Old 04-22-2009, 09:56 AM   #21
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default Re: Check Coolant Level warning?
It's on 75% of the time. When engine gets up to operating temp, it comes on & stays on.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 04-22-2009, 12:10 PM   #22
AFLAC42
AFLAC42 is on a distinguished road
Just a thought. I know you said that the dealer did a pressure check, but have you thought to gahnge the radiatior cap? I'm haven't checked to see if there is one, but I have had caps go bad and due stupid stuff. Might be worth a try.
Add to AFLAC42's Reputation
Rate the quality of this post and help AFLAC42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AFLAC42 is offline   Reply With Quote
Old 04-22-2009, 12:39 PM   #23
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
That's not a bad idea. Might be worth a try.
Although, if they did a pressure check and everything was fine (no pressure loss), then I wouldn't suspect the cap to be a culprit.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 04-22-2009, 08:14 PM   #24
j0n
j0n is on a distinguished road
I was told that GM's temporary solution was to bleed the coolant, which my dealer did. It did seem to decrease the time that the warning flashes by about 50% but it does still come on. ALSO, anyone else that gets this light, you can(at least I can) cancel the warning by pushing either the large dial on the DIC or the left wheel on the steering wheel.
-2008 Saturn Astra XR3 5-spd - Bone stock daily driver
-1999 Corvette FRC - 11.985 @ 115.06(1.773) - Bolt-ons
Add to j0n's Reputation
Rate the quality of this post and help j0n reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
j0n is offline   Reply With Quote
Old 05-01-2009, 10:26 AM   #25
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
I was finally driving the wife's Astra the other day & tried your idea. Holding the round dial in did not clear the display. However, by holding down the "OK" button for about 10 seconds seemed to clear the display.
I have tried this before, but apparently I did not hold the button down long enough.
Thanx, j0n!
I owe ya a beer.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 05-08-2009, 09:04 AM   #26
j0n
Thanx, j0n!
I owe ya a beer.
.... did you say... beer?
Old 03-07-2011, 04:04 PM   #27
kieranna
kieranna is on a distinguished road
My wife's car has been displaying this pretty consistently for the past several days. I have checked the level, and it looks fine. No visible leaks from hoses or engine parts.
Anyone else have the same problem and diagnosed?
It would be nice if this car had a "coolant temp guage" like most cars in it's class.
What, Europeans don't believe in guages?
It would be also nice, if instead of blasting this message across the DIC, it would put it in red warning light somewhere else. No other information is reported on the DIC when this happens.
We have a 2008 Astra Xe, exact same problems. Coolant light randomly comes on, then no readouts on MPG, and not able to switch stations on radio or cd.
Coolant level has been checked by mechanics twice, but no leak? What have you done?
Add to kieranna's Reputation
Rate the quality of this post and help kieranna reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kieranna is offline   Reply With Quote
Old 03-07-2011, 09:30 PM   #28
Swordfish
Swordfish is on a distinguished road
Swordfish's Avatar
2009 Astra XE
Strictly pertaining to the coolant level issue, my sensor was replaced under warranty. it fixed the problem.
However, the other issues with the radio, I have no idea...
Marc-Antoine
2009 Astra XE 5-door, Twilight Blue.
"I have four rules in the Astra. No food, no drink, no smoking, and no vomit. Got it? Now... let me just put my coffee in the cup holder..."
Add to Swordfish's Reputation
Rate the quality of this post and help Swordfish reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Swordfish is offline   Reply With Quote
Old 03-10-2011, 05:52 PM   #29
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Held the "OK" button down for 10 seconds.
It should clear.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 03-14-2011, 05:48 PM   #30
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
My check coolant light comes on from time to time. It's just slightly below the fill line. When I took it in for an oil change the tech said the level was fine.
I suspect that the sensor is just sensitive, and adding a small amount of coolant will take care of it.
I'm going to wait until the next oil change and tell them to top it off (included in the price of the oil change). That way I don't have to buy a gallon of fluid for 1/2 a pint.
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 03-16-2011, 02:05 PM   #31
Swordfish
Swordfish's Avatar
2009 Astra XE
Thr fill line is actually the maximum line. The tank we fill is the expansion tank, so as long as you are near the line, it should be fine. The issue is the sensor itself.
Old 03-25-2012, 11:04 PM   #32
bdjones
bdjones is on a distinguished road
2009 Astra XE
old thread now but just in case someone else sees it you can get rid of (for that car trip anyway) of the Coolant Level warning by hitting the "OK" button. It dismisses the warning and you get the normal DIC back
Add to bdjones's Reputation
Rate the quality of this post and help bdjones reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bdjones is offline   Reply With Quote
Old 11-24-2012, 04:00 PM   #33
kikastra
kikastra has a spectacular aura aboutkikastra has a spectacular aura aboutkikastra has a spectacular aura about
kikastra's Avatar
2009 Astra XR
Sorry to bump an old thread, but for the past 2 weeks or so, when I would start the car in morning, the Check Coolant level warning would occasionally come on the display. This would only happen when I parked in my outside parking spot, which is on a very slight incline, and when the temperature was close to 0C. After a couple of times, I finally checked the coolant level, when cold, and it was down a little under an inch below the cold/kalt line. In the meantime I filled it back up with some dexcool. The car has only 38,000 Kms, so should I be concerned that the coolant level has dropped by that much?
2009 Saturn Astra XR3 5-Speed - 77,000KM
Add to kikastra's Reputation
Rate the quality of this post and help kikastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kikastra is offline   Reply With Quote
Old 11-24-2012, 06:46 PM   #34
smwalker
smwalker has a spectacular aura aboutsmwalker has a spectacular aura aboutsmwalker has a spectacular aura about
2008 Astra XR
If that is all you have added in 4 years I would not worry about it. if you see the warning in 4 days and it's an inch down then I would start looking for a leak.
Add to smwalker's Reputation
Rate the quality of this post and help smwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smwalker is offline   Reply With Quote
Old 11-24-2012, 08:37 PM   #35
darek_dade
darek_dade is on a distinguished road
It could be that your sensor went bad. My coolant warning comes on every 5-10 minutes. I will be doing this mod soon: http://www.astra-h.ru/antifrize_sensor.html. I already got the coolant tank from Opel Zafira and a new sensor.
09 Astra XR (manual, 3-door)
Add to darek_dade's Reputation
Rate the quality of this post and help darek_dade reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
darek_dade is offline   Reply With Quote
Old 11-24-2012, 09:14 PM   #36
kikastra
kikastra's Avatar
2009 Astra XR
Well for me I don't think it was the sensor as the coolant was actually a bit low. Hopefully as the above poster said, its nothing, and it doesn't go down again, in the next little while.
Old 11-24-2012, 09:16 PM   #37
kikastra
kikastra's Avatar
2009 Astra XR
Thanks, I'll keep an eye on it. I don't think I had a car that lost ANY coolant, that's why I'm a bit worried. But hopefully its nothing.
Old 12-01-2012, 12:50 AM   #38
lgodave
2003 ION-3 Sedan
If the Astra is like the ION... check that your Coolant/Tank is Clean and doesn't need changing.
The Sensor can get dirty and require cleaning (or replacement) to insure reliable readings.
Add to lgodave's Reputation
Rate the quality of this post and help lgodave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-16-2013, 07:58 PM   #39
kikastra
kikastra's Avatar
2009 Astra XR
Just a reply to the problem I was having. I did not have any issue adding a bit of dexcool to the reservoir to this day. So it looks like it was just a very small loss of coolant, and I can just add a bit more if the warning ever returns.
Old 05-19-2013, 04:34 AM   #40
carlomartin
carlomartin is on a distinguished road
It could be that your sensor went bad. My coolant warning comes on every 5-10 minutes. I will be doing this mod soon: . I already got the coolant tank from Opel Zafira and a new sensor.
Are you able to get this in english? OR how much did it cost you? and how hard is it to do?
Add to carlomartin's Reputation
Rate the quality of this post and help carlomartin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carlomartin is offline   Reply With Quote
03 L300 low coolant level light on intermitently level is fine wooskie L-Series General 16 03-27-2010 05:26 PM
Low coolant level and High coolant/transaxle fluid temperature nls S-Series Tech 2 08-30-2009 09:46 AM
low coolant level light on but plenty of coolant in reservoir smote S-Series Tech 2 11-11-2008 01:04 PM
Low fluid level warning lights kick in and out.... Serpico S-Series Tech 8 06-14-2007 04:34 PM
Low coolant light comming on... but coolant level is fine? joe4324 Miscellaneous Tech 3 12-02-2003 01:26 PM
