Old 09-17-2008, 10:58 AM   #1
Ackpacket
Ackpacket is on a distinguished road
Default Squeaking noise
There is a terrible squeel coming from my engine bay. It's obviously a pulley or the belt slipping but I can't tell which. Recently replaced water pump and got coolant all over the belt, but sooner or later the belt should have dried up right?
I think if it's not just the need for a new belt, the leaking coolant from the old pump could have corroded a pulley or something?
What are your thoughts and guesses?
Here's the kicker. The sound is only there when the engine is stone cold. Gone after things have been heating up for a while.
Thanks for your comments guys.
2002 SL2 126kmiles.
Add to Ackpacket's Reputation
Rate the quality of this post and help Ackpacket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ackpacket is offline   Reply With Quote
Old 09-17-2008, 11:23 AM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: Squeaking noise
Does it do it all the time or only at start up for a couple minutes?
Saturnless...
Old 09-17-2008, 11:57 AM   #3
2002 SL2 126kmiles.
Antifreeze is a lubricant. The belt is now ready for replacement and all of your pulleys require a very good cleaning as the stuff does not wash off real easy. Formula 409 or a similar kitchen grease cutter and water will do the job. The pulleys must be dry before you install the new belt or you will ruin another belt. If you have both power steering and A/C the belt length is 778 and not 780 if you are buying aftermarket.
Old Chinese proverb: Education is expensive.
Old 09-18-2008, 07:15 PM   #4
banjo
banjo is on a distinguished road
I've had the Tensioner pulley go bad and would only squeel real bad for a minute or so after a cold startup, especially in the winter months here in FL.
Bill
Add to banjo's Reputation
Rate the quality of this post and help banjo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
banjo is offline   Reply With Quote
Old 09-19-2008, 01:40 AM   #5
Ackpacket
Only at startup for a couple of minutes
If the antifreeze lubed the belt permanently then why does it go away after the engine (and subsequently the pulleys and belt) gets warm?
2002 sl2 DOHC 126k miles
'squeaking' noise on cold starts redcannon S-Series General 8 10-09-2008 11:25 AM
Stuck in Gear and squeaking noise salix51 L-Series Tech 2 07-23-2008 03:29 PM
Squeaking Noise twostirish222 2008 Vue 0 05-14-2008 08:48 AM
Squeaking Noise from Wheels The Critic S-Series Tech 4 06-18-2007 07:07 PM
Squeaking Noise From Wheel mr. ed S-Series Tech 6 01-28-2004 12:11 AM
