Old 11-26-2010, 04:21 PM   #1
Auragirl09
Auragirl09 is on a distinguished road
Auragirl09's Avatar
Default 09' Aura XR front passenger door won't open.
I have a 2009 Saturn Aura XR that I have had for over a year and never had any problems with it. The front passenger door opened just fine and about 20 minutes later my friend tried to get out of the car and the door wouldn't open. The locks work just fine. I tried opening it from the inside and the outside and still it wont open. Any ideas??
Add to Auragirl09's Reputation
Rate the quality of this post and help Auragirl09 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Auragirl09 is offline   Reply With Quote
Old 11-26-2010, 06:14 PM   #2
Auragirl09
Auragirl09's Avatar
Default Re: 09' Aura XR front passenger door won't open.
Has anyone had this happen to them? It seems to be hard to find information about on the web.
Old 11-26-2010, 08:03 PM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
ive never heard of this happening to anyone else.
Add to onefunkar's Reputation
Old 11-26-2010, 11:42 PM   #4
PCweber
PCweber is on a distinguished road
I had this happen one time on a Passat rear door. Part of the reason was that the child lock was enable so it could not be opened from the (which should not be an issue on your front door). The ourside handle linkage had failed. I ended up having to figure out a way to get the door panel off from inside with door shut. It has been about 10 years ago and kinda fuzzy but I had to ruin the door panel in doing so.
2008 Aura XR
Add to PCweber's Reputation
Rate the quality of this post and help PCweber reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PCweber is offline   Reply With Quote
Old 11-27-2010, 06:14 PM   #5
jita1
jita1 is on a distinguished road
2008 AURA XE
Default
I had this problem before I had the shift cable problem. It all ties in together (like the doors locking when you shift into drive, for instance). At least one time, I heard the door locks click while on the highway. I was going to take it in but I didn't have the issue anymore until my shift cable needed replacing. There is a recall for the shift cable for your MY. I'm almost willing to bet that's what your problem is.
Add to jita1's Reputation
Rate the quality of this post and help jita1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jita1 is offline   Reply With Quote
Old 11-30-2010, 01:36 AM   #6
99SL2_Modder
99SL2_Modder is on a distinguished road
2009 AURA XR
Funny story. My dad had to back my car down the driveway during the snowstorm last year so we could shovel the driveway. The doors unlocked when he turned the car off, but the drivers door would not open at all. He had to climb over to the passenger side and get out that door instead.
It hasn't ever happened to me at all, but I have heard it happen. I haven't ever had a problem with it since I got it...except for cold weather startups.
Add to 99SL2_Modder's Reputation
Rate the quality of this post and help 99SL2_Modder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99SL2_Modder is offline   Reply With Quote
Old 12-03-2010, 08:54 PM   #7
jita1
2008 AURA XE
Yep, Once, I had to get out from the passenger side too
2014 Chevy Impala 2LT, 3.6L, Blue
2014 Chevy Malibu LTZ, Black (wife's ride)
Then:
2008 Saturn Aura XE, 3.5L V6 (Traded in for Impala)
2011 Chevy Cruze 1LT, Gold Mist Metallic (wife's old ride)
Old 02-27-2011, 01:00 PM   #8
MDxr80
MDxr80 is on a distinguished road
I just had this happen to my 2008 Aura XR. My drivers door first would not latch. After holding the door and driving to the nearest GM dealership, the door then shut. Now the door will not open, and I have to crawl over the shifter, to get out the passenger door.
Add to MDxr80's Reputation
Rate the quality of this post and help MDxr80 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MDxr80 is offline   Reply With Quote
Old 02-27-2011, 06:09 PM   #9
greenman
2009 AURA XE
My money is on the actuator/lock assy since that is the most mechanical & trouble-prone part of the door lock system. A proper Tech 2 diagnosis can confirm it.
Add to greenman's Reputation
Old 02-28-2011, 01:13 AM   #10
WhiteGhostII
WhiteGhostII is on a distinguished road
I had my driver side door not open, so I had to crawl out the passenger door, then after many locks and unlocks it worked again, until I drove down the street to stop by work for a minute, then I got out tried to close the door and it wouldn't latch. Took it across the street to the Chevy dealer, they tried to lubricate it, when the service tech said there were done I went to open and shut it, it bounced off the frame. They determined I would need a new door latch, $400 later, it works =/
Add to WhiteGhostII's Reputation
Rate the quality of this post and help WhiteGhostII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WhiteGhostII is offline   Reply With Quote
Old 02-28-2011, 12:53 PM   #11
Low Saturn
Low Saturn's Avatar
2000 SC2
Hopefully that $400 was covered under warrenty. Especially since its a $70 part and taks a half hour to replace. And hopefully it was replaced with the updated unit.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 02-28-2011, 04:49 PM   #12
greenman
2009 AURA XE
Originally Posted by Low Saturn View Post
Hopefully that $400 was covered under warranty. Especially since its a $70 part and takes a half hour to replace. And hopefully it was replaced with the updated unit.
Agreed. $400 is an outrage. Just replace two door lock actuators on my Ford with aftermarket versions for under $20/each including shipping. I haven't seen aftermarket versions for the Aura/Malibu/G6 yet; but they may exist.
Old 02-28-2011, 06:00 PM   #13
Low Saturn
Low Saturn's Avatar
2000 SC2
They dont.
Heck, the third generation Saturn SC2 uses a similar design latch/actuator design. The car stopped production in 2002 and GM discontinued the part sometime in 2006. And there no aftermarket alternative.
Also the latch has electrically more in it than just the lock/unlock motor. It senses if the door handle has been pulled or if the door latch is ajar. I was curious when I replaced mine why there were so many wires on the electrical connector. An acuator only has two. These have something like six.
Mike
-1991 Turbo SL2.
-2000 SC2
2002 Saturn Vue Front Passenger door wont open walboy Vue Tech 0 04-14-2010 07:01 PM
Passenger door wont unlock / open spartacus46 Vue Tech 5 10-17-2008 12:28 AM
Passenger Sliding door won't unlock or open mommybayer Relay General 2 04-15-2008 01:57 AM
Any way to get passenger door open on an SC2? TIMSPEED S-Series Tech 5 10-08-2007 05:04 PM
Strange-Rear Passenger door will not open from the inside JIM03VUE Vue General 2 06-09-2003 05:31 PM
