Old 11-18-2010, 12:27 PM   #1
PCweber
PCweber is on a distinguished road
Default Any way found to have heated seats come on with remote start?
I have tried leaving the heated seat on when I shut the car off hoping it would revert back to the on position when remote start is used. no dice. Anyone found a trick?
2008 Aura XR
Add to PCweber's Reputation
Rate the quality of this post and help PCweber reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PCweber is offline   Reply With Quote
Old 11-18-2010, 03:38 PM   #2
golftango
golftango will become famous soon enough
golftango's Avatar
Default Re: Any way found to have heated seats come on with remote start?
If I recall correctly, the climate control equipped ones do under a certain temp?
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
http://www.flickr.com/photos/golftango
https://500px.com/golftango
https://www.instagram.com/golftango
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is offline   Reply With Quote
Old 11-18-2010, 04:15 PM   #3
greenman
2009 AURA XE
This guy built himself a control circuit for his G8. Looks a bit complicated if you're not an EE.
http://www.g8board.com/forums/showthread.php?t=38925
Add to greenman's Reputation
Old 11-20-2010, 05:25 AM   #4
99SL2_Modder
99SL2_Modder is on a distinguished road
2009 AURA XR
Negative. They don't even work with remote start. Only when the key is in.
Add to 99SL2_Modder's Reputation
Rate the quality of this post and help 99SL2_Modder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99SL2_Modder is offline   Reply With Quote
Old 11-20-2010, 12:42 PM   #5
I would read the owner's manual to see if there's a provision to set the seat heater(s) ON when using the factory remote start. In extreme cold the plug-in overnight engine block heater helps with morning start-ups so having a nicely pre-warmed seat is a luxury. Safety is always in mind so most remote starts are set to run for a timed period before automatically shutting down the engine. Whether the factory remote has additional features should be coverd in the owner's manual. If not.......
As an aside, my aftermarket DEI remote has additional features to accomodate these functions; to turn on rear defrost, changing run times from 10-minutes (default) to 12, 15 or more minutes, and as a cool down engine run timer for those having a turbocharger and don't want to wait the 3-5 minutes of engine idling after a thoroughly heat soaked turbocharger came off the streets from blasting around. Those with turbochargers are familiar with oil coking the oil feed line going to their turbos right after blasting around and never allowing the engine to cool down with a few minutes of idling to allow oil circulation; turbos stay HOT from all that exhaust gas flowing through and spinning the rotor so oil not circulated cooks in place resulting in coke deposits to choke off oil flow, ending in blown turbos. The after run feature of some remote starts (like mine) allows the driver to lock the doors and run away to hang out wit da boys while the engine runs a few minutes to continue oil circulating through the turbo's oil feed to prevent coking. Its wishful thinking to have a turbo in my L300 just so I can use this feature. The additional feature of turning on the rear defroster could be used to switch on a seat heater or two.
Remote Start Turns on Heated Seats? ddollhoff 2008 Vue 4 01-22-2010 12:48 PM
remote start with heated seats den98xes Vue General 2 01-16-2009 02:40 PM
remote start & heated seats den98xes 2008 Vue 3 01-11-2009 05:04 PM
Heated Leather Seats, Remote Start, Paint Quality IowaVue 2008 Vue 40 05-28-2008 11:23 AM
Heated seats? hoob Vue Red Line 25 01-24-2006 12:08 AM
