#21 |
![]() Join Date: Jun 2007
After replacing both front strut assemblies with monroe quickstruts, I'm getting a creaking sound from the right side when I turn the steering wheel.
I'm hoping that after the springs settle, this noise will go away. I checked the location of the spring end (where it seats on the rubber) and it's not pushing one of the rubber bumps up to the metal. Any suggestions for what to do if the problem doesn't fix itself? Thanks |
#22 |
![]() ![]() ![]() Join Date: Sep 2005
My Monroe SensaTrac (regular, not quick stut) makes the same noise on the right strut and it has not gone away and I installed the strutes over a year ago. I just ignore it. Also, in my case I used after market springs.
#23 |
![]() Join Date: Jul 2015
Excellent Post Barnowl, THANK YOU and thanks to those who created this extremely helpful website !!!
Wanted to share some helpful information I've collected; perhaps others may find this useful: Saturn / GM Parts 801 W Hwy 83 McAllen, TX 78501 (866) 423-9926 8am - 6pm M-F 8am - 4pm Sat. gmpartsonline dot net Genuine Original Equipment Replacement Parts GetSaturnParts dot Com Heritage Cadillac 716 Belair Road Bel Air, MD 21014 800-743-5376 Harbor Freight Bushing Press - Bench Shop Press - $79.99 6 ton A-Frame Bench Shop Press Rear knuckle-to-lateral link bolt / Hardware: I found the following from an earlier post: M14x2x230 and found GM OEM part number to be: 11516464 Found: gmpartsonline dot net for above part number Lateral rod WASHER (Left or Right): Part Number: 10268814 Lateral rod NUT (Left or Right): Part Number: 11516382 OTHER GOOD POSTS on SATURNFANS: 2 good post w/ detailed info & illustrations: Subject titled: Energy Suspension bushings installation, thoughts, PICS! Thread=192814 Subject titled: How-To; SC1 Suspension Bushings Replacement Thread=2096421 Other good posts on SATURNFANS: Subject titled: S-Series Torque Specifications Thread=44221 Subject titled: how do you adjusting rear wheel toe in? Thread=131483 Subject titled: how to replace lateral links: Thread=184941 Special tool, people here have called it, that connects FRONT "Lateral Link" to cross-member: homedepot dot com Husky T55 Torx 3/8 in. Drive Bit Socket $1.97 /each NOTE: I've read in another post this Torx bolt isn't used to adjust alignment - only the back or rear bolts from REAR Lateral Link to Cross-member are adjusted during the alignment process. Subject titled: Re: Struts and Shocks - Saturn SC1 Thread=193835 Subject titled: Strut Replacement With Pictures on a 2000 SW2 Thread=67077 Maybe helpful for some: Check: aftermarketsuspensionparts dot com Energy Suspension Bushing Options: Rear End Control Arm Bushing Set Part Number: 18.3102 for $53.98 OR HyperFlex Master Kit Saturn S Series 91-02 Part Number: 18.18101 for $99.40 energysuspensionparts dot com |
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2010
1997 SW1
#25 |
I still have the car and now the miles are 166K and on occasion the right tower will make the rubber noise but the left tower never has. I torqued all the nuts with the same torque wrench to 21 fl lbs. I just re-checked them a few minutes ago.
2000 LS2 3.0 V6 Timing Belt Replacement Pictures | aaront | L-Series General | 11 | 09-26-2016 12:32 AM |
97 SW2 Strut replacement | gregorye70 | S-Series Tech | 6 | 08-15-2008 11:48 AM |
Strut mount problems 00 SW2 | opus | S-Series Tech | 7 | 06-13-2007 12:21 AM |
Strut Replacement How-To 2000 SW2 | BarnOwl | S-Series Tech | 2 | 12-17-2005 06:13 PM |
'97 SW2 Strut Replacement & Wheel Alignment | stu | S-Series Tech | 9 | 11-02-2005 06:16 PM |
