleshooting. Its difficult to damage a tac. Either it works or its broke and no one has posted of a completely broken tac so you may be treading a new pathway..............If the throttle doesn't open when holding the electronic pedal down (have someone do this so you can see the throttle plate move) this may stop the engine from starting. (ignition must be ON to exercise the throttle body) Are there any indicators on the instrument panel?
Is the tac clean or filthy from years of use with no cleaning done? If its dirty then clean it the best way you can.
Old 11-26-2011, 05:22 PM   #8
JakeJD
Checked all the fuses like 3 times and yes I cleaned it wasn't that dirty. headed out to see if it moves.
Quoted $150 for a door body gasket. Crazy? CaptainMouse64 S-Series Tech 1 09-02-2010 01:39 AM
New noise from car driving me crazy! Help me? CaptainMouse64 S-Series Tech 7 01-20-2010 12:15 PM
How to know if throttle body is bad? hd071502 Vue Tech 11 03-12-2009 11:14 AM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 05:20 PM
This noise is driving me crazy! mjbuck Vue General 28 08-02-2006 07:23 AM
