Old 01-10-2008, 07:20 PM   #1
russellhome
russellhome is on a distinguished road
russellhome's Avatar
2004 VUE 3.5L
Default '04 Vue Radio stopped working (but CD/MP3 still works)
Well - it took just over 3 1/2 years, but my perfect record of having "no problems" with my '04 Vue has come to an end. It is certainly not a show stopper -- just a radio issue.
I have the 6 speaker CD/MP3 player option - and no Onstar. A few days ago, the radio stopped working. The unit appears to function properly (i.e. you can still select AM/FM radio and adjust to different stations -- just no sound comes out. Also - playing CD and MP3 disks works fine. Just no sound when switched over to the radio.
Any chance the antenna just came loose or is this some other problem? Could it be an Amp fuse? Has this happened to anyone else?
I am now into the extended warranty period - so I'm assuming this may be covered - but likely with some kind of deductable. The factory unit was fine for me -- but I do need a working radio. But if the cost to fix is too much, I may just go for an aftermarket head unit.
Add to russellhome's Reputation
Rate the quality of this post and help russellhome reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
russellhome is offline   Reply With Quote
Old 01-10-2008, 07:37 PM   #2
kcookie
kcookie is on a distinguished road
Default Re: '04 Vue Radio stopped working (but CD/MP3 still works)
Hi Russell-
My husband and I had the same problem several months ago with our '04 Vue...it was one of those uh-oh moments. It stopped producing sound only when using the radio function, the CD/MP3 player seemed to work just fine. (for record we also have the upgraded speakers, in case this matters electrically). The good news is, it spontaneously fixed itself after several car stops and starts (Parked, went into store, came out, drove around, parked at post office, etc...). We have not had a repeat problem since (knock on wood). My feeling is there is either a fuse or short problem somewhere in the antenna system. I hope yours fixes itself, too.
Cheers.
Kari
Add to kcookie's Reputation
Rate the quality of this post and help kcookie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kcookie is offline   Reply With Quote
Old 01-10-2008, 11:32 PM   #3
russellhome
2004 VUE 3.5L
Thanks for posting Kari
It sounds like the same sort of issue. However, it has been several days since mine stopped working. I doubt I'll have the luck you did. It is kind of a quirky problem -- the unit seems to be working fine. I may just pull the thing out and reset all of the connection cables. Who knows - maybe it will be a simple fix.
... and Welcome to the forum.
Old 01-11-2008, 12:20 AM   #4
GMDad
GMDad will become famous soon enough
The radio in our '04 quit a couple of months ago as well. We pulled the radio fuse and it kinda reset itself and worked for another week or two and then quit again. I ended up with a fairly inexpensive aftermarket radio in there now. I purchased the mounting bracket and adapter harness and it looks real good in there and plays just fine for us. I believe these radios were noted for having issues after a length of time. Good Luck
Add to GMDad's Reputation
Rate the quality of this post and help GMDad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GMDad is offline   Reply With Quote
Old 01-18-2008, 08:03 PM   #5
russellhome
2004 VUE 3.5L
Originally Posted by kcookie View Post
Hi Russell-
... I hope yours fixes itself, too.
Cheers.
Kari
Believe it or not, my problem went away by itself, too. After approx. 2 weeks with no radio - it just started working again. Do I detect a trend here? We will see how long it lasts. I will probably still look to getting a new system - but at least now I can take my time and look for a good deal.
A self-reparing vehicle. Who would have thunk it. I wish all problems would just fix themselves.
Won't turn over & key fob stopped working while wiring radio yottabit S-Series Tech 3 06-20-2009 08:56 PM
XM radio stopped working... REDLINE_IT Vue General 3 06-28-2008 02:14 PM
2003 Vue stopped working scc4fun Vue General 12 02-19-2007 06:55 PM
radio stopped working oldgoat S-Series General 3 08-11-2005 05:24 PM
My odometer stopped working... well, sometimes works.... DJboozeAlot Miscellaneous Tech 10 03-18-2005 07:14 AM
