Old 06-30-2019, 12:06 AM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default 2005 Saturn ION dies while driving and after its little colder it starts again
2005 Saturn ION - manual - 170k miles.
This car dies while driving .....but when you let it cool down a little ..it will start again.
What could be the reason ?
Why would it die while driving...and there is no specific time after which it dies.
But after a while it dies ..it always starts up
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 06-30-2019, 10:53 AM   #2
bluesl2
bluesl2's Avatar
Default Re: 2005 Saturn ION dies while driving and after its little colder it starts again
Flakey crank sensor maybe? You need to determine what you are lacking after it stalls. Check for spark. Could possibly be a fuel pump going bad as well. See if you have fuel pressure or listen for the fuel pump when you cycle the key.
Add to bluesl2's Reputation
Old 06-30-2019, 04:09 PM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Car dies while driving when it hot/warm ..has nothing to do with timing correct?
could it be coolant temperature sensor because it is related to temperature?
Old 07-02-2019, 09:28 PM   #4
bluesl2
bluesl2's Avatar
Does not have anything to do with the timing of the motor. I highly doubt that the coolant sensor would be the issue.
Old 07-04-2019, 04:23 AM   #5
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Just to give little more info...
There is no consistency as to how long it will drive before it dies. Sometimes it last for 40 miles and sometimes just 10-15 miles before it dies.
Does it give you better idea as to what could be wrong?
Old 07-04-2019, 02:40 PM   #6
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Is the check engine light on as it should be with the key on engine off? Does the engine crank after stall and while does not start?
Possible bad powertrain relay number 29 or other high resistance connection.
Add to bern's Reputation
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-05-2019, 02:55 AM   #7
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Lets assume ..crank sensor is bad...if so is it tough to replace it?
Old 07-09-2019, 12:36 AM   #8
Although the engine is not identified by the OP it's most likely a 2.2L ECOTEC. The symptoms previously described are similar to those mentioned in the L-Series forum when a crankshaft position (CKP) sensor is displaying intermittent failures. With that in mind, the CKP sensor should be on the block behind the starter motor and also near the oil pressure switch.
The starter must be removed to have access to the CKP sensor. Removing the starter's upper mounting bolt is somewhat awkward. It's more difficult to reinstall it. If you intend to replace that sensor then be patient with reinstalling the upper mounting bolt. It may take a number of attempts to get the bolt threads started correctly.
325,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 07-09-2019, 05:47 PM   #9
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
I feel that the coil pack is more likely to be bad than the crankshaft position sensor, but the symptoms could stem from either one. Also, check the wiring harness near the oil filter housing for fraying.
Is the Check Engine light on? If so, get the code numbers and post them here. That would be most helpful.
2007 Ion 2 Quad Coupe 5-speed manual 182K miles
2007 Chevy Equinox LT 194K miles
2018 Chrysler Pacifica Touring L 41K miles
Add to ruley73's Reputation
2002 Saturn SL Starts but then dies. Teela S-Series Tech 16 06-11-2016 11:25 PM
1999 saturn sc1 starts then dies streetrodder51 S-Series Tech 2 03-21-2014 09:40 PM
2000 Saturn sl2 starts then dies Adallen S-Series Tech 7 07-25-2011 04:29 PM
Saturn SL1 2002 starts then dies PatrickB S-Series Tech 4 07-24-2011 03:08 PM
96 Saturn SL runs dies then starts roscoemegan96sl S-Series Tech 21 08-16-2008 01:01 AM
