Old 12-04-2009, 10:22 AM   #1
Leafy
Leafy is on a distinguished road
Leafy's Avatar
Default Rotella Synthetic 5w40
Ok, i know I've read on here that a lot of people like the rotella synthetic oil in their cars, I have only been able to find it in 5w40. I have no problem with the 5 viscosity number since its starting to get to be that time of the year up here. its the 40 molecule size that worries me a bit. I know the cars are designed for 30 but after 150l miles have my tolerances opened up enough to use 40 without any issues. Old Nuc I await your response.
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 12-04-2009, 10:45 AM   #2
manualman
manualman is on a distinguished road
1995 SL
Default Re: Rotella Synthetic 5w40
Are you having trouble holding adequate oil pressure with 30 weights?
Or are you just hoping the thicker stuff won't squeeze past the piston rings and burn as fast?
Add to manualman's Reputation
Rate the quality of this post and help manualman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
manualman is offline   Reply With Quote
Old 12-04-2009, 10:49 AM   #3
Leafy
Leafy's Avatar
No I dont believe I'm really having either of those issues (as if I have an oil gauge). I've just seem to read a lot on here about people using the rotella synthetic to great success, and its cheaper than mobile 1. I just want to make sure that the people who have been using the rotella havent been using 30.
WPI class of '12 ME
Old 12-04-2009, 11:32 AM   #4
The 5w-40 brackets the 5w-30. You can use it but you need to look up the physical differences between the 5w-40 you want to use and the specified oil.
There are several different formulations of 5w-40 oils and they are not actually interchangeable.
Old 12-04-2009, 12:39 PM   #5
HStockSolo
HStockSolo is on a distinguished road
HStockSolo's Avatar
My SC2's engine had Rotella Synthetic 5W40 in it when I spun the rod bearing. I won't use a xW40 oil again. I might go with Mobile 1 0W30 if I re-ring the engine this winter. I have a bunch of different weights in it right now (10W30, 10W40, 0W30, and 5W30, and 5W40) since it has been gobbling it up. I've just been adding whatever leftover oil I have had on hand. Keeping it filled is more important than specific type. As far as recommendations, I haven't had trouble with Valvoline Maxlife 10W30/5W30. I wouldn't use the 10W weights in winter.
1995 Saturn SC2 - ST(X)ish
1994 BMW 325i Sport
www.furrin.org
Add to HStockSolo's Reputation
Rate the quality of this post and help HStockSolo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HStockSolo is offline   Reply With Quote
Old 12-04-2009, 01:01 PM   #6
Leafy
Leafy's Avatar
yeah so I'm thinking of taking it back, I'm only using just over a quart every 3000 miles. I really dont feel like spending 8 dollars more a gallon on mobile 1, so I check valvoline.
WPI class of '12 ME
Old 12-04-2009, 01:30 PM   #7
Are you sure the Mobil 1 bottles are gallons? Rotella-T is a truck oil, typically dispensed in gallons. Oil for cars like Mobil 1 5w30 often comes in 5-quart bottles. 'Round here, Mobil 1 is usu. $5.50-6.00 a quart, and Rotella-T Syn is about $20 a gallon, so only a coupla bucks cheaper than M1.
Add to madpogue's Reputation
Old 12-04-2009, 02:12 PM   #8
Leafy
Leafy's Avatar
Yeah I realized that in the store. I got valvoline synthetic it comes in a 5.28 quart bottle. *******s couldn't have added a quarter quart more?
Anyways I'm sitting here waiting for the pistion soak, damn valve cover is leaking into the #2 cylinder again, and my plugs are white on and around the two poles but black up inside. That means I'm running lean and burning a bit of oil right?
Old 12-04-2009, 02:58 PM   #9
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
I use the Rotella T 5W40 in everything but my saturn. For 2 reasons....
There is a lot is Zinc in the oil even though it is rated "S" as well as "C" and at 147000 miles on the stock CAT I don't want to kill it The zinc fouls them up over time. The latest oil spec was for removing some(or most) zinc and phosphorus to guarantee the CAT's last their 150,000 warranty period.
Also a guy I work with, used the wrong oil in his saturn and killed the motor. Top end failure I believe from oil starvation.
I do use it to top off though since I seem to always have a partial gallon lying around.
In my info gathering the penzoil platnum 5W30 uses the same base stock as the rotella so I use it. (helps to be owned by Shell as well)
I use the rotella in: (and love it) Been using it since it first came out
Motorcycles 1998 ZX9R, 883 sporty with 1200cc kit
Jeep CJ7
SS396 Chevelle
94 RAM Diesel
Old 12-04-2009, 07:52 PM   #10
Leafy
Leafy's Avatar
I liked the rotella because it has lots of good lubricating zinc, dont care if the cat dies. Still waiting on the piston soak.
WPI class of '12 ME
Old 12-04-2009, 09:14 PM   #11
bumpdraft
bumpdraft's Avatar
1998 SW2
Jeep CJ7
SS396 Chevelle
94 RAM Diesel
Rotella
Why the 5W40? Don't the diesels like 15W40? Use it in my 2-stroke dirtbike tranmissions, F-350 Diesel, Trooper Diesel, rototiller, lawnmower, chipper/shredder.
For the SC2, as soon as I learned all the zinc was removed from oil, been adding a little ZDDPlus to semi-synthetic...just to make me feel better.
I'd be happy to stop adding ZDDP if someone could assure me the '98 SC2 engine had valve stems and timing chain designed for use without zinc.
...In the Rust Belt, the entire exhaust system falls off the car before 150,000 miles. Not too concerned 'bout the Cat. warrenty
Add to bumpdraft's Reputation
Old 12-04-2009, 11:08 PM   #12
Use Amsoil 5w-30 Heavy Duty Diesel. You get all your zinc and phosphorus and a real PAO synthetic. And the engine seems to like it just fine.
Old 12-04-2009, 11:11 PM   #13
Leafy
Leafy's Avatar
and how much does that cost? 50 dollars a gallon?
WPI class of '12 ME
Old 12-04-2009, 11:41 PM   #14
eRic 02sc2
eRic 02sc2's Avatar
D'oh! mine had a mixture of Saturn and Valvoline 5W30 when it spun all 4 con-rod bearings. S-Series need a baffled oil pan or an oil accumulator for sustained cornering g's
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-05-2009, 12:20 AM   #15
1996SL11.9L
2002 SL1
Most engines built after the late 80's were of the roller cam variety. They used less horsepower and were not as finicky as a flat tappet cam for lube and cam break-in. Since they are roller they can use less zinc etc because it's a roller. GM has been using roller lifters since the early 80's Mopar since the late 80's on small engines 2.2L, 2.5L...and early 90's with the V8's (Magnum engines went roller)
I tried confirming our cam's are roller cams but can't. May be because its no big deal anymore.
The 5W40 oil has the same specs as the 15W40 plus it flows at a lower temp better. The rotella synthetic is not a PAO but is also not a Dino oil. It is made from the slack wax removed from crude oil during the refining process. So...even though it's a groupIII synthetic it never originated from an oil base.
Oil and oil addatives are a touchy subject (just like who makes the best oil filters)
My cummins has a 3 QT oil galley and it takes a few seconds to build pressure because it must first pressurize the main galley. With the 5W40 I get oil pressure twice as fast as 15W40 anything.
Old 12-05-2009, 12:23 AM   #16
Leafy
Leafy's Avatar
91-99.5 flat tappet. 99.5-03 roller. Of course the only put the roller in the ****ty head, it would have been great if they'd done it to 1st and 2nd gens.
WPI class of '12 ME
Old 12-05-2009, 12:25 AM   #17
1996SL11.9L
2002 SL1
Flat tappet....... use the addative, go with the diesel oil or hope the oil companys did their homework on haw to get the same quallity with a different product.
Old 12-05-2009, 12:58 AM   #18
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Why couldn't you use 3rd gen cams in a 1st/2nd gen head? Or do you need the corresponding parts/head too so you can't just swap cams?
Sorry, my knowledge of valvetrains is pretty shallow.
2007 Ion 2 Quad Coupe 5-speed manual 182K miles
2007 Chevy Equinox LT 194K miles
2018 Chrysler Pacifica Touring L 41K miles
Add to ruley73's Reputation
Old 12-05-2009, 01:55 AM   #19
You have to swap the entire head, as a minimum, and then deal with intake and exhaust.
All you get out of the roller system is more reciprocating mass and more parts.
Old 12-05-2009, 01:58 AM   #20
Leafy
Leafy's Avatar
all that and you get the ****ty flowing 3rd gen head. I man the 1st and 2nd gen flow like absolute crap as it is, compared to other 4 bangers. This is why full bolt on's to this motor only nets you 10-15 hp and on a B motor civic they net you 20-25.
WPI class of '12 ME
Rotella T Engine Oil.... gm7 S-Series Tech 37 08-28-2019 11:01 AM
Keep using Rotella Synthetic? ScottSaturn83 S-Series Tech 9 06-20-2008 10:58 PM
Shell Rotella Recommendation, inquiry Luke S-Series Tech 24 01-19-2007 03:52 PM
Shell Rotella T 5W40 good oil for the saturn 1.9? turbobuick33 S-Series General 25 11-10-2005 08:45 PM
Anyone ever ran Rotella T 15w-40 WILMONT S-Series Tech 6 04-03-2005 09:46 PM
