Old 09-29-2007, 12:18 PM   #1
Sohc_dreamer
Sohc_dreamer is on a distinguished road
Dizzy another noob question(difference between pre 95 intakes and post 95 intakes)
whats the difference between pre 95 intakes and post 95 intakes on a sohc
Add to Sohc_dreamer's Reputation
Rate the quality of this post and help Sohc_dreamer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sohc_dreamer is offline   Reply With Quote
Old 09-29-2007, 12:47 PM   #2
JADEDSL2
JADEDSL2 will become famous soon enough
JADEDSL2's Avatar
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
Default Re: another noob question(difference between pre 95 intakes and post 95 intakes)
On a SOHC? UH, the 95+ SOHC's have the DOHC intake, and multi port fuel injection. No more POS TBI 85hp after 94.
SOHC
91-94 TBI single injector 85hp POS
95-2002 MPFI 4 injector 100hp semi-POS (still missing a cam)
"1G8ZJ5472MZ134321"-my Jaded, I will never forget.
"1G8ZF5594PZ249184"-Trinity, for three are now one.
Add to JADEDSL2's Reputation
Rate the quality of this post and help JADEDSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JADEDSL2 is offline   Reply With Quote
Old 09-29-2007, 12:53 PM   #3
Sohc_dreamer
ok thanx cause i was wondering if it cauld be converted for use on a 92 sl1
Old 09-29-2007, 12:55 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
Open the hood on a 1991-1994 SOHC and a 1995+, the difference will be obvious. Also no one makes an aftermarket 1991-1994 SOHC intake.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 09-29-2007, 12:57 PM   #5
Sohc_dreamer
Question Re: another noob question(difference between pre 95 intakes and post 95 intakes)
i know no body makes one thats why i was wondering if a 95 one would fit
what about transplanting a 95+ engine in to a 92 body w/transfered wireing
Old 09-29-2007, 01:03 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
You cant swap a 1995+ SOHC into a 1991-1994 SOHC. But can swap a 1991-1992 DOHC into your 1992 SOHC.
You would need:
  • 1991-1992 complets DOHC motor (including all brackets and manifolds)
  • MP3 or MP7 transmission (depending on weather you have a manual or auto)
  • 1992 DOHC PCM
  • 1991-1992 DOHC instrument cluster
  • DOHC throttle cable
  • 1991-1994 DOHC fuel pump
  • 1991-1992 engine wiring harness
  • 1991-1992 exhaust header and downpipe
I did a very similar swap in my 1993 SW1
http://www.cardomain.com/ride/484404
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-29-2007, 01:09 PM   #7
Sohc_dreamer
ok that seems kinda exspensive
Old 09-29-2007, 01:11 PM   #8
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
You would need:
  • 1991-1992 complete DOHC motor (including all brackets and manifolds)
  • 1992 DOHC PCM
Sure you could swap a 95+ SOHC into a pre 95 SOHC car....just use the same procedure as the DOHC swap, but use all post 95 SOHC parts for it, right? I wouldn't do it....just saying, it has to be possible...
Old 09-29-2007, 01:14 PM   #9
Sohc_dreamer
Happy Re: another noob question(difference between pre 95 intakes and post 95 intakes)
ok i'm just wondering right now since i am unemployed at the moment
but when i get some money it will be a dohc swap
Old 09-29-2007, 01:32 PM   #10
Low Saturn
Low Saturn's Avatar
2000 SC2
These only one speed bump in that plan. Depending on the year of the car, a 1991-1994 MFPI PCM would be required to run a 1995+ SOHC engine in a 1991-1994 car. A 1991-1994 MPFI SOHC PCM doesnt exist.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-29-2007, 01:35 PM   #11
Low Saturn
Low Saturn's Avatar
2000 SC2
There's a lot of inexpensive options. Depending on where you live, junkyard part prices can vary. It possible to get everything needed from $100 to well over $2000. Its also possible to just buy an entire car to get the parts you need. You can find cars that have body damage but no drivetrain damage for really cheap in craigslsit.org. I've bought entire running Saturns for $0 to $300.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-29-2007, 01:43 PM   #12
Sohc_dreamer
ok thanx
Old 09-29-2007, 01:57 PM   #13
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
Of course it doesn't. but if you're dragging over a 95+ sohc engine, you'll of course need the engine harness, and of course also need the pcm. It's not a speedbump, you just have to grab a pcm from the same car as the newer engine, just like you'd have to do with a DOHC anyway.
Old 09-29-2007, 02:21 PM   #14
Low Saturn
Low Saturn's Avatar
2000 SC2
The PCM has to match the recipient vehicle, not the donor. A 1995 PCM in a 1991-1994 would cause another entire headache of problems. And if an automatic transmission is involded, then you're really screwed.
When doing a DOHC swap you would need the DOHC PCM from the same year the DOHC engine is going into, not the year the DOHC came out of.
IE:
Say you have a 1993 SL1 and have a 1998 DOHC engine. You need a 1993 DOHC PCM. If you have a 1997 SW1 and a 1993 DOHC engine, you'd need a 1997 DOHC PCM.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-29-2007, 03:28 PM   #15
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
IE:
Yeah, I understand what you're saying, and I'm not meaning to argue with you, I know you have experience with this.
But I have a 93 SL manual base, using a 99 DOHC engine AND the 99 DOHC PCM from the car it came out of, that I drive everyday. (see my gallery) Yes, it is a major headache to do, and your method is MUCH easier, I'm just saying it's possible, that's all. I'm definitely NOT saying it's a good idea...trust me on that one!
Old 09-29-2007, 04:43 PM   #16
eRic 02sc2
eRic 02sc2's Avatar
the difference is no one makes an aftermarket performance intake for the 91-94 sohc with tbi. the 95-02 sohc mpfi can use the same part as a 91-99 dohc so you have options.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 10-02-2007, 04:14 PM   #17
You had to swap in a whole dash, just to drive the right cluster, IIRC, which involved some structural surgery, right?
Add to madpogue's Reputation
Old 10-02-2007, 10:34 PM   #18
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
Yeah, technically. Mechanically, it had nothing to do with anything. I swapped the whole dash so the cluster had a place to "fit" in properly. It wasn't so bad really, lots of planning, and looking, but it only took 3 minutes of "cutting" to fit it in. Wasn't that bad.
Old 10-03-2007, 12:01 AM   #19
bottlecap
bottlecap is on a distinguished road
bottlecap's Avatar
1997 SW2
when i supercharged my 94 sl1 i moded a carberator intake to fit over the tbi unit. was quite simple. and it was a universal part from auto zone.
i also added a few injectors to keep up with the supercharger.
I did this is 94 before they had the mpfi set up on the sohc other wise i would have swaped the intake and harness ect.
In hind site it would have just been better to have bought a twin cam to start with.
Add to bottlecap's Reputation
Rate the quality of this post and help bottlecap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bottlecap is offline   Reply With Quote
Question About intakes shiffy Ion Mods 5 08-23-2008 03:36 PM
Difference between RAM and Cold air intakes? Corith Mods and Performance 3 07-29-2003 03:47 PM
My first post. Topic Air intakes. cloud819 Mods and Performance 7 03-10-2003 11:19 AM
Suggestions/recommendations for oil, intakes, and an alternator question 94sc293sl1 Ion General 4 06-21-2002 11:09 AM
pre 1995 SOHC Intakes Whelan S-Series Mods 0 03-09-2001 02:28 AM
