Old 08-28-2010, 11:07 AM   #1
thrshr
thrshr is on a distinguished road
thrshr's Avatar
Default On the topic of strut braces......
I have been looking around for info/options, the GM parts direct seem to touch/rub/be in contacct with the hood. I was looking and found this one, I want some feed back from you guys to see if you see any issues to cross use this to our Aura's.
http://racinglineperformance.com/sho...&idcategory=17
Add to thrshr's Reputation
Rate the quality of this post and help thrshr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thrshr is offline   Reply With Quote
Old 08-28-2010, 11:09 AM   #2
thrshr
thrshr's Avatar
Default Re: On the topic of strut braces......
the second picture looks pretty low in the engine bay in a way that looks good. does not seem that it would cause any clearance issues...
Old 08-28-2010, 09:57 PM   #3
3 Rings
3 Rings is on a distinguished road
3 Rings's Avatar
2008 AURA XR
2007 SKY Red Line
I'd be interested to hear if it fits the Aura, as well. Have you contacted the vendor to see if they know?
Add to 3 Rings's Reputation
Rate the quality of this post and help 3 Rings reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
3 Rings is offline   Reply With Quote
Old 08-29-2010, 03:39 PM   #4
Eric37a
Eric37a is on a distinguished road
It fits fine, no rubbing. I have one and the only problem was there was a small bolt in the way on the driver side tower. The brace has a hole to let the bolt through, but it didn't line up exactly. I just cut the bolt off since it was for a fluid reservoir that our cars don't have.
Add to Eric37a's Reputation
Rate the quality of this post and help Eric37a reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eric37a is offline   Reply With Quote
Old 08-29-2010, 04:55 PM   #5
thrshr
thrshr's Avatar
When I did the eibachs I was curious to what that bolt was for, what vehicle is that resevoir for? I knew it was not used considering the bolt was painted to match the car and all other bolts were alloy in color.
Old 08-30-2010, 01:38 PM   #6
jimmyfloyd
jimmyfloyd is on a distinguished road
2007 AURA XR
Pretty sure that bolt is for the clutch fluid reservoir that the G6 had, and just got designed into the aura (assuming it's the same tooled part)
Add to jimmyfloyd's Reputation
Rate the quality of this post and help jimmyfloyd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimmyfloyd is offline   Reply With Quote
Old 08-31-2010, 12:33 AM   #7
Askspot
Askspot is on a distinguished road
I have the same one in my car!!!! I'll look tomorrow and see if there are any rub marks. I doubt it. It sits very low in the car. You will have the grind out the hole a little bit on the driver's side because of that ground post on the stop of the strut tower, but no big deal hit the bracket with some paint so it don't rust and you're good to go.
Add to Askspot's Reputation
Rate the quality of this post and help Askspot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Askspot is offline   Reply With Quote
Old 09-02-2010, 12:54 AM   #8
thrshr
thrshr's Avatar
sounds good to me. I compared pics of the two braces in the engine bays and this one looks about right.
Old 09-02-2010, 07:38 AM   #9
PyratWesly
PyratWesly is on a distinguished road
PyratWesly's Avatar
2007 AURA XR
I have that very part on my Aura and it fits fine, no rubbing. I had to widen one of the holes to fit over a bolt sticking up off the driver side tower.
Pictures here, scroll down a bit and you'll see it installed:
http://www.saturnfans.com/forums/sho...d.php?t=152976
Add to PyratWesly's Reputation
Rate the quality of this post and help PyratWesly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PyratWesly is offline   Reply With Quote
Old 09-27-2010, 09:46 PM   #10
carlover
carlover is on a distinguished road
2008 AURA XR
The question is: Does it improve ride and handling?
c
Drive like you mean it, keep the rubber side down.
Add to carlover's Reputation
Rate the quality of this post and help carlover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carlover is offline   Reply With Quote
Old 09-28-2010, 12:48 AM   #11
Askspot
c
YES! I took it off and on and my cousin drove it and he did not know if it was on or off and I tried to be tricky about it too. He could tell ever time.
Old 09-28-2010, 06:48 PM   #12
carlover
2008 AURA XR
OK then. I guess I have to get one. But if this car handles much better I may scare myself. I have had none of the rattle and clunk problems described by other posters. I had a 99 Ford Contour SVT that handled fairly well but the XR would spank it on a road course. Just amazing. And on stock tires.
Old 09-28-2010, 08:41 PM   #13
99SL2_Modder
99SL2_Modder is on a distinguished road
2009 AURA XR
Umm, it doesn't handle all that well imho.
Add to 99SL2_Modder's Reputation
Rate the quality of this post and help 99SL2_Modder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99SL2_Modder is offline   Reply With Quote
Old 09-28-2010, 09:26 PM   #14
carlover
2008 AURA XR
Really! For a mid-size FWD sedan? Are you driving an Aura XR?
I'm sure Phaeton Driver will agree with me if he is still lurking here. C'mon PD, weigh-in here.
Old 09-29-2010, 06:43 AM   #15
99SL2_Modder
2009 AURA XR
For a mid-size FWD sedan, it's ok, but not great. There's a LOT of improvements to be made on it.
Then again, most of my cars have always handled extremely well, so maybe it's just me.
Then again, these stock tires don't hold the road at ALL. I drive aggressive.
Old 09-30-2010, 12:45 PM   #16
carlover
2008 AURA XR
What tire pressures are you running? If you are inflating to factory recommendations, try putting 38psi in the fronts and 35psi in the rears and get back to me. It makes a big difference. If you already run higher pressures I don't know what to say. I drive fairly aggressively and have driven/owned a few fast cars. You might be able to squeeze better handling out of the car by lowering and stiffening, sacrificing ride. Just not my cup of tea for a daily driver. I am still quite impressed with the car and the stock (independent rear) suspension.
Old 10-02-2010, 04:42 AM   #17
99SL2_Modder
2009 AURA XR
My old car was dropped on coilovers with a FSTB and an upgraded rear adjustable swaybar on full hard, and solid motor mounts. Believe me, sacrificing ride quality is nothing for me, because I've yet to ride in a DD that was as poor a "quality" as that was. It handled like it was on rails though.
Old 11-02-2010, 05:45 PM   #18
carlover
2008 AURA XR
I ordered one of these yesterday. Once I get it installed I will report back.
Old 11-22-2010, 09:16 PM   #19
carlover
2008 AURA XR
Took two weeks for the item to arrive. Finally got a chance to install it this weekend. I had to take the extaneous bolt off with my Dremel cut-off wheel as the hole provided in the left plate did not align. I added flat washers, which I think they should have included. I don't corner hard very often so can't comment on handling but the ride seems a bit more solid and composed over uneven surfaces.
Old 12-07-2010, 08:29 PM   #20
carlover
2008 AURA XR
Oh, yeah! This thing really helps on sharp, low-speed turns. I thought the car was good before but now it's amazing. Nice looking, too.
c
New Strut Braces' -> New Rattle.. - 2001 Sc2 01SIlverSc2 S-Series Tech 4 04-04-2007 06:37 PM
Strut tower Braces????? kaviation Ion Tech 11 02-05-2007 06:16 PM
Front strut tower braces? any one got one? BlueIonDriver Ion General 4 03-29-2004 11:55 AM
Anyone tried Ractive strut braces? FireMate Mods and Performance 8 04-22-2002 12:15 PM
Strut Braces TheRayMan Miscellaneous Tech 2 07-19-2001 05:39 AM
